Old 31st December 2007, 16:29   #211
Jaggu's Avatar
Thanked: 7,684 Times
I havent tried them yet :(
Old 31st December 2007, 17:01   #212
Thanked: 16 Times
Nice article, i have one question, when I go for long drive I sometimes pour water on the engine to cool it. I do not know wheather it is good. Can any one help me on this?
udaydesai is offline   Reply With Quote
Old 31st December 2007, 20:46   #213
GTO - Touring's Avatar
Thanked: 13 Times
What car!! Why would you do that?
GTO - Touring is offline   Reply With Quote
Old 31st December 2007, 20:51   #214
CrAzY dRiVeR's Avatar
Thanked: 17,026 Times
Dont think this is good.
Any metal heated to high temperatures and cooled 'suddenly' is subjected to a lot of stress.
Old 2nd January 2008, 10:31   #215
Thanked: 16 Times
I have MFPI maruti ZEN 2002, I agree the any metal if hot and cooled by pouring water is subjected to stress, But guide me its just a habit that i pour water on engine and also on radiator.what sort of problem will i come across if i do so. also now I had stop pouring water on engine. I did sak Maruti service person, he said nothing happens. kindly guide me on this.
Old 2nd January 2008, 13:16   #216
androdev's Avatar
Thanked: 1,808 Times
you mean you pour water on the hood panel.. and not on the engine block i hope. pouring on the engine block can affect (short) some electrical connections.
pouring on the hood will affect the paint i am sure.. the metal and the paint layer will contract at different rates due sudden temperature drop.. can result in pealing, oxidation marks in the long run..
in any case, unless your temperature gauge shows the engine overheated u don't need any explicit cooling i think.
androdev is offline   Reply With Quote
Old 2nd January 2008, 18:58   #217
reachmash's Avatar
Default Guideance Required on Exterior Treatment in Bangalore
Please let me know if any of you tried the service here? I am planing to take my Ford 2000 Model for a exterior treatment, as I see lot of swirl marks and if I can see very very tiny holes on the body where paint has eaten up. I love the color of the car which is "Tarmuline Green" as Ford India says other wise the ride is in too good condition.
Please advise what type of detailing stuff that I should go far.
which place in bangalore & who is the contact person (if any)
what kind of treatment should I opt for?
what would be the approx cost?
Thanks in advance
reachmash is offline   Reply With Quote
Old 2nd January 2008, 20:43   #218
vivekiny2k's Avatar
Thanked: 172 Times
I think you picked it seeing old mahindra jeep drivers stopping onc ein a while and filling up radiators.
no, you have a technologically advanced car and you don't need to do any circus, plus you may actually be harming your car.
even if it gets overheated (which needs a trip to the mechanic anyway), putting normal temperature water in radiator will take care of the cooling (provided the water circuit is working)
vivekiny2k is offline   Reply With Quote
Old 27th January 2008, 19:37   #219
moralfibre's Avatar
Thanked: 6,222 Times
The Professional Car Care Centre This is the place for Turtle Wax product range
Guys, does anyone have the updated website address for tpc3 care? The one listed above has gone down.
Old 27th January 2008, 21:15   #220
rr_zen's Avatar
Thanked: 262 Times
Check this one out:
Turtle Wax - Home
rr_zen is offline   Reply With Quote
Old 30th January 2008, 11:29   #221
razor4077's Avatar
Thanked: 252 Times
I recently took my Lancer (black colour) on a drive on the highway and the front (bonnet, bumper, grille) got splattered with insects. This is a common phenomenon that vehicles plying on the highways are subjected to.
Now, I've been having some trouble getting these bug marks off the car. They're somehow stuck to the paint like glue and are not coming off easily. Is there any way to clean up the car without damaging the paintjob?
Also, can any preventive measures be taken when going on the highway to avoid this situation? Maybe some coating on the front that prevents the bugs from sticking?
razor4077 is offline   Reply With Quote
Old 30th January 2008, 11:40   #222
Rudra Sen's Avatar
Thanked: 4,155 Times
Use car shampoo in concentrate form. Add a little water and soak those areas. Keep it for some time and wash it down with a proper shampoo wash. Carry out this process in cool shaded area only.
Nothing you can do to prevent this. Also wash AC condensor with pressurized (light) water. You can be sure of stuck insects there too.
Old 30th January 2008, 12:04   #223
Jaggu's Avatar
Bug splats, to remove Rudra is spot on with his instruction.
To add, earlier your remove easier it will be, if you wait for a week before you wash then its double trouble. Another observation, waxing helps to an extend to reduce the glue effect.
Avoid early morns and twilight hours as much as possible, especially when the route has open fields on either sides which is not practical.
Old 30th January 2008, 17:30   #224
Thanked: 11 Times
The other day I saw the chap at a service station buy 2 sachets of shampoo and proceed to wash the entire car instead of the regular oil soap they use, is this dangerous ?
Also what frequency are you guys using the car shampoo? My daily routine is water wipe and wash.
Old 31st January 2008, 00:18   #225
vivekiny2k's Avatar
Thanked: 172 Times
actually, this claims to help. not sure if you can find something similar in india though.
Rain-X: Bug & Tar Protective Shield
I have a can of this (or something similar), and I always remember to put it only after a long drive when I see bugs on the front bumper .
Car Detailing and Cleaning - 3M Car Care (Koramangala, Bangalore) nareshtrao Bangalore 26 16th September 2017 22:38
