Old 8th August 2017, 10:33   #4336
Styler's Avatar
Thanked: 222 Times
Default Re: Mahindra Scorpio : Issues & Solutions
What happened if you turned the "ignition" back on?
Sutripta
If you turn it back on, the rpm and sound becomes like it is normal idling.
My mechanic's theory here is that the solenoid switch contracts and does not stop the flow of diesel completely.
I was worried because this behavior also happens when the Turbo is leaking oil and this regularly happened before my engine run-away incident and it completely broke down. The difference is that at that time it was happening in Delhi.
I got my turbo checked and there was no oil leak, and this time the phenomena happens only at high altitude and the moment we come down to under 2000 Mtrs everything becomes normal.
Styler is offline   (1) Thanks Reply With Quote
Old 8th August 2017, 11:53   #4337
1100D's Avatar
Thanked: 2,391 Times
Is there an Ambient temperature aspect to it, rather than the Altitude? Am trying to divert thought towards the injectors.
1100D is online now   Reply With Quote
Old 8th August 2017, 21:07   #4338
Thanked: 2,198 Times
Wondering if something to do with crankcase ventilation. Can't quite figure out the chain of events wrt role of altitude.
Sutripta
Old 8th August 2017, 23:58   #4339
wrongturn's Avatar
Thanked: 436 Times
The only logical reason I can think of this problem is that at higher altitudes the air is considerably lighter, and the diesel engine only needs fuel and air to run, and the mechanism to switch it off is to block the air supply. Maybe air leaks through the vacuum at higher altitudes and that's what keeps the engine running.
wrongturn is online now   Reply With Quote
Old 9th August 2017, 09:55   #4340
dhanushs's Avatar
Thanked: 4,150 Times
Originally Posted by wrongturn View Post
.. and the mechanism to switch it off is to block the air supply. ..
Diesel engine switched off by cutting fuel supply. Not air.
My mechanic's theory here is that the solenoid switch contracts and does not stop the flow of diesel completely.....
Next time when this happens, try removing the injector lines, any one of them, and see if there is diesel pumped. That way, we can figure out, if this is an engine problem or fuel pump problem.
dhanushs is offline   (2) Thanks Reply With Quote
Old 9th August 2017, 10:24   #4341
wrongturn's Avatar
Thanked: 436 Times
My mistake, I was trying to relate air and high altitude together as a problem, should have mentioned fuel too. But since the problem occurs at high altitudes only could only think about air density and how that could be related with the issue.
Another couple of views with respect to air density and high altitudes, since this engine was recently rebuilt.
1. In many vehicles, a crankcase breather pipe feeds into the air intake to vent the crankcase. On a highly worn engine, gases can blow past the sides of the pistons and into the crankcase, then carry oil mist from the crankcase into the air intake via the breather.The engine will run on this oil mist, since engine oil has the same energy content as diesel fuel. The engine revolutions increase as this extra fuel is taken in. As a result of increased revolutions more oil mist is forced out of the crankcase and into the engine, and a vicious cycle is created. But this is less likely as it was just rebuilt and let's hope everything is in it's proper place.
2. Engine could have a bad fuel solenoid or bad rings/pvc system. There is a problem with the air pumps for the brake booster with internal leaks keeping oil and vapors in the intake system, allowing run-on.
Just trying to assume that the problem is related to a vacuum leaks, from one component or another which feeds the engine some sort of fuel to keep purring, bearing in mind high altitudes and lighter air density.
Old 9th August 2017, 10:58   #4342
dhanushs's Avatar
.. There is a problem with the air pumps for the brake booster with internal leaks keeping oil and vapors in the intake system, allowing run-on..
Again, in a diesel engine (Scorpio), the brake booster vacuum is generated by a vacuum pump in the alternator, not the intake manifold vacuum like in petrols.
Old 9th August 2017, 16:47   #4343
wrongturn's Avatar
Thanked: 436 Times
I stand corrected again. Thanks.
Does that version of Scorpio comes with a High Altitude Compensator. About mHawk I know that ECU has different variables set for different altitudes. But no knowledge about HAC.
Also, as you mentioned about checking the injectors, in what way the functioning of injectors related to variable altitudes. Could you elaborate.
Old 9th August 2017, 18:03   #4344
dhanushs's Avatar
Removing the injector lines, not injectors, will show if any diesel is being pumped when this condition occurs. That way, one can finalise which part (engine or pump) the problem is. Or its the oil or diesel that is being burnt for the engine to run.
dhanushs is offline   (3) Thanks Reply With Quote
Old 9th August 2017, 19:33   #4345
Thanked: 252 Times
You mean removing/opening up high pressure fuel lines while the engine is still idling?!
Old 9th August 2017, 20:18   #4346
Any examples?
Can't get what is meant
Sure. Done all the time with jerk/ rotary (ie. non CR systems) FIPs.
Sutripta
Sutripta is offline   (2) Thanks Reply With Quote
Old 12th August 2017, 12:01   #4347
Thanked: 690 Times
Your mechanic could well be right, Styler. You have mentioned that you renewed the fuel cut-off solenoid v/v at the time of the engine rebuild. Solenoid v/v issues are too common to dwell on (impurity caught between v/v & seat & not getting cleared with fuel flow, solenoid core not returning to rest position, etc) & it maybe a good idea to get the unit (solenoid & v/v) checked. As we all know an engine does not run on fresh air & love alone! For some reason fuel is reaching the jerk pump & then to the injectors even after switching off. Also as you have clarified the issue is not the same as your earlier experience with a runaway engine (God forbid!), with engine oil reaching the combustion space. So eliminate one source, the solenoid fuel cut-off valve first.
I have my fingers crossed that the problem & its solution is as simple as I'm hoping and not something more profound. Like you, I too belong to the pre-CRDE Scorpio era & love my Bucephalus as much!
shashanka is offline   Reply With Quote
Old 12th August 2017, 17:53   #4348
Styler's Avatar
Thanked: 222 Times
Before my engine runaway this was happening in Delhi and a few days before the engine runaway the Mahindra Authorized Workshop had told me during service that the Turbo was leaking oil. That time it was surely the leaking oil from the Turbo which caused the run-away.
The issue that you miss is that now it is happening only at high altitudes over 2000 mtrs not. As soon as we come down the engine shuts off normally, so it is not the impurity in the solenoid as that would make it happen in Delhi too. There is no way for us to check in Delhi. As a precaution I have got the Turbo checked and it is not leaking oil. Moreover HVK has reported the same has been happening to his scorpio at high altitude without any damaging consequences. I am just not bothering about it too much as long as it is not happening here in Delhi. It's just a few days in the year that I might be at high altitudes anyways.
Styler.
Old 12th August 2017, 21:55   #4349
Thanked: 690 Times
Styler.
You are right of course - so it is a bigger headache than anticipated. And I'm relieved that it is restricted to high alt. and disappears when you return to Delhi. Gives you more time to work around the problem. I'm going to give it some thought too & ask around - there are a few similar vintage Scorpios here in Lucknow too - & see if any one else has experienced similar symptoms.
Shashanka
shashanka is offline   (1) Thanks Reply With Quote
Old 15th August 2017, 13:53   #4350
Thanked: 690 Times
Hello Styler, I took the liberty of writing to mahindra's customer care (without any serious expectations, mind you! ) and surprisingly got a very prompt reply. I did not know how to proceed further, so am attaching both - my mail and M&M's reply, in the hope that it just might be of some help in solving the problem you are facing.
Shashanka
Shashanka Choudhury shashach@gmail.com
to: customercare@mahindra.com
date: Sun, Aug 13, 2017 at 12:38 PM
subject: Engine does not shut down after switching off ignition at altitudes above 2000 meters.
Hello,
The above problem is occurring in my friend's 2003 model Scorpio when travelling at above 2000 m altitude (in the hills of HP & UK). When the vehicle returns to the plains, the problem disappears & and the engine stops normally on switching off the ignition.
Would be grateful for advice / suggestion in solving issue.
Shashanka Choudhury
CUSTOMERCARE
8:18 AM (5 hours ago)
to me
Dear Sir,
Thank you for writing to us.
We request you to kindly provide us your Contact Number, Vehicle Registration No and Dealer Details.
Looking forward to hear from you.
Thanks & Regards,
Mayuresh Walanju
Customer Care-Automotive Division
Reach us at:
cid:image001.jpg@01D1FC9E.EDBEC5B0@18002096006
cid:image002.jpg@01D2C034.2252CD90 customercare@mahindra.com
Mahindra Thar : Issues & Solutions Rajith Technical Stuff 446 11th February 2018 18:16
Accent / Viva CRDi: Issues & Solutions manishk83 Technical Stuff 61 13th April 2015 14:00
Child safety issues and Solutions sreenidhibr Street Experiences 55 29th April 2013 18:18
