Old 15th December 2009, 11:32   #826
Thanked: 388 Times
Originally Posted by tvsakpal View Post
Dear All,
Thanks for all your comments and guidance. Well the beast is back and rurrning good. My contact pint at SS did agreed that electrical mechnic goofed up, he diodnt tighten a switch properly which resluted in the incident.
He is still not coming clean , It can not be electrical switch IMHO. It was something mechanical which resulted in brake line leakage.
Another query though, I drove 22 kms today and avg speed was 75-80 kms/hr (as its a highway). After parking my car in office i checked all 4 tyres and the wheel caps were quite hot. I never tested this earlier hence not sure if this is normal. Please guide.
Thanks,
Tushar.
Does not look normal on modern SUV , Wheel cap should not heat up in just 22 KM so still I feel all is not well with your braking system.
Based on this detail my guess is that your brake pads may be rubbing causing hubs to heat , Earlier there might be some leakage in your braking system and this overheating resulted in complete failure.
Please compare it with another Scorpio or talk to some other scorp owner and take action soon.
Others may comment on this hypothesis.
amitk26 is offline   Reply With Quote
Old 17th December 2009, 13:40   #827
Wolfheart's Avatar
Thanked: 22 Times
Hey there fellow Scorp masters,
It's realy dumb but I have to ask this questions. Yesterday when I unlocked my car (with remote) it gave me 3-4 long beeps instead of the regular 2 short beeps. Once I got into the car there was a lock shaped red icon blinking in the dash. I know that this indicates some issue with the security system. Does anyone know why this happens? It's happened a couple of times earlier as well. Both times, my car was parked outside my office.
I would also like to ask if anyone knows any good accesories shop in Mumbai? I need to get a nice bull guard and a couple of fog lamps.
Wolfheart is offline   Reply With Quote
Old 17th December 2009, 14:51   #828
n.devdath's Avatar
Thanked: 1,745 Times
What was the blinking pattern of your icon?
The codes for these beeps are mentioned in the owner's manual for the security system but as far as I remember, they beep for 4 times continuously when it has foiled an attempt to tamper.
I may not be correct but it is my hunch. Your manual would explain these fully.
Old 17th December 2009, 15:12   #829
Thanked: 252 Times
...they beep for 4 times continuously when it has foiled an attempt to tamper.
That is correct. Four chirrups mean there has been tampering in your absence!
Old 17th December 2009, 16:57   #830
raj_5004's Avatar
Thanked: 2,036 Times
who is tampering with your vehicle wolfheart? pesky kids in your society???
also, just FYI, 4 beeps while locking (instead of the regular 2) means that one of the doors is not closed properly.
Old 17th December 2009, 19:44   #831
Wolfheart's Avatar
Thanked: 22 Times
Hey guys thanks for all your replies.
The car is parked on the street outside my office building. There could be a thousand losers out there trying to tamper with my car.
Old 17th December 2009, 19:44   #832
suman's Avatar
Thanked: 257 Times
In the Safari 3.0L, the lock shaped red icon blinking in the dash indicates that the engine immobiliser has been activated. It happens if it detects that the doors have been opened but the key has not been inserted in the ignition within a certain number of seconds. In case someone opens a door forcibly,the alarm (in its case the Horn) goes off as well apart from the immobiliser getting activated.
It could be the same in your vehicle, particularly if the doors had not locked earlier (as pointed out by Raj) or if someone tried opening a door.
Old 17th December 2009, 19:51   #833
Wolfheart's Avatar
Thanked: 22 Times
Whoah! So does it mean that someone got into my car but couldnt crank the engine so just quietly shut it and left?
My car gets washed everyday as well. Sometimes I hand my keys to the car washer so that he can clean the interiors as well.
is it possible that he forgort to shut the car properly?
Old 17th December 2009, 23:14   #834
capt.chandru's Avatar
Thumbs up VLX Third gear Vibration Ceased
Greetings Bhp-ians,
I am happy to inform you all that the Third gear vibration in my Scorpio has ceased finally after the installation of the kit provided by Mahindra and Installed by A.S.S. ( CAI Industries, Coimbatore ).
It took about Two and Half days for the A.S.S. to return me the vehicle after i had left it to install the kit and do my 50,000 km service. Finally, i got it today and I am very happy to see the vibration not existing.
and this is how it happened, I had to written to the customer care about 3 weeks ago about the vibrations i had on the 3rd gear. I had the Customer Care people calling me about 3-4 times asking me about the service centers where i service my vehicle. Another couple of days later , i had the customer service manager of the A.S.S. calling me to tell me that , this problem has been talked to Mahindra and they have got a kit to install to get that problem solved. So, Finally i had left the car for service which was also ready for the scheduled 50k maintenance and i got the car with the problem not existing.
Thank you Mahindra ! You have done a great job !
capt.chandru is offline   Reply With Quote
Old 17th December 2009, 23:46   #835
Default VLX 50000 KMS service Report
Hi guys,
I just got my Scorpio VLX from the 50,000 Km scheduled service at CAI Industries, Coimbatore today and the following was charged for the service.
PARTS
1. Maximile Supreme 5 - INR 848.89
2. Oil Supreme (2) - INR 344.88
3. Oil Filter - INR 138.66
4. Oil Seal Front HUB (2) - INR 152.12
5. Wheel Bearing Grease - INR 135.00
6. ANABOND - INR 12.92
7. Scuff Plate Set ( which i had asked them to install ) - INR 640.00
8. Break Pad Kit - INR 3801.78
9. Lower Link Bush (2)- INR 264.88
10. Lower Link Bush 45 (2) - INR 128.00
11. Rustlick 631 (2) - INR 142.00
12. ANA Bond (3) - INR 38.85
13. Clutch tube slave - INR 177.78
Labour Charges
1. Paid Service : INR 3960.00
2. Scuff Plate FIX : INR 60.00
3. Link Rod Bush Kit : INR 450.00
4. Consumables and Lube : INR 250.00
5. Sundries : INR 50.00
Total : 6961.64 (Parts ) + 4770.00 (wages ) + Tax = INR 13,093/-
* The Break Pads, Lower Link bushes and Scuff plates where the things which are done apart from the scheduled service for 50,000 km.
Old 18th December 2009, 09:38   #836
Hi Capt.
3960 for a paid service sounds like a lot. Can you give us a break up?
shekharlele is offline   Reply With Quote
Old 18th December 2009, 09:57   #837
suman's Avatar
Thanked: 257 Times
That is a distinct possibility & a dangerous one - you'll end up losing stuff that's inside the car if he's that careless. Best not to give him the keys unless you're present.
Old 18th December 2009, 14:41   #838
@shekharlele : There was no breakup on the bill and i see that A.S.S. here in coimbatore and in chennai seems to have a preset value for the scheduled services.
I have not taken the car to any other service centers , so i am not sure about it.
anyway, It stated " 50,000 Km service : INR 3960.00 "
Old 18th December 2009, 16:42   #839
4x4addict's Avatar
Thanked: 2,513 Times
I think these dealerships are milking money. I think we should insist on doing only what the manual calls for and get a breakdown of the labor expenses.
4x4addict is offline   Reply With Quote
Old 19th December 2009, 12:23   #840
mooza's Avatar
Thanked: 246 Times
Yes, I feel that it's essential to get a break up of the labour charges. I once discovered that a simple replacement of fog lamps was billed as Rs. 450/- by the A.S.S., just for the labour !
mooza is offline   Reply With Quote
Mahindra Thar : Issues & Solutions Rajith Technical Stuff 439 31st December 2017 19:25
Accent / Viva CRDi: Issues & Solutions manishk83 Technical Stuff 61 13th April 2015 14:00
Child safety issues and Solutions sreenidhibr Street Experiences 55 29th April 2013 18:18
