Old 24th May 2011, 13:34   #1
Maibaa's Avatar
Thanked: 38 Times
Default Aftermarket Radiator for Cedia
The radiator in my Brother's Cedia has developed leakages and as per Mitsubishi A.S.S, needs to be replaced. They have to order stock from Japan and will take around 3 weeks for it to be available. The cost quoted was around 11K.
  • Is there any aftermarket Radiator available in the market here in Bangalore that would fit a Cedia? Or it is specific to Cedia?
  • If yes, can I get it replaced at a local garage?
  • Can the radiator be repaired locally?
  • Any other options?
The car was running just fine and one evening stalled and there was smoke from the bonnet. A local mechanic identified the issue as no coolant in the radiator and there was a leak. The car is running normally after water was filled in the radiator. Hence I guess its a gradual leak.
Any specific details/comments on this from the experts? Thanks.
Maibaa is offline   Reply With Quote
Old 24th May 2011, 14:12   #2
Psycho's Avatar
Thanked: 95 Times
Default Re: Aftermarket Radiator for Cedia
How sure are you that there is a leak, a loose fitting radiator cap could also cause the same problems.
A good mech should be able to get a copper core radiator made for you matching the original size of the cedia radiator (note: Am not sure if it is a combined radiator+condensor if so please wait for the original.)
Old 24th May 2011, 14:37   #3
Maibaa's Avatar
Thanked: 38 Times
Its not the case of a loose fitting radiator cap. The service Engineer has confirmed that the radiator has damage both at the top and the bottom. Even the local mechanic was mentioning of the leak.
Now I am still not sure how a radiator get damaged under normal running conditions!
Old 24th May 2011, 15:27   #4
Psycho's Avatar
Thanked: 95 Times
Most of the radiator problems I have seen tend to happen at the press fit joins between the fibre casing and the aluminium body of the radiator(I am facing the same issue too) over a period of time.
Old 24th May 2011, 15:43   #5
gaurav_chopra04's Avatar
Thanked: 534 Times
@Maibaa, I recently sourced aftermarket brake pads for cedia from a Kashmere Gate (Delhi) wholesaler and I believe they have other parts for cedia too. They supply all over the world. here's the link
Car Parts - Spare Parts Car Spare Parts Supplier Auto parts Exporters India
Please note, I gave cash on delivery as I am in delhi itself.
You may press HM and ask for radiator from assembly line vehicle, it shouldn't be a problem.
Also, I wont be astonished if the radiator in cedia is similar to the one in lancer, if not same. Check that option as well.
lastly, most radiator leaks are repairable if they are from top/bottom joints.
gaurav_chopra04 is offline   (2) Thanks Reply With Quote
Old 24th May 2011, 17:58   #6
susan3004's Avatar
Thanked: 120 Times
@gaurav. Can you reveal the price you paid for this radiator?
How many km has your vehicle done, that it has asked for this change?
Can you indicate the location of this shop at Kashmere Gate?
susan3004 is offline   Reply With Quote
Old 24th May 2011, 19:06   #7
Thanked: 534 Times
No, No.. I didnt have any problem with the radiator and neither did I replace it. I just bought front brake pads for cedia from them. And they said, if I need any other part in future, I can contact them. If fact, they called me next day to ask if I want to get them installed installed from their shop in rohini, but I had already got them installed from my local mechanic.
How many km has your vehicle done,?
I have done 70k kms plus on my car with absolute trouble free ownership. Detailed reviews can be found here.
http://www.team-bhp.com/forum/test-d...0k-update.html
Actually they delived pads to nearest metro station and I handed the cash there and then after checking the pads.
And lastly, all credit for link goes to Bhpian Sushrutha, who posted the link on civic maintenance thread.
gaurav_chopra04 is offline   Reply With Quote
Old 24th May 2011, 19:37   #8
Maibaa's Avatar
Thanked: 38 Times
@Gaurav - Thanks for the information. I will get more details from the service engineer and post an update. Meanwhile I will also check the link you provided.
The problem with asking for a radiator from Assembly line vehicle is, there may not be any vehicle on the assembly line given the sales numbers HM is reporting every month. But will check for the same.
Old 24th May 2011, 22:51   #9
Thanked: 534 Times
They will have atleast few cars in the factory, 5-10-15?? getting one radiator shouldnt be an issue...if they really want to.
Old 24th May 2011, 23:11   #10
Maibaa's Avatar
Thanked: 38 Times
In Bangalore, since Southern Motors have shut shop, some of the service engineers have moved to SVR motors which is the only service center in Bangalore. I know some of these people from past interaction during service of my Cedia. Will try to see if there is a possibility of getting one from the factory.
Old 25th May 2011, 01:25   #11
vigsom's Avatar
Thanked: 581 Times
There are any number of radiator repair shops ; and they'll repair your radiator for sure.
However, the Corolla radiator could be a good alternative ,if dimensions more or less match the Cedia's ,given that both engines are almost of the same capacity
Integrated Head Units - Is this the death of the aftermarket for aftermarket HU's ajmat In-Car Entertainment 44 27th July 2011 16:48
Cedia Spirit relaunched as cedia sports basic at Rs. 9,30,000 sidindica The Indian Car Scene 42 4th August 2010 00:16
Need help - Cedia, SX4, Optra or ANHC ? EDIT : The Cedia it is! kartho Sedans 59 23rd November 2009 13:59
Radiator Fan Blues tsk1979 Technical Stuff 14 29th October 2007 17:31
Stuff blocking the radiator chanapli Technical Stuff 0 6th March 2007 18:20
