Old 23rd April 2009, 14:18   #496
Rudra Sen's Avatar
Thanked: 3,697 Times
So it's only a mark now, I presume.
Get WAXPOL rubbing compound (it comes in small can too) from auto paint shop.
Take some cotton wool and soak it in water. Squeeze out water from it.
Take rubbing compound (no more than a fingertip full) and put on that cotton. Slowly but firmly rub that area in a circular motion.
Do not put too much of pressure. Mark will go.
Apply some wax for that spot. Wipe it with cotton waste (you get them in paint shop too).
Apply wax for the whole roof to get that uniform shine.
Old 23rd April 2009, 14:24   #497
sharma_sanjeevi's Avatar
Thanked: 62 Times
Thanks Rudra Sir for the valuable suggestion, i will try this out and will update on the result.
I have a Formula 1 Rubbing compund also which i use, can i use that ?, if not then i will buy a WAXPOL rubbing compund, as the auto paint shop is near to my house.
regards,
Sanjeev
sharma_sanjeevi is offline   Reply With Quote
Old 23rd April 2009, 14:28   #498
Rudra Sen's Avatar
Formula 1 Rubbing compound should do the trick. Try it out before buying WAXPOL.
Old 23rd April 2009, 14:39   #499
dockap's Avatar
Thanked: 371 Times
use paint thinner and then rubbing compound and polish
dockap is offline   Reply With Quote
Old 23rd April 2009, 14:43   #500
Thanked: 62 Times
Thanks, i will do the same and revert on the result tomorrow, lets hope it goes off.
Old 23rd April 2009, 15:58   #501
marlinspike's Avatar
not a good idea, may end up thinning the paint instead. may be soaking the spot with some petrol would loosen it up. the wax pol could fix the rest.
marlinspike is offline   Reply With Quote
Old 23rd April 2009, 16:00   #502
Thanked: 62 Times
@dockap & marlinspike,
I think the paint thinner may harm the paint, what you say ?
I will try, what Rudra Sir has recommended, lets see what is the outcome.
Thanks to both of you for your responses.
Old 23rd April 2009, 16:30   #503
Roy.S's Avatar
Thanked: 40 Times
No, No!! No thinner under any circumstances.
Originally Posted by sharma_sanjeevi View Post
I will be applying the wax on the car this Saturday as it is a holiday for me Hope will have a good exercise.
Prepare for a Sunday of nursing your aching biceps. But its worth it!
Roy.S is offline   Reply With Quote
Old 23rd April 2009, 16:43   #504
Thanked: 62 Times
Thanks Mate, ya really gearing up myself for the exercise
Old 23rd April 2009, 16:46   #505
dockap's Avatar
Thanked: 371 Times
try the rubbing compound and if its dosent work use thinner small amount it should remove the stain in 10 secs then apply polish i have used thinner on my car dont worry
Old 23rd April 2009, 17:00   #506
Thanked: 62 Times
If nothing works, i will try that out also, thanks mate.
Old 23rd April 2009, 21:45   #507
Thanked: 62 Times
Default Pic of the Cement Clot
Attached here is the picture of the Cement Clot that is there on the Roof of My M800, i think the picture will be helpful to describe the thing.
I clicked the picture today.
Old 23rd April 2009, 23:03   #508
Roy.S's Avatar
Thanked: 40 Times
Ouch! This is not good. I think your only option now is to very gently chip it away. Some scratches are inevitable as you reach the metal. Trying to soak it in water will only aid the curing process and harden the cement.
This will leave a mark of some sort, but nothing a good rub with some wax will not get rid of - in time. I speak from experience. The same thing happened to my silver M800. Only this was larger. Almost palm sized. Few months later, I could not even locate the mark. My service station guy used some generic wax polish.
Old 24th April 2009, 10:10   #509
Thanked: 62 Times
Ok, i will try to chip it tomorrow, lets hope everything goes well.
You are right, that it some scratches are inevitable, as Rudra Sir also suggested will try out rubbing it up after removing the cement.
Old 25th April 2009, 20:43   #510
NOTORIOUS's Avatar
Thanked: 85 Times
Rudra Sir , I want to buy wax for my white verna. which one should i buy
Turtle Wax or Formula1 ??????
NOTORIOUS is offline   Reply With Quote
Car Detailing and Cleaning - 3M Car Care (Koramangala, Bangalore) nareshtrao Bangalore 25 25th October 2016 15:12
Cleaning, Polishing, Painting, etc - Carz Spa (Mangalore, KA) james Other Cities 6 20th December 2013 10:21
