Old 11th June 2010, 09:57   #1411
akshay4587's Avatar
Thanked: 1,684 Times
Originally Posted by suman View Post
Is that how it needs to be done on all Mhawks?
I'd suggest you have this checked out at the service station Akshay as it doesn't sound normal to me.
Not sure,i will check again,in all conditions and gear combinations and revert.
I have noticed this in cousin's Swift,you directly shift to reverse from neutral,the whole car shakes with that jerky sound,shift to first and then reverse,it works fine.
he has been facing this since day 1,A.S.S guys say its normal
I never had such issue with Bolero\Accent.
Old 11th June 2010, 10:19   #1412
Thanked: 253 Times
Originally Posted by akshay4587 View Post
and last night i was having trouble engaging reverse gear,it was giving that grinding sound.
sometimes it does sometimes it doesnot.
Even shift to first gear is pretty notchy at times.
This is certainly not normal i guess.
Akshay, I would say it is not normal!
Seeing how many people seem to have experienced this issue I am led to believe that my Scorpio has been an absolute gem! OK, it's only at 25K kms in nearly four years, but then, that is my usage pattern!
Old 11th June 2010, 10:32   #1413
Thanked: 420 Times
If you are able to slot the 1st / 5th gear not in first try but after de-clutching and applying clutch once more then Tell A.S.S guys there is a problem in Synchromash ring of gear box and then he will think that you know a few things under the hood and look at this problem seriously.
amitk26 is offline   Reply With Quote
Old 11th June 2010, 10:33   #1414
suman's Avatar
Thanked: 257 Times
Anup, it sounds like an issue with the recent crop (Mhawk). A very good friend of mine is moving through his 2nd (non Mhawk) Scorpio with substantial mileage covered on the Odo & I've never heard him crib about this.
(Double) De-clutching is something we used to take pleasure in doing with the Fiats & the Ambis, I haven't felt the need for it in more than a decade now
EDIT:
Ok guys,i guess i found the Culprit.
i had got new foot mats 2 days ago,already had carpet mats,so got rubber mats for the upcoming rainy days.
it was not allowing the clutch to move freely,i removed it,and gear shift is smooth again
So, alls well that ends well! But if the mat was the culprit, shouldn't it have affected all your gear changes (or at least First & Second gear)?
Old 11th June 2010, 10:36   #1415
akshay4587's Avatar
Old 11th June 2010, 10:37   #1416
Ranga's Avatar
Thanked: 43 Times
Nagging problems in M Hawk
Water gets collected some where in the right side portion of the car and creates a strange sound while driving in Monsoons
This problem was reported to Seerish Auto during 2nd service and rectified . This problem has cropped up again ..
Not sure if any one else has gone through this problem
Ranga is offline   Reply With Quote
Old 11th June 2010, 10:41   #1417
Thanked: 420 Times
I would say don't be relaxed and observed for few more days perticularly when you start from cold in morning , Most of the times gear shift being notchy for 1st and 5th is intermittent problem and synchromash was the culprit at least in 1 mHawack I know off.
Old 11th June 2010, 10:52   #1418
Thanked: 145 Times
Anup, it sounds like an issue with the recent crop (Mhawk). A very good friend of mine is moving through his 2nd (non Mhawk) Scorpio with substantial mileage covered on the Odo & I've never heard him crib about this...
As mentioned earlier, I have a 2003 Scorpio which shows similar characteristics. Not sure if that is a one off case. But then, noticing it in a recent MHawk also. Lucky me!
Good! Looks like these mats are more problem than helpful!
HappyWheels is offline   Reply With Quote
Old 11th June 2010, 12:05   #1419
Hey,
Any suggestions on the water leakage in my scorp?
shekharlele is offline   Reply With Quote
Old 11th June 2010, 12:18   #1420
Thanked: 28 Times
Folks,
Windshield water runs down within the body and actually comes out thru the exit near the point where front door bottom meets the quarter panel.Infact i had a issue of rusting near this point as the cladding does not run till the door tip/panel on other side.I have learnt a lesson to use a 1 ft stick to open up the door and pull out dry leaves etc between these holes.No A.S.S also thoroughly cleans it.Suggest all of you to cloasely monitor for rusting in this point.
PRADEEP KUMAR is offline   Reply With Quote
Old 11th June 2010, 13:02   #1421
Thanks Pradeep, I too faced a similar situation a week ago. It was raining heavily and water was getting inside near to the accelerator pedal. I was wondering why, never had this problem before. Now I guess some dry leaves would be preventing the water from the smooth flow through the holes.
Anoop RD is offline   Reply With Quote
Old 11th June 2010, 21:51   #1422
akshay4587's Avatar
Not an issue,but something one should be careful about.
Please Release your seat belts carefully.
Today I just pressed the release Latch and let the belt retract on its own.
The buckle hit the driver side window glass really hard.
a little more force,it can easily break the glass.
akshay4587 is offline   (1) Thanks Reply With Quote
Old 12th June 2010, 11:58   #1423
forbhaskarm's Avatar
Thanked: 30 Times
Default Vibration & noise while over 35 kmph
Hi friends,
My Scorpio 2005 is a non-CRDe model, has done 95K & almost trouble free. Recently, i.e. since yesterday, I noticed weird sound (tak-tak-tak) while driving over 35-40kmph when the steering is either straight or turned left. The sound & its corresponding vibrations travel straight through from the pedals to the steering wheel. Its not an obvious bubbling that one experiences when the tyres need balancing.
Can anyone please shed some more light on what the issue can be?
forbhaskarm is offline   Reply With Quote
Old 13th June 2010, 11:10   #1424
Thanked: 30 Times
Originally Posted by forbhaskarm View Post
Hi friends,
Cum on guys! any useful information would help!
Old 13th June 2010, 11:21   #1425
vigsom's Avatar
Thanked: 601 Times
Hi friends,
Is the noise at regular intervals even on smooth roads or is it off and on especially at low speeds?
Does the noise increase with speed?
Very difficult to diagnose without seeing the car.However,here are some possibilities:
  1. worn steering tie rod end
  2. noise from the strut(strut kit worn)
  3. something stuck in the wheel disc cover - easiest thing is to drive in revers efor say 20-30 metres and the foreign object would come out
Mahindra Thar : Issues & Solutions Rajith Technical Stuff 455 19th June 2018 21:11
Accent / Viva CRDi: Issues & Solutions manishk83 Technical Stuff 61 13th April 2015 14:00
Child safety issues and Solutions sreenidhibr Street Experiences 55 29th April 2013 18:18
