Old 5th January 2011, 00:25   #4021
Garipagol's Avatar
Thanked: 7 Times
Red face EBay India has started selling some good brands
Mothers, Megs, Carrand, Turtlewax, Lexol etc are now available thru Ebay India. But the price is three times of USA. Good selection of Microfibre cloths, cleaning brushes, leather products, foam applicators etc are being offered. Folks who do not have access to US can look at a selective assortment (though expensive). If you plunge in please read the review of the product first if your are not sure !! Megs Clay kit is available for Rs. 1900 or so.
Rgds
Garipagol is offline   Reply With Quote
Old 5th January 2011, 09:41   #4022
vasoo's Avatar
Thanked: 207 Times
Default re: A superb Car cleaning, polishing & detailing guide
If you dont have access to US stores directly, it is always better to order from SYW. IK found them to offer the best prices amongh all the overseas shopping sites. And you can of course order anything from Amazon. Bestbuy etc. I have been a regular user of that portal especially for items that are difficult to bring from abroad such as liquids, heavy/bulky items etc.
vasoo is offline   Reply With Quote
Old 5th January 2011, 11:15   #4023
rk_sans's Avatar
Thanked: 783 Times
I was going thru ebay and found this polisher.
Has anyone have any info about this ? anybody has tried it, seen it, heard it, etc ?
eBay India: SKIL CAR / METAL POLISHER,1300w+2 handle+Velcro+Sponge (item 130466088042 end time 14-Jan-2011 17:37:01 IST)
rk_sans is offline   Reply With Quote
Old 5th January 2011, 12:56   #4024
Thanked: 35 Times
It is a China polisher. My experience with these (chinese machines) was the speed controllers burnt out too quickly. Also from the specs of the machine, I personally prefer the Makita 9227C as its speed starts from 600 rpm. If you are an experienced polisher than 1000 rpm should be no problem for you. The advantage with this polisher is they have an India office, which I found out. So servicing issues should not be there.
ThinkBig is offline   Reply With Quote
Old 5th January 2011, 14:20   #4025
bj96's Avatar
Thanked: 130 Times
Originally Posted by ThinkBig View Post
It is a China polisher. My experience with these (chinese machines) ...
I think Skil is a pretty respectable company and they are part of Bosch. Machine should be good.
-BJ
bj96 is offline   Reply With Quote
Old 5th January 2011, 15:01   #4026
VMC
Thanked: 18 Times
As per my knowledge gained from the detailing wizards in BLR(mkh and nirmaljustdoit) always rely on a good polisher preferable a DA polisher.
You can PM them to find out what they use. The ones they use are around 30K i guess. This is a huge difference.
I also had a similar question and link in the same thread.
BottomLine:- A good DA is a requirement if you dont not want to spoil your paint and get a very good sparkling mirror like finish like the below
Welcome to Facebook
VMC is offline   Reply With Quote
Old 5th January 2011, 15:05   #4027
Shan2nu's Avatar
Thanked: 89 Times
Damn, from some angles that Acura looks like it's got a chrome finish. I bet he never gets caught for speeding, coz a radar would just bounce off that car. LOL
But i feel the darker car shades usually give out the best results due to higher contrast levels.
Shan2nu
Old 5th January 2011, 16:40   #4028
Garipagol's Avatar
Thanked: 7 Times
This is a rotary/circular polisher.
You will find the specs here :
http://www.skil.co.in/skil/l0/produc...er%20Guide.pdf
The polishing plate does not have hook & loop attachment - many circular polishers do not. So, as far as polishing pads are concerned you will need ones which directly screw on to the spindle. You will get a generic pad with the unit. Look at the Edge pads in Autogeek to get an idea about pads for this unit. If you have not used polishers earlier a DA unit is safer choice. As such the product looks OK and should deliver good results in capable hands.
Rgds
Old 5th January 2011, 16:48   #4029
Thanked: 164 Times
RK_Sans - Not sure of this model, it looks to be a rotary with quite a competitive price. Check the reviews of this machine on the net & note that its a rotary,not a DA, hence risk of burning the paint would be there. Please also check the backing plate details to see which type & makes of pads that can be used with it. VMC has correctly pointed out that a proper DA is the best if you are planning a DIY kind of paint correction. If starting out with a rotary, better to get some second hand painted panels or be ready to repaint your existing panels while on the learning curve !
nirmaljusdoit is offline   Reply With Quote
Old 5th January 2011, 18:58   #4030
sohail99's Avatar
Thanked: 200 Times
I have a Clif Rotary polisher and its quite decent!!
Though it starts at 800RPM, you can actually vary the speed by pressure!
I use it mostly to work on thin panels like the A,B and C pillars and some curvy parts of the bumpers etc.
With it I was easily able to remove 1200grit sanding scratches with M105 and a 4" orange pad!
I kinda like the rotary as it makes less noise and vibration and works really-really quick!!
Rgds
I have various backing plates for my rotary polisher(hook and loop) a 3" one and a 5" one!
Both take normal pads easily!
EDGE uses double sided pads(more economical), but since in a edge pad, the plate is kinda in between the pad, it might be risky if you apply some pressure where the edge of the plate is, inside the pad.
I'd use Edge pads for mostly straight panels, like non-contoured bonnet, trunk, doors etc.
sohail99 is offline   Reply With Quote
Old 5th January 2011, 21:05   #4031
blackfire_9's Avatar
Thanked: 187 Times
^^ Sohail, what's your polisher's model number? I was in Chandni Chowk a few days back & inquired on the prices of DeWalt. I was given a quote of 3.5K without any bargain & the device looked the same as yours. I am expected to go back there this coming weekend & would like to see if it is indeed a different model or the same one (in which case, the prices may have been slashed heavily ).
Drive safe.
Old 5th January 2011, 21:12   #4032
Thanked: 40 Times
Nirmal,
For academic's sake,
what does that the DA do, that the rotary doesn't or can't do?
Please revert.
nandans2005 is offline   Reply With Quote
Old 5th January 2011, 21:33   #4033
sohail99's Avatar
Thanked: 200 Times
^ I feel that with a DA, you can finish better on a soft paint!
But a rotary cuts through oxidation and hazed surface super fast!(but if one isn't experienced with a rotary, a rotary polisher can even burn through the clear coat if not used properly!)
If I'm given a abused finish, I'd compound and finish with a rotary and jewel with a DA.
Basically, if you're starting machine polishing, never go beyond a dual action polisher!
As you become more experienced, you can step into rotary polishers and then finally perfect them!
But for ppl maintaining their own cars, a rotary is generally not needed.
Its mostly for detailers who have to do each of the steps of compounding and finishing, fast and with perfection!
Drive safe.
My DA polisher is DeWalt DW443 - DW443 6" Right Angle Random Orbit Sander with Electronic Variable Speed | DEWALT Tools
Old 5th January 2011, 21:38   #4034
Ravi Yadav's Avatar
Bought a bottle of Amway Silicone glaze. Now does one need to apply a wax after applying Amway silicon Glaze.
Ravi Yadav is offline   Reply With Quote
Old 5th January 2011, 22:54   #4035
Thanked: 164 Times
Default Re: EBay India has started selling some good brands
Rgds
It is similar to showyourworld you order here and they will get it from US and deliver you so the price is so high, Megs clay kit could be bought at 1600 from shopyourworld.
shamanth is offline   Reply With Quote
Car Detailing and Cleaning - 3M Car Care (Koramangala, Bangalore) nareshtrao Bangalore 27 19th June 2018 09:32
