Old 6th December 2012, 14:01   #3121
akshay4587's Avatar
Thanked: 1,684 Times
Default Re: Mahindra Scorpio : Issues & Solutions
How long are they supposed to last?
Ours is at 41K and got the pads checked at 40K service,and got a thumbs up that they are fine.
Old 6th December 2012, 14:08   #3122
Thanked: 39 Times
@RJS: Thanks. Have told dealer to go ahead with brake pads. Regarding Shocks, I am trying to source Bilsteins from Germany so am waiting. OEM shocks here is Gabriel costing 2.5K and Bilsteind might cost close to 5K. So that's where I am at. I mostly drive alone in NCR on good roads.
@Comfortablynumb: Yes its first brake pad change. I am little luckier in that I usually drive in off peak traffic on good roads but generally I avoid braking by keeping a safe distance at that speed if I can't overtake from either side. Also I keep changing lanes so i dont have to slow down by applying brakes...That's one of the reasons my JK Elanzos have anoth 15-20K remaining in them. That's what I was told by the manager of a wheel balancing store recently.
JKBKS is online now   Reply With Quote
Old 8th December 2012, 01:36   #3123
octane78's Avatar
Thanked: 28 Times
Hello people, I just had a query regarding my 2010 Dec model Scorpio VLX. It has been quite sometime that I have been on highways and today by chance I was driving over the PVNR expressway and thought that I would engage the cruise control and to my horror I find that it does nothing the vehicle slows down. I tried it several times but it failed. So I call up VVC service guys and they advice me to get the beast in to have a look. Did any of you people face this kind of a situation?
octane78 is offline   Reply With Quote
Old 8th December 2012, 11:16   #3124
SS-Traveller's Avatar
Thanked: 11,578 Times
Check if the brake lights remain on all the time. Explained in detail here...
Another irritant is a little rubber button on the brake pedal, that engages the brake light switch. The rubber self-destructs in a few thousand km, leaving the brake lights glowing and the cruise control out of action. That's easy to fix - with a bit of hard plastic and a couple of drops of Fevi Kwik. The last time I did that was over 20,000 km ago, and I haven't had the brake lights come on unnecessarily till the time of writing this. When cruise control fails to engage, the first thing to investigate is that little rubber button.
SS-Traveller is offline   (1) Thanks Reply With Quote
Old 8th December 2012, 12:00   #3125
4x4addict's Avatar
Thanked: 2,651 Times
As SS has mentioned, it is most likely your break or clutch sensor. Can you also check if your Micro hybrid is working?
4x4addict is offline   (1) Thanks Reply With Quote
Old 10th December 2012, 12:45   #3126
AVR
AVR's Avatar
Thanked: 530 Times
Last night took the Crde out for a drive and it started fine. Though in retrospect, it looked like something was amiss. Anyways 5 mins later, when I stopped to get something, It didn't start again. Had the krrrr-sound when I tried to start. Some orange-light started flashing on the dashboard. Checked if the battery connection had got loose or something but that wasn't the case. Got it push-started and reached home. In the parking, tried to start it again but same issue (same krrr sound). What could it be? In my Jeep when this happens, I usually rock it back-and-forth in 2nd gear and then try again and that usually works. Not sure how these ECU engines work.
Wife's car so don't really use it much but glad it was me and not her when this happened.
AVR is offline   Reply With Quote
Old 10th December 2012, 13:31   #3127
m_upreti's Avatar
Thanked: 309 Times
My front RHS window stopped working recently, it would wind up only about of couple of inches down and stop. It was making some sounds and a oily line was coming through on the glass for last few weeks but finally it stopped completely.
Took the car over to a local garage, one of the supporters (white plastic arm) had broken and the entire winding assembly had to be replaced by cutting the rivits and reinstalling with bolts.
The assembly cost me Rs. 780.00 & Rs. 300 for the fitting.
If you can tell which light was flashing (engine check ? , as it is usually orange) it may get more insight on the issue. The krr sound would be the ignition turning but the engine not firing.
I have had this issue, the problem was on acccount of one of the connecting wires which had broken. The vehicle slows down because once you apply the cruise control and leave the accelerator the ECU is not taking over the control of the fuel supply.
m_upreti is offline   (1) Thanks Reply With Quote
Old 10th December 2012, 14:33   #3128
AVR
AVR's Avatar
Thanked: 530 Times
The battery is Sep-2010 Amaron 80 mAH. Is it past its life?
The light was the orange one here in the CRDe cluster:
Source pic: Team-bhp.com
Mahindra Scorpio : Issues & Solutions-scorprio-cluster.png
Old 10th December 2012, 16:27   #3129
m_upreti's Avatar
Thanked: 309 Times
Cant make out much from the image, let me crosscheck with my mHawk cluster, it should be similar. (What is the shape of the image).
The battery should be fine, my 2007 original is still going strong, but check if you are able to run the headlights with good power.
Old 10th December 2012, 20:39   #3130
akp
akp's Avatar
Thanked: 151 Times
Anyone has a pdf version of the Scorpio manual? Very useful to have it on your laptop/tablet but have not been able to find one yet.
akp is offline   Reply With Quote
Old 11th December 2012, 06:58   #3131
Thanked: 253 Times
..... What could it be? In my Jeep when this happens, I usually rock it back-and-forth in 2nd gear and then try again and that usually works. ....
Probably the armature of the self starter motor.
Either it is not making full travel to engage with the flywheel gear or the armature gear teeth are worn.
anupmathur is offline   (1) Thanks Reply With Quote
Old 11th December 2012, 09:05   #3132
Styler's Avatar
Thanked: 247 Times
It is called the Self Bendex. This needs to be replaced. Simple job, and not too expensive.
Styler
Styler is offline   (1) Thanks Reply With Quote
Old 11th December 2012, 10:23   #3133
Thanked: 253 Times
Originally Posted by Styler View Post
It is called the Self Bendex. ...
I'd call it a bendix. And yes, it could be the bendix or the solenoid that makes it articulate with the flywheel splines.
Old 11th December 2012, 11:14   #3134
AVR
AVR's Avatar
Thanked: 530 Times
Styler
As it turned out, the battery had gone dry and one of the battery cells had conked off so had to replace the battery. To eliminate all doubts, everything worked fine with a different used battery so the culprit was correctly identified. Picked up the SF Jumbo 8800 for 5200 Rs.
Additionally, in the Crde, harshness/vibration is a bit too much at idle and even during the drive. Is there no solution to that? Engine/body mounts? Any fuel/engine oil/transmission additive? I used Mobil Delvac MX this time but it didn't reduce the harshness as much as it does in my TCIC Safari.
Old 11th December 2012, 15:11   #3135
Thanked: 36 Times
Is the old one a Amaron Black battery? I had a Amaron Black in my CRDe and it gave me exactly 23 months life which I thought was very less. Thinking it a one off case I replaced it with the same battery again. Now I wonder if the Amaron Blacks life is just around 2 years while most other batteries serve a lot more.
Attachment 1025488
asdfvinay is offline   Reply With Quote
Mahindra Thar : Issues & Solutions Rajith Technical Stuff 454 18th June 2018 21:47
Accent / Viva CRDi: Issues & Solutions manishk83 Technical Stuff 61 13th April 2015 14:00
Child safety issues and Solutions sreenidhibr Street Experiences 55 29th April 2013 18:18
