Old 25th April 2012, 09:42   #5731
KkVaidya's Avatar
Thanked: 271 Times
Originally Posted by sudipta View Post
Some pictures taken today. I was not able to capture the close paint details. Let me know if there is a specific way that I need to take the pictures.
Can we see a picture with the camera close to a panel eg. put the camera atop the bonnet & take a picture of the paint sheen on the bonnet.
I would also like to see the paint for any swirl marks. Flash a light on the paint or better take it out in daylight and let the sun flash the paint to check the reflectance.
KkVaidya is offline   (1) Thanks Reply With Quote
Old 26th April 2012, 10:25   #5732
darthvader's Avatar
Hi guys, how do you clean/wash your Jopasu duster? I've had mine for about a month now, and I use it every morning to dust my car. I think the duster is saturated with dust now.
Also, does anyone know what has happened to Carpolish.in? They are not reachable via phone, and their website has nothing to offer. It has been this way for over a week. I couldn't find anything on their Ebay store either. Need a refill of Optimum Opti Clean, and its about a hundred and twenty costlier on EBay from another seller.
I was also thinking of getting a Quixx Scratch Remover -- I've heard its good. Has anyone here used it?
darthvader is offline   Reply With Quote
Old 26th April 2012, 10:52   #5733
comfortablynumb's Avatar
Thanked: 999 Times
Prepare a bucket full of water + mild detergent mix. Leave the duster in it overnight. Squeeze the threads softly to remove water. Dry in shade. Once it's dry, shake to separate the threads in case they are stuck to each other. Done.
Cheers,
Vikram
comfortablynumb is online now   Reply With Quote
Old 26th April 2012, 10:58   #5734
darthvader's Avatar
Thanks comfortablynumb . What detergent do you use? For microfiber, I have used Ezee (which works will).
Old 26th April 2012, 11:01   #5735
Thanked: 999 Times
I use half a small spoonful of whatever is handy - Nirma, Surf, Sunsilk shampoo etc - in 1 bucket of water. But Ezee should be good too. Only thing to keep in mind is that the water + detergent mix shouldn't be too concentrated.
Cheers,
Vikram
Old 26th April 2012, 13:31   #5736
Cheers,
Vikram
Don't use fabric softeners like Ezee on MF cloths. Use any of the mild detergents like hand wash soap or amway sa8 etc.
icecoolsam is offline   Reply With Quote
Old 26th April 2012, 15:12   #5737
darthvader's Avatar
Ezee was recommended by Sanjay (of Bringing Best, where I got the Eurow MF from). It seems to have worked well on the two occasions that I did wash MF with. Why do you disagree?
By the way, I did try hand wash soap (though not Amway SA8), and it did not work. Kanpur dirt is very stubborn
Old 26th April 2012, 15:36   #5738
Rachit.K.Dogra's Avatar
Thanked: 730 Times
I had ordered Chemical Guys Black Light and V07 Paint sealant from USA.
http://www.team-bhp.com/forum/test-d...ml#post2739877
These are the results after 1 layer of Black Light, 1 layer of Formula1 Wax and 1 layer of V07 paint sealent.
http://www.team-bhp.com/forum/test-d...ml#post2753907
I am not very sure of how to use this V07 paint sealant. Anybody with any suggestions..
Rachit.K.Dogra is offline   Reply With Quote
Old 26th April 2012, 16:00   #5739
Thad E Ginathom's Avatar
Thanked: 8,337 Times
If it contains fabric softener*, then that would be because manufacturers of microfibre cloths warn, often on the packet, that fabric softener destroys the effectiveness.
Otherwise, as I posted recently, don't treat microfibre as delicate, it isn't. This is not silk or wool, it is a tough synthetic fibre.
I just chuck my mf cloths in the pile, and they get washed by the maid. I guess she uses Pril, or some other solid washing soap. This goes for the household cloths as well as the car cloths.
This from the e-cloths site:
You can wash as low as 30 degrees C, but most e-cloths can be machine washed at 90°C or boil washed. There are exceptions and all cloths have washing instructions on the label, except for certain lightweight cloths where the cloth’s smear-free performance would be affected by the addition of a stitched edge and label.
For all cloths:
  • A thorough rinse is often enough for day-to-day use.
  • To ensure e-cloths perform at their best, we recommend machine washing, using a small amount of washing powder.
  • Tumble or hang dry.
  • DO NOT use bleach or conditioner. Bleach breaks down the fibres and conditioners will block them.
  • Colour may run - initial washes must be separate at 60c.
Notes:
If fabric conditioner is used by mistake, rewash with a little detergent.
As cloths age, some staining will not come out. Some types of dirt contain a pigment which stains any cloth. If the cloth has been washed properly, it will actually be clean. Repeated washes will gradually reduce marks.
Whilst a standard bleach will damage tea towels and cloths, you can use a natural bleach, such as Ecover.
Hey, even I didn't know you can boil them!
E-cloths make very expensive microfibre stuff. Whilst I suspect that all microfibre care would be much the same, if your cloth has a wash label that says anything different, then please take its word for it, not mine!
*it does, I checked their site.
Old 26th April 2012, 21:01   #5740
torquecurve's Avatar
Thanked: 654 Times
I normally wash my MF with the regular load in the Washing Machine. It does not seem to have any negative effect.
EZee AFAIK does not have fabric softener, rather it is a very mild soap.
torquecurve is online now   Reply With Quote
Old 26th April 2012, 21:21   #5741
Thanked: 164 Times
Using normal detergents like Surf, Ariel etc is a sure shot way of destroying your microfiber towels. The powder in them destroy the threads and the weaves over time.
What i recommend from experience is using a proper liquid detergent to wash your MF's. A good brand is Amway SA8.
If you have stubborn stains, like brake dust, grease etc , soak them overnight in a higher concentrated solution. Lightly rub them together with water added the next day and exclusively wash well. Do not wash along with cotton as fibres from cotton will get stuck in the MF fibres and when you are wiping the glass etc, they will get deposited.
nirmaljusdoit is offline   Reply With Quote
Old 26th April 2012, 21:31   #5742
Thanked: 139 Times
I used this and results are satisfactory as per my expectations. Just another option -
http://www.team-bhp.com/forum/modifi...ml#post2568851 (Jopasu Car Duster - A mini review)
Most of India have this same problem. Please share, what is so unique about Kanpur dirt.
AvonA7 is offline   Reply With Quote
Old 26th April 2012, 21:55   #5743
Originally Posted by torquecurve View Post
...EZee AFAIK does not have fabric softener, rather it is a very mild soap.
It is on the Godrej/Ezee site. Honest!
Do they destroy your clothes? Do they put something abrasive in the Indian formulations? I know this (and so might you, of course, if you have lived abroad): the stuff sold under same brand names in UK is vastly better at getting clothes clean than the stuff sold here, so nothing would surprise me.
PS... just read this on that same Ezee site, so, according to those guys, it might be Soda doing the damage.
Old 26th April 2012, 23:03   #5744
Thanked: 164 Times
Yes, it could be the soda in it along with some abrasives. That must be doing the damage.
I have tried washing MF's using the normal detergents and then using Amway SA8. The normal detergents turned the MFs unusable within 15 washes. (rough and thin) There is simply nothing like SA 8. Some of my MFs have been through 150 + washes and still are alive and well, though not being used on paint but on glass, tires, interior etc.
I have found almost all the brands to be equally bad - Surf, Ariel, Henkel etc.
Old 27th April 2012, 00:15   #5745
I am looking for some expert advice on how often should the car be washed during monsoon rains . I have been following the jopasu plus ONR routine so far but the recent rains in Bangalore has left my White Vento completely muddy. I washed the car using two bucket method yesterday and it took almost close to 45 minutes for a complete wash and dry with MF. Now I am back to square one today and the car is in same state and no energy left to even look at it.
Is it ok to let the car take all the abuse and then wash it just once a week even if it rains daily ?
Please let me know some innovative ways if there are any which can save some time spent on keeping the car in good shape for next couple of months .
I think I would be forced to hire a car cleaner unless there is some shorter way out.
Car Detailing and Cleaning - 3M Car Care (Koramangala, Bangalore) nareshtrao Bangalore 27 19th June 2018 09:32
Copyright İ2000 - 2018, Team-BHP.com
