Old 27th October 2009, 18:23   #706
Red Liner's Avatar
Thanked: 1,170 Times
Ok here comes my 1st issue. Both my central locking keys dont work from distance, I literally need to walk up to the Scorp' and lock/unlock . Highly unlikely that both the batteries have gone kaput.
Am sure it has something to do with the central locking assembly itself. ?Haven't had the time to sit back and fiddle around with this and read the manuals. Kinda too busy enjoying all the respect on the road, while this has taken a back seat in my priority list for now.what do you folks suggest
I have the same trouble. Even after having them open up the *antennae* near the gear box cover and increase the size of it or something. Basically pulled it out and stretched it for better receiver signal.
It still gave me trouble. But its reasonably better now. Works at about a 7 feet distance. But still dumb.
The only good thing about this is if you slip the console into your pocket and you misadvertently press the unlock button - nothing can possibly happen. Talk about seeing a silver lining on a dark cloud!
If you're talking about the battery within the console - maybe. But if its the same trouble with both sets? Replace both batteries? I doubt thats the issue.
Red Liner is offline   Reply With Quote
Old 27th October 2009, 20:27   #707
Thanked: 252 Times
Originally Posted by Red Liner View Post
... But if its the same trouble with both sets? Replace both batteries? I doubt thats the issue.
I tend to think the same way.
Maybe the receiver unit has 'toppled' inside and is in an awkward position where it cannot receive the signals properly.
Or the power connections to the receiver are corroded and need cleaning.
Old 27th October 2009, 21:14   #708
rjstyles69's Avatar
Thanked: 791 Times
Thanks for your replies folks. Looks like its time to get me hands dirty and check as suggested.Maybe a quick visit to the service center should do the trick.
Old 27th October 2009, 22:29   #709
Red Liner's Avatar
Careful! A quick visit to the service center could end up being more trickier Just kidding, you obviously know enough and more about the blokes sitting in the official garages. Let us know how it turns out.
I miss the ability of being able to check if my car is locked or not from the first floor of my gym a good 500 metres away. Used to get away with this in my erstwhile Petra Diesel.
Miss that baby. Ah, that's another story.
Old 28th October 2009, 13:31   #710
benbsb29's Avatar
Thanked: 3,529 Times
Somewhat off-topic.
I sometimes check if my car which is parked in the building basement is locked from my balcony 3 floors up. When i normally point the remote in the general direction of the car, and try, nothing happens. Point the remote close to your head, and viola! The beep informing the lock sounds.
Dont know how it works, had read about it somewhere on the forum itself, and it worked... and i was able to replicate it on more than one occassion as well.
Remote locking unit in question is the Autocop Cobra.
Old 28th October 2009, 14:21   #711
shankar.balan's Avatar
Thanked: 5,331 Times
Dont you think you will be causing some kind of chaos to your brain if you do this?
Somewhat off-topic.
Old 28th October 2009, 18:11   #712
nvldvr's Avatar
Thanked: 253 Times
Looking to get underbody antirust treatment done on my scorpio as it will be used mainly in coastal areas only. Can anyone comment on how effective it actually is? What brand of antirust coat do mahindra A.S.S people use? Any better alternatives available?
nvldvr is offline   Reply With Quote
Old 29th October 2009, 22:43   #713
anjan_c2007's Avatar
Thanked: 4,755 Times
Ever faced a puncture with the tubeless tyres of the Scorpio? Guess that can't be repaired by the roadside puncture wallahs on the highways and even within cities.Hope to get opinions from fellow Scorpio(n)s!
Am quoting these lines from www.carwale .com
The must-haves for a car with tubeless tyres are: a plug puncture repair kit and a spare tube. Now, why a tubeless tyre need a tube? In case of a puncture you cannot repair on the road, you can simply insert the tube into the tyre and use it just like an ordinary tube-type tyre until you get home.
anjan_c2007 is online now   Reply With Quote
Old 29th October 2009, 22:49   #714
hvkumar's Avatar
Thanked: 3,357 Times
I have. If I am close to home, I go to my regular tyre puncturewala who knows how to fix a tubeless tyre puncture - and also has the machines to remove the tyre properly. When I am travelling ouit of town, I try to find a tyre alignment shop who are probably the bets guys to fix a puncture. And I also carry the tubeless puncture repair kit - but never did it myself so far - and spare tubes. Last week, my stepney kept leaking air because of rusty rim, so I have put a tube inside and it is now stopped leaking.
hvkumar is offline   Reply With Quote
Old 30th October 2009, 09:33   #715
Thanked: 252 Times
Anjan, in the north the situation seems to be a lot better. Along the highways and in hill towns it is not a problem at all to find puncture wallahs who repair tubeless tyre punctures, even in situ, without taking the wheel off.
Old 30th October 2009, 11:12   #716
tsk1979's Avatar
Thanked: 15,683 Times
thanks to innova, the first taxi with tubeless tires, now you find tubless repair shops everywhere, even in small towns!
Old 30th October 2009, 12:04   #717
Red Liner's Avatar
Where do you usually keep your mobile phone? In your pockets in your pants? Mobile phones are known to emit harmful radioactive waves. Guess where those waves are bouncing off
Old 10th November 2009, 23:09   #718
Thanked: 7 Times
Default Advise needed
Can anyone please comment on my post #677 (permalink). Appreciate your inputs on this.
I have booked 20th Nov for the 1st servicing. I hope global gallerie Panvel rectifies all the problems.
Real_man is offline   Reply With Quote
Old 13th November 2009, 21:13   #719
You seem to have a clutch bearing issue and considering your vehicle is new its probably a manufactuing defect. IMO They should replace the clutch/pressure plate and fork bearing.
Have you tried Global Gallarie Thane branch? Excellent service.
Mohnish is offline   Reply With Quote
Old 14th November 2009, 23:25   #720
Default Brake issue with new mHawk Scorpio
I bought a new Scorpio mHawk VLX a few months back(June 2009). I am having this strange issues with the brakes.
1. When I freshly start the vehicle (after a break of around 20 to 30 mins or more) and drive for a few meters and apply the brakes, the brakes locks up and the vehicle skids. The braking action is not smooth. This is really embarrassing especially at valet parking when he gets back the vehicle. You can easily make out the vehicle brakes are screwed up.
2. This is a more serious issue and a safety hazard. When I am driving above 50 or 60km/hr and I have to apply brakes for a speed breaker or anything, I hit the brakes, release the brake and apply again (while changing the gear). When I apply the brakes the second time the brake peddle becomes hard and I hear this gad..gad..gad...sound and the vehicle does not slow down (basically I don't feel the brake working at all). I immediately release the brake, apply again and chances are it works.
I have sent back the vehicle to the showroom thrice in the last 1 month to get this fixed and the issue remains. The showroom rep asked me to register a complaint with M&M to replace the ABS system.
I am not sure what to do now. Should I send the vehicle to another garage in Bangalore to get it checked/fixed ?
Any advice/help appreciated. Let me know if you need further details and I can provide it.
Sudhir
vasudhir is offline   Reply With Quote
Mahindra Thar : Issues & Solutions Rajith Technical Stuff 439 31st December 2017 19:25
Accent / Viva CRDi: Issues & Solutions manishk83 Technical Stuff 61 13th April 2015 14:00
Child safety issues and Solutions sreenidhibr Street Experiences 55 29th April 2013 18:18
