Old 1st November 2010, 14:46   #1756
SPIKE ARRESTOR's Avatar
Thanked: 807 Times
Proprietary items are covered by the respective manufacturers warranty, in such cases the decision taken by the proprietary manufacturer is final and binding.
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 1st November 2010, 14:54   #1757
Red Liner's Avatar
Thanked: 1,441 Times
Spike
What if the issue does not get resolved despite repeated efforts? How, when, and who makes the call to replace a particular component?
I know M&M has strict discipline in terms of not just replacing things under warranty but trying to find a cure for it. But how many times do they get this leeway?
If the proprietary manufacturer's decision is final, can the owner (affected party) take it up directly with the prop.manufacturer and deal with them rather than via the M&M dealer? How does the system work?
Red Liner is offline   Reply With Quote
Old 3rd November 2010, 12:33   #1758
comfortablynumb's Avatar
Thanked: 999 Times
Originally Posted by docfreak View Post
the bouncing ball game the scorpio plays and the rolls it takes when u go through undulations or corner at high speeds. looked every where fr solution but it came from mr sudhir kashyap. decrease the front tyre pressure to 28 and rear to 30. try it , then we shall discuss it. i have all the logics and reasons but before that try it for a week . everybody, we can have a poll on its results.
Has any other Scorpio owner on the forum tried this? If yes, with what results? Not sure about the crde, but the mHawk manual recommends 32 in all 4 tyres (for laden & unladen weights). Wouldn't a decrease of 4 psi be a bit too much?
Cheers,
Vikram
comfortablynumb is online now   Reply With Quote
Old 3rd November 2010, 13:16   #1759
getsurya's Avatar
Thanked: 962 Times
I tried 30 psi in all tyres and there is an improvement in the overall handling and behaviour of the ride. The other way to avoid bouncy ride(according to my childhood memories on my Grandfathers' Willys 4X4) is to load a sand bag or heavy stuff on the jeep's rear.
getsurya is offline   Reply With Quote
Old 3rd November 2010, 13:36   #1760
tsk1979's Avatar
Thanked: 16,012 Times
Using a air pressure lower than mfr recommendations and driving at high speeds can lead to blowout.
Old 3rd November 2010, 14:18   #1761
Thanked: 999 Times
Would a reduction by only a couple of psi's - say 30 psi in all 4 tyres - be advisable only for city driving? After all, we hardly get a chance to pass 40 kmph in cities (at least in Pune) and that's also where the potholes, speedbreakers and other miscellaneous surface undulations are most prevalent.
Cheers,
Vikram
Old 3rd November 2010, 14:25   #1762
tsk1979's Avatar
Below 80kmph there should be no issues. Problems crop up around 100kmph or more.
But if you need to lower air pressure below MFR recommendations for a comfortable ride, either you have unrealistic expectations w.r.t ride quality, or something is wrong with the suspension on your vehicle.
Old 3rd November 2010, 14:56   #1763
SS-Traveller's Avatar
Thanked: 11,590 Times
Tyre pressure recommendations are a compromise between city & highway driving, load, fuel economy and grip/handling. I maintain a 2-3 psi reduction in pressure below mfr. recommendations, if driving fast in any car with 2-3 passengers & little luggage. Blowouts are highly unlikely, unless the tyre is damaged otherwise.
In the city, I'm happier with a 1-2 psi increase above the recommendations for better slow speed behaviour & FE.
Old 3rd November 2010, 15:13   #1764
condor's Avatar
Thanked: 4,848 Times
Blow-out / explosions can happen more on over-inflated tyres. With under-inflated tyres, there is more sidewall flex and the walls of the tyres are not so much stressed as with over-inflated tyres. Also, in the event of hitting a pothole, the under-inflated tyre can more easily transmit the impact to the wheel /rim.
* IMO, recommended tyre pressures (as put forth by OEM's) would have been done so after testing.
* The recommened pressures are in a range, and going 2-3 psi more than recommended should not be a problem.
* This 2-3 psi increase would also not be too high above recommended levels, %-wise.
* The OEM recommeneded values are also well within the max pressure ratings of the tyre itself.
Considering the above points, going a little above or below is also not really a problem
Old 4th November 2010, 06:35   #1765
sudev's Avatar
Thanked: 2,507 Times
And that is why the tire wall gets weak and heats up leading to blow out!!!
I think what tsk1979 said was correct. See heading on inflation at wikipedia Tire - Wikipedia, the free encyclopedia
sudev is online now   Reply With Quote
Old 4th November 2010, 08:59   #1766
raj_5004's Avatar
Thanked: 2,061 Times
For the past few months, i have been filling my scorpio's tyres with nitrogen at 30 psi. works wonders for the ride quality. but of course, this is only for the city & short 15 mins highway bursts (city highways!). On a long trip, we increase the pressure back to 32 psi.
Old 5th November 2010, 09:20   #1767
agbenny's Avatar
Thanked: 113 Times
I fill 30 PSI Nitrogen too, It shows 43, 44 PSI in Tyretronics. The ride is not bad. I am confused with Tyretronics. Now sure which one to trust.
agbenny is offline   Reply With Quote
Old 5th November 2010, 11:55   #1768
raj_5004's Avatar
check the sensors. my car's sensors show 30.1 or 30.2 psi when filled with 30 psi nitrogen.
Old 6th November 2010, 08:38   #1769
pramods's Avatar
Thanked: 441 Times
The OEM Philips 60/55 for new refresh is not available either in service center nor in market, in market most of the bulb comes with 100/90 now, have ordered that at sevice center meanwhile gone ahead with Xtreme Power, feels better than original may stick with the and keep the original as spare.
-Pramod
pramods is offline   Reply With Quote
Old 6th November 2010, 13:04   #1770
Originally Posted by pramods View Post
... gone ahead with Xtreme Power, feels better than original...
It certainly does. I find night driving to be a lot more comfortable on the eyes, after two back-to-back weekend overnight drives, one to Amritsar (Hawk-On-Fours® (H-4®) Roadtrip - Amritsar & Pathankot) and another to Lucknow (Hawk-On-Fours® (H-4®) Roadtrip - LUCKNOW). The OE Philips bulbs went into my Swift, where the improvement was also marked in comparison to the OE Halonix which was there earlier. Now the Halonix bulbs do duty as spares!
Mahindra Thar : Issues & Solutions Rajith Technical Stuff 455 19th June 2018 21:11
Accent / Viva CRDi: Issues & Solutions manishk83 Technical Stuff 61 13th April 2015 14:00
Child safety issues and Solutions sreenidhibr Street Experiences 55 29th April 2013 18:18
