Old 30th January 2006, 04:21   #1
falcon's Avatar
Exclamation Fuel Gauge Problem - Contessa & Esteem
I've been having a problem with my fuel guage for a long time now.
The photo here shows the gauge when the tank is full.
I have checked the float and the guage for any problems, but all seems OK.
Can anyone help solve this please.
Thanks,
Falcon
falcon is offline   Reply With Quote
Old 30th January 2006, 07:51   #2
Thanked: 27,229 Times
Welcome to the club. My car's fuel guage worked fine for a long time. Now the needle just dosen't move up. I checked the fuse, the float, etc. and again, like your case, it seems to be fine. I'm taking it to the garage this week. Let's see what happens.
Aditya is online now   Reply With Quote
Old 30th January 2006, 10:33   #3
navin's Avatar
Thanked: 4,286 Times
I use my odometer to know when to fill fuel.
Old 30th January 2006, 15:35   #4
falcon's Avatar
Hi Aditya,
The Temperature gauge and the Fuel gauge are connected via the same supply line. There is a sort of thermal relay to limit the supply going to the Fuel gauge, so the Fuel gauge does not get pure DC, but pulsating DC.
If your temperature meter is working then supply is not a problem, it could just be a matter of cleaning the contacts of the bimetallic strip feeding the fuel gauge.
Do let me know what the findings are... It will at least give me a pointer as to what I have missed checking.
BTW which garage do you go to ?
I take it to National Garage at Milan Subway, Santacruz. Have not asked them about this fault as yet though...
Falcon
Old 30th January 2006, 15:37   #5
falcon's Avatar
Well, my meter is not totally dead, so as soon as it drops to quarter tank, I top it up...
And even at the quarter mark, the tank still holds about 20 litres of fuel!!!
Old 5th April 2006, 18:51   #6
pramodkumar's Avatar
Thanked: 947 Times
Default Help With the fuel guage
The Fuel Guage In my esteem is not working its a 98 model new shape LX model can any one help???
pramodkumar is online now   Reply With Quote
Old 5th April 2006, 19:43   #7
normally_crazy's Avatar
Thanked: 394 Times
Pramod,
It would be great if you could give us some more info so that we would be able to help.
thanks
normally_crazy is offline   Reply With Quote
Old 5th April 2006, 21:33   #8
Thanked: 947 Times
It dosent move at all. It all started after i installed my new central locking . it had a ignition cutoff function which completly killed my battery as i did not know how to bypass it. The speedo meter is working fine but the temprature guage is not working as well, at times i see it climbing up but it stays below normal. I think its a bad fuse could you tell me how to check and which could be that fuse?????
Old 6th April 2006, 10:15   #9
Rehaan's Avatar
Thanked: 25,043 Times
Threads Merged
cya
R
Old 9th August 2008, 23:03   #10
yogisays0909's Avatar
Thanked: 189 Times
Well i am also facing problem with my fuel gauge Type 1 esteem.
I had tried to repair the float winding, it worked fine for an year but again its gone bad.
Mechanic said to replace the kit i.e. Fuel pump and gauge float. Rs 6k new isnt it killing, dont we get the fuel gauge only?
Needles are working fine the problem rests at the tank end. What to do?
yogisays0909 is offline   Reply With Quote
Old 10th August 2008, 20:18   #11
Thanked: 146 Times
There is some vital info on How Fuel Guages Work on Howstuffworks hope it could help u guys in some way.
Jr Godzilla is offline   Reply With Quote
Old 16th September 2008, 22:11   #12
RuffRyder's Avatar
Unhappy problem with fuel gauge..
Hi All,
Iam also facing the same problem with my fuel gauge..even when the tank is full it shows that the the tank is 1/4..checked with a mech and he told me that it was a long process to correct the same..any thing that i need to check or that i can do before i leave it in a workshop??
RuffRyder is offline   Reply With Quote
Old 18th September 2008, 00:06   #13
Thanked: 189 Times
Originally Posted by RuffRyder View Post
Hi All,
Dude, if the problem is inside the tank, he will advice you to change the whole fuel pump set. Cost 6k for original and nalla about 1.5-2k.
Mind it you dont get the fuel gauge seperate.
My suggestion would be to search for it at some junk ward.
Also donot leave the car at workshop.
There is a winding on a plastic pad like thing, on which the needle moves.
check if there is a cut in the winding, try to repair it.
Old 18th September 2008, 00:51   #14
RuffRyder's Avatar
hmmm..thanx yogisays..will keep that in mind..
Old 12th October 2008, 10:54   #15
Thanked: 205 Times
So let’s understand how most fuel gauges and indicators work.
The gauge consists of two parts:
  • The sender unit
  • The indicator
The sending unit usually uses a float connected to a variable resistor. When the tank is full, the resistor is set to its low resistance value.
As the tank empties, the float drops and the slides a moving contact along the resistor, increasing its resistance, finally reaching its highest value when the tank is empty. In addition, when the resistance is at a certain point, it will also turn on a "low fuel" light on some vehicles.
The indicator unit on the instrument panel is measuring and displaying the amount of electrical current flowing through the sending unit. When the tank level is high and maximum current is flowing, the needle points to "F" indicating a full tank. When the tank is empty and the least current is flowing, the needle points to "E" indicating an empty tank.
The system is fail proof; a fault that opens the electrical circuit causes the indicator to show the tank as being empty rather than full.
Thus you have to start from your float assembly and check the resistor coil at the end of the float for any discontinuity in the coil. Also check all the wiring from the float assy. to the indicator and the ground wire.
Finally you can also eliminate the doubt in the meter by shorting the meter terminals and it will show a full tank and explain the meter is working.
All spares including the float assy. pump are available separately and can be replaced after identifying the cause of the problem.
Mike
Post EDITED since it contained various [FONT], [COLOR] and [SIZE] tags.
Posting with such text formatting should be avoided on Team-BHP as it is inconvenient for members to read post.
Kindly go through Announcements section before proceeding.
Thanking You for your anticipated co-operation
The Team-BHP Support Staff
Miyer is offline   (1) Thanks Reply With Quote
Honda City - Fuel Gauge Problem amit_3306 Technical Stuff 12 19th September 2013 18:36
Fix for Faulty Fuel Gauge-Maruti Esteem 1997 Kamal Technical Stuff 7 7th July 2011 23:56
Alto Fuel Gauge problem ? abhibh Technical Stuff 4 23rd January 2009 16:08
Wagon-R Fuel gauge Problem zoom_vroom Technical Stuff 8 14th July 2008 15:04
Problem with fuel gauge in Esteem frankmehta Technical Stuff 3 14th April 2006 18:05
