Old 10th November 2011, 21:08   #2581
SPIKE ARRESTOR's Avatar
Thanked: 674 Times
Default Re: Mahindra Scorpio : Issues & Solutions
^^ HVAC system pressure is monitored. Usually there is a pressure switch in the circuit (Trinary pressure switch) which monitors high pressure (blockage, faulty components) and low pressure (due to leaks). AFAIK, the compressor spec (for max and min pressure) is protected through this provision in the circuit.
Spike
PS- SST- Why do you think it must overheat? When the condenser fan fuse is removed so AC trips.
PPS- We have checked this (without any sophisticated instrumentation)-- no overheating.
SPIKE ARRESTOR is offline   Reply With Quote
Old 10th November 2011, 21:52   #2582
Thanked: 1,693 Times
Usually? Not in all Scorpios?
Sutripta
Old 10th November 2011, 21:53   #2583
SS-Traveller's Avatar
Thanked: 9,700 Times
Ok - so that's the safety net built into the wiring - but what would happen if you wire up the compressor to run, but stop the electric condenser fan from running?
Old 10th November 2011, 22:12   #2584
Someone post the Scorpio wiring diagram please.
Sutripta
Old 10th November 2011, 22:56   #2585
vraghuz's Avatar
Thanked: 22 Times
Dear All,
Today while cleaning the vehicle , my cousins driver broke the Key of the Hawk , grrrr..sigh !!!! , called up the ASC they say , i need to change the key set in the doors, re program the new key set all of which is going to cost me nearly 9k ..!!!
Do i have any other options ????
vraghuz is offline   Reply With Quote
Old 10th November 2011, 23:06   #2586
Thanked: 674 Times
All.
I would paraphrase this question of yours-- What happens in a Thar (no condenser fan) with AC?
Spike
Old 11th November 2011, 00:05   #2587
4x4addict's Avatar
Thanked: 1,987 Times
@SS & S
Do you guys think that Mahindra would design an engine that depended on the condensor fan to control engine temperature? The cooling system has to be designed to control engine temperature without depending on the condensor fan.
4x4addict is offline   Reply With Quote
Old 11th November 2011, 00:33   #2588
akshay4587's Avatar
Thanked: 1,506 Times
Originally Posted by vraghuz View Post
Dear All,
Look around,and you might be able to get a new one made,for cheap.
the programmed chip can be transplanted from the old key to a new one.
Old 11th November 2011, 07:29   #2589
Thanked: 243 Times
AFAIK, every AC compressor has an internal high pressure protection built in. This could be a pressure relief valve or a bursting disc. In the event of impermissible pressure being built up the discharge port is shorted to the suction port or the crankcase.
It is industry practice to not depend on external wiring and circuitry to prevent dangerously high pressures.
Low pressure protection is left to external circuitry to manage, since the consequences are not potentially dangerous.
Old 11th November 2011, 07:42   #2590
Thanked: 674 Times
Is this ^ ^ (pressure) monitored then in a Compressor? Yes / no and how?
Spike
Old 11th November 2011, 08:03   #2591
Thanked: 243 Times
Spike
Yes, this pressure is 'monitored' within the discharge port of the compressor. This is always a passive, 'pre-set' device, a valve or a bursting disc made of suitable material. Totally fail-safe.
For the old fashioned R22 compressors, for example, the in-built relief valve or the bursting disc would be set to blow at 20 bar.
The external control circuitry, if provided, would have the HP cut-out set at, say, 18 bar. If this fails, the in-built protection kicks in.
These are figures used in water cooled systems; values would differ for air cooled systems.
Old 11th November 2011, 08:34   #2592
Thanked: 674 Times
I am aware of this ^^. Hydraulic devices (e.g compressors, HP pumps) must have an inbuilt safety device (e.g. relief valves, by pass etc) built into them. What I asked was regarding "external control circuit' as mentioned by you above. How does that happen?
Spike
Old 11th November 2011, 08:48   #2593
Thanked: 243 Times
.... What I asked was regarding "external control circuit' as mentioned by you above. How does that happen?
Spike
Spike, I don't think our cars have any such external control circuit. There is no LP cut-out that I can see. There seems to be no HP cut-out either!
The compressor clutch is de-coupled in case of condenser fan failure?
This would not be fool proof; I suppose the inbuilt protection of the compressor would be called into play if discharge pressures go to dangerous limits.
Any details about the Scorpio HVAC system would be most welcome.
Old 11th November 2011, 09:43   #2594
Thar? What AC? You guys left out the AC - or don't you remember? Then the after-market fitments have all kinds of modifictions - with fans, without fans, whatever. Any extensive regimented testing done by M&M while running AC without an additional electric fan?
Old 11th November 2011, 10:31   #2595
Thanked: 244 Times
Originally Posted by Zed View Post
Try this - the next time the temp gauge starts going into the red zone, pull over and with the engine idling switch on the high beam \ try short bursts of the horn etc and look out for any sudden movements of the temp gauge needle. If you can spot some movements happening immediately when the hi-beam or horn is used, you can be rest assured that its an earthing problem with the electrical system. The first gen Scorpio had an earthing point somewhere near the wheel well...not sure if the design was changed in later variants.
Zed,
This morning, I had the same problem, again it was ephemeral. Was playing loud music (have an amplifier) and when the needle shot up, tried what you said.. honking, high-beam, loud music (don't know whether it matters)... didn't observe anything different.
And right from the beginning, there's no sudden movement (twitching) of needle ever. It was always smooth.
And by the way, discussion amongst you/ss/4x4/sa was very interesting and enlightening... keep it going.
tifosikrishna is online now   Reply With Quote
Mahindra Thar : Issues & Solutions Rajith Technical Stuff 385 23rd November 2016 15:43
Accent / Viva CRDi: Issues & Solutions manishk83 Technical Stuff 61 13th April 2015 14:00
Child safety issues and Solutions sreenidhibr Street Experiences 55 29th April 2013 18:18
