Old 11th April 2014, 17:38   #46
dark.knight's Avatar
Thanked: 2,963 Times
Default Re: Sx4 Idle Problem
I assume the car's injectors & throttle body have been looked at & serviced on schedule since you are already aware of it. Since this problem occurs only upon use of Ac this may be a simple fix under warranty.
The vacuum hoses related to the Ac should first be checked for leaks and replaced if so. Also for inspection is the idle air valve control which increases RPM when Ac is on to support the strain on the engine. Finally the HSS can try adjusting the throttle cable a bit tighter which in turn will help open the throttle valve more if need be.
dark.knight is offline   Reply With Quote
Old 12th April 2014, 07:21   #47
sudev's Avatar
Thanked: 2,385 Times
Does the a/c cut off also happen? in an older i20 I noticed some thing like this on a very hot day last summer but there the a/c was cutting off time and again - while we were in a traffic jam - most likely due to high temperature being sensed by ECM.
sudev is offline   Reply With Quote
Old 12th April 2014, 19:16   #48
Thanked: 53 Times
Haven't yet had the time to get it looked at at the HSS since the problem cropped up. The car has just gotten one paid service yet as per the schedule, don't know if injectors and throttle inspection would have been part of it.
No, the AC hasn't been cutting off, haven't taken the temperature knob down to the lowest setting yet as the summers are still a bit bearable.
Anyways, will head over to the HSS one of these days to get it checked. Was just worried if its a serious issue to have this crop up on a relatively new car.
Sinner666 is offline   Reply With Quote
Old 21st June 2014, 19:39   #49
Thanked: 53 Times
Just wanted to update that I finally managed to find time to get this looked at.
The service station guy hooked up the Gscan, tinkered around with some settings, and voila-issue resolved. Not sure what he did though!
Old 5th October 2015, 12:34   #50
Thanked: 11 Times
In my sx4,(odo @ 84k), O2 sensor is indicator always on. i checked with service guy, he said its ok and an indicator issue. i left the service station. but now i feel in idle rpm goes to 1.5k and comes to 500 for every few mints and there is jerk.
csanthosh is offline   Reply With Quote
Problem: High Idle RPM burnout_boy Technical Stuff 8 20th May 2016 16:19
Problem: Ford Ikon vibrating (almost shaking) when Idle. Eddy Technical Stuff 34 1st August 2011 13:26
Idle problem in Yamaha Gladiator Hashim Motorbikes 9 15th June 2010 15:59
Puzzling (and expensive) problem with Idle Speed ISA in Santro silverbyte Technical Stuff 0 15th July 2009 18:28
Suzuki SX4 or NHC type 1 second hand EDIT: SX4 now booked - EDIT 1 -Swift VDi booked GeekSrik Hatchbacks 126 24th June 2007 12:37
