Old 9th August 2010, 23:28   #31
msaudf's Avatar
Thanked: 152 Times
black exhaust smoke from a diesel engine can be caused by several reasons.
check the following
1. low fuel pressure
2. faulty injector/s
3. faulty fuel pump
4. restricted air flow. (most common)
or it can simply be your exhaust pipe itself. it could be clogged with carbon.
i suggest you begin by taking a look at your air filter first.
clean it or replace it.
while you are at it, try revving your engine gently with out the filter fitted for signs of smoke, but please remember to take the necessary precautions to NOT let any objects into the air intake manifold.
if the problem is still persistent check the injectors. getting them cleaned at a dedicated diesel pump repair shop costs only around rupees 500.
only after you've all of this and they don't help, ask them to check the fuel pump for malfunctions.
cheers
Saud
msaudf is offline   Reply With Quote
Old 10th August 2010, 10:21   #32
Vasanthan's Avatar
fuel pressure is fine ...
Injectors working fine (cleaned for 400 bucks) ...
Fuel pump rechecked twice for 5000 bucks ...
Had a trial without airfilter - problem persists ...
If exhaust pipe is clogged with carbon , will it smoke continously low at slow accelaration and huge at high accelaration ?
Getting continous black smoke when i accelerate !
Vasanthan is offline   Reply With Quote
Old 10th August 2010, 13:48   #33
Vasanthan's Avatar
Moreover Engine sound raises suddenly with less pickup when i accelerate above 50kmph in top gear , above 35kmph in 3rd gear , above 20kmph in 2nd gear where i am getting huge black smoke ......... In slow speed , engine sound is fine with less smoke !!!
white smoke from exhaust...its Turbo baleno neo_trace Technical Stuff 41 28th March 2015 11:39
Smoke from Car's Exhaust-Why? akshay4587 Technical Stuff 9 23rd November 2010 23:02
Verna crdi: black smoke from exhaust live2drive Technical Stuff 32 26th November 2008 11:43
Dark Greyish Smoke bellows from exhaust pipe Rahulk76 Technical Stuff 7 13th March 2006 01:06
