Old 1st May 2015, 13:45   #781
Thanked: 527 Times
Default Re: VW Polo - Maintenance and Service cost and dos/don'ts
This was even before the SA approached the car. In VW whitefield, they are driving the car inside the workshop even before SA inspection, due to lack of space in the service lounge.
poloman is offline   Reply With Quote
Old 1st May 2015, 15:02   #782
Schoudhury's Avatar
Thanked: 470 Times
Originally Posted by poloman View Post
Gannu, I don't know whether this is a coincidence, last week I had given Polo for bodywork at VW Whitefield. The car was standing in the front of the workshop. When I was syncing with the SA, some one drove the car inside.By the time I went to collect the valuables, SD card in the HU was long gone. This in a matter of 10 minutes. 2 workshop boys were playing with HU but played total ignorance of the matter.
Did you escalate this? Please talk to Ms Kalpana, she is the service manager . Believe me, they take escalations very seriously .
Today it might be a SD card, but some other day it could be something very expensive . So I would request you to bring this matter to their notice .
Schoudhury is offline   Reply With Quote
Old 6th May 2015, 13:07   #783
DudeWithaFiat's Avatar
Thanked: 379 Times
Hi all,
A close friend of mine's 2013 VW Polo 1.2 (Diesel) has one of its tires (front right) is wearing out faster than the other three. I haven't seen it, but he says the wear is even across this tire. What could be wrong? He is taking the car to the service center this weekend. What could be wrong? Alignment or Suspension ?
DudeWithaFiat is offline   Reply With Quote
Old 6th May 2015, 13:11   #784
mr_hardcore's Avatar
Thanked: 69 Times
Strangely, my car's rear parking sensors as well as reverse light has stopped working all of a sudden. Though i have the 7500 Kms periodic checkup is scheduled for later this week, just got curious to know the reason behind this.
mr_hardcore is offline   Reply With Quote
Old 6th May 2015, 13:11   #785
Thanked: 14,305 Times
Originally Posted by DudeWithaFiat View Post
Hi all,
First get the alignment checked from a competent alignment guy.
Did the car hit any pothole at high speed?
Check the fuse or wiring connections. Rat menace IMO.
Old 6th May 2015, 13:13   #786
saket77's Avatar
Thanked: 4,863 Times
Hi all,
Should be an alignment issue. Ask your friend to fit equally & even worn tires on the front before getting the alignment done. If the tires are already worn completely, I suggest replacing them just before aligning. In general, specialized alignment centers do a better job than the ASC.
saket77 is offline   Reply With Quote
Old 6th May 2015, 13:20   #787
Thanked: 379 Times
Thank you Saket, but the problem here is, there are no 'tires', the wear is only on ONE tire in the front (the front right tire). Could it still be because of bad alignment?
Old 6th May 2015, 13:27   #788
saket77's Avatar
Absolutely. Also look if that particular tire is wearing at any specific area, like the outer or the inner edge. This indicates a wrong camber setting as the front wheels are not parallel to each other.
If the car does not holds a straight line on a fairly plain and straight road, then the toe needs adjustment.
I am sure that a good alignment will solve the issue. But before you begin, you need to have tires of even wear to have the best results.
Regards.
Old 6th May 2015, 16:57   #789
Gannu_1's Avatar
Thanked: 10,403 Times
Anurag, the wiring harness of the rear lights and parking aids are concealed within the car and not exposed outside. Fat chance that a rat would chew through them. Could be the fuse.
Gannu_1 is offline   Reply With Quote
Old 18th May 2015, 13:59   #790
Thanked: 69 Times
Got it corrected during the 7500 Km checkup, the wire from connector was ripped off. As per VW, it was chewed by rats but I didn't got any such hints while I was getting it repaired in the service center.
Moreover, it was a tad costly too. The connecting wire (approx 10 cm) was quoted INR 900, tab connector another 270 rs excluding labor charges.
Also, the SA charged me 1500 as labor charges for:
1. Routine Checkup ( a liter of engine oil was also topped up, is it common during the initial Kms or am I the only one who needed to top up the engine oil?)
2. Additional Horn fitment
3. Reverse light and sensor repair
4. Speedometer rattle correction
mr_hardcore is offline   (1) Thanks Reply With Quote
Old 28th May 2015, 16:22   #791
SiddVish's Avatar
Thanked: 22 Times
Question Re: VW Polo - Maintenance and Service cost and dos/don'ts
Hey,
So the RHS headlight on my Polo has fogged up completely.
It's been like this for a good couple of weeks, and I haven't had the time to go to the service centre yet. Is there any DIY fix for this at home?
I have attached pictures of both headlights for comparison.
VW Polo - Maintenance and Service cost and dos/don'ts-img_0001.jpg
VW Polo - Maintenance and Service cost and dos/don'ts-img_0002.jpg
SiddVish is offline   Reply With Quote
Old 28th May 2015, 16:33   #792
Gannu_1's Avatar
Originally Posted by SiddVish View Post
So the RHS headlight on my Polo has fogged up completely. It's been like this for a good couple of weeks, and I haven't had the time to go to the service centre yet. Is there any DIY fix for this at home?
To dry the condensed water inside, remove the headlamp assembly - 2 Torx screws (image), give the headlamp a push from the rear to remove it from the slot below, disconnect the 3 wires (H4 bulb, PY21 bulb, W5W bulb), remove the bulbs and use a heat gun/hair dryer and direct the warm air stream inside through the H4 bulb slot. You will have to leave aside the headlamp for a night to dry the water completely.
Ensure the following after replacing it back:
1. The rubber cover for the H4 bulb is properly seated.
2. The bulb sockets for the PY21 bulb (indicator) and the W5W bulb (parking light) is properly slotted and seated. They turn with an assuring click after the tabs go into the slot.
3. The venting rubber tubes are not clogged.
Were the bulbs changed recently?
Gannu_1 is offline   (2) Thanks Reply With Quote
Old 29th May 2015, 07:45   #793
SiddVish's Avatar
Thanked: 22 Times
Thanks, I shall try this tonight!
Little worried about opening up the headlight though, shouldn't have any warranty issues right? (Considering VW and all) :P
No, the bulbs haven't been changed. Although, I did have a small accident about 6 months ago where the other headlight was replaced. Not sure if this is related though.
Old 29th May 2015, 08:04   #794
Thanked: 869 Times
Ganesh, this has happened to me also late last year. The left side rear parking light stopped working and I had even made an appointment with the service centre to fix it (they indicated charges of Rs 300 to 900 on phone depending on the diagnosis). Luckily I was getting the Maruti repaired at that time and the engineer volunteered to open up the polo panel and see the problem. He did so and it turned out to be a break in the wiring (bulbs were OK). I don't know if rats caused it (unlikely) but snapping is a real possibility.
Kumar R is offline   Reply With Quote
Old 29th May 2015, 08:44   #795
Gannu_1's Avatar
Are you referring to the headlight? The wiring to the headlights are exposed inside the engine bay, easily accessible to rodents. However, the wiring harness of the taillights, parking sensors etc. are concealed inside the car within the plastic trims. It isn't exposed to the outside.
Oh absolutely no. Go ahead. Remember, after the 2 screws are out, you still need to give a push to take the headlight out of its slot.
Honda Civic : Maintenance, Service Costs and Must dos laluks Technical Stuff 9105 18th June 2018 11:48
Maruti's new Service Packages - MCP (Maintenance Cost Protect) for its entire range of cars RavenAvi Technical Stuff 20 15th May 2018 21:46
Car Battery: Dos and Don'ts! evilshantanu Technical Stuff 214 4th May 2018 17:29
