Old 7th May 2009, 16:39   #601
Thanked: 31 Times
Originally Posted by NOTORIOUS View Post
Tell me how to maintain dashboard of my verna. i have cleaned it with moist cloth and now it has lots of white stains all over it.
EDIT : Can i use stp sun of gun on it ???
Hyundai cars have this problem as they have granular dash boards. I had it with Getz. You can use cleaner which can be used on leather or vinyl or anything which is little oily based. Don't use Mobil oil which generally garage uses. It smells and dust sticks to it.
aka_iitd is offline   Reply With Quote
Old 7th May 2009, 21:31   #602
NOTORIOUS's Avatar
Thanked: 89 Times
So , can i use stp sun of gun on it ????
NOTORIOUS is offline   Reply With Quote
Old 7th May 2009, 22:33   #603
Hi everybody
Thanks Vahan for your comments. However FYI I found out on my car the TASS goes all the way to the metal at the places dented and scratched and puts the lambi etc but does not remove the entire paint on the panel i.e the door for example and then paints the part, bakes it and then puts another coat of lacqure on the entire panel.
At the TASS they were offering an Underbody treatment by Wruth called Stone Guard for 3000/- incl Taxes. Is this good ? comments please as i had done an earlier treatment where they applied this fiber on the underbody and it fell off. So before the rains if the Guru's on this forum can suggest some thing
I have Tubeless tyres on original Steel rims, should i have the rims painted or treated with any antirust. I read something about this on some TBHP forum. where i dont remeber now
Well waiting for your comments, fellow bhpians
NandanRM is offline   Reply With Quote
Old 8th May 2009, 00:55   #604
Roy.S's Avatar
Thanked: 109 Times
Originally Posted by DWind View Post
...but would need help in removal of paint on plastic areas like windshield beading and OVRM and bumpers.....
I think diesel would work for this. Thinner surely would, but I try not to use it as far as possible.
Yes you can.
I got good results with 3M's vinyl & plastic protector (not sure exactly what its called) which cost me Rs 165 but does not seem to be available anymore.
Roy.S is offline   Reply With Quote
Old 8th May 2009, 01:33   #605
johnda's Avatar
Thanked: 11 Times
Any dashboard and interior Spray will help; jus that some cause the other extreme with the Dashboard shinning like glass and a HUGE glare that can blind you. I've used the Armor spray meant for plastic and rubber and that did wonders.
johnda is offline   Reply With Quote
Old 8th May 2009, 12:35   #606
Default Queries
Friends - a few queries
  • Somewhere in this thread it was advised not to put on car cover immediately when the engine is still hot. What happens if cover is put on imdtly after the journey & engine is still hot? what are the consequences? am asking as I'm doing it currently
  • While I do DIY waxing with spongy applicatior - is it to be done very lightly or by applying force & repeatedly rubbing in circular motion?
VahanPujari is offline   Reply With Quote
Old 8th May 2009, 12:48   #607
Rudra Sen's Avatar
Thanked: 4,287 Times
Originally Posted by VahanPujari View Post
Somewhere in this thread it was advised not to put on car cover immediately when the engine is still hot. What happens if cover is put on imdtly after the journey & engine is still hot? what are the consequences? am asking as I'm doing it currently]
Heat from the engine reacts with surface moisture and create patches on the paint. Same applies (strongly) when you put cover on rain soaked car.
Youíre from Bombay and rain is really heavy there. Itís also not possible to wipe the car before putting the cover. Especially, if youíre parking your car outside. I would urge you to find a temporary parking during the monsoon.
Light circular motion only. Idea is to spread the wax evenly.
Old 8th May 2009, 15:08   #608
akbaree's Avatar
Thanked: 50 Times
Couple of weeks back I undertook my first DIY Car Care exercise. The products I used were
Waxpol Shampoo,
Waxpol Carnauba Wax ,
Waxpol Tyre Cleaner,
3M Dashboard/Vinyl Cleaner
The results were amazing. I am now hooked to DIY.
akbaree, come down to Indiranagar, CMH Road. You'll find MK Ahmed Retail. It's opposite Max Muller Bhaban. Go to first floor and pick up what you need.
Thanks Rudra, for the information. I will be going to this place tomorrow as I still have some pending items to complete my inventory of car care products.
I have a few follow up questions.
  1. I used 3M Dashboard/Vinyl conditioner. But I could found it with great difficulty. If I have to use some other brand, which one would you recommend?
  2. I am not sure about the Dashboard/Vinyl conditioner's action. Does it clean as well? On the pack it is mentioned that clean the surface before applying. I think it is not for cleaning. How do I clean the dashboard before applying conditioner. Just with a wet cloth?
  3. What do I use for the extensive plastic work that I have in my Adventure on the outside - bumpers, side bars, and other plastic cladding?
  4. I will be buying the Sonax shampoo tomorrow as recommended in earlier posts. If the recommendation has changed please let me know. I was not so much impressed by Waxpol car shampoo. But that may be because I washed my car with it when it was dirty.
  5. I have bought the 3M as well as Waxpol glass cleaner. I am not sure how to apply them. Any suggestions.
Sorry for the long list of questions.
akbaree is offline   Reply With Quote
Old 8th May 2009, 15:24   #609
invincible7's Avatar
Thanked: 154 Times
Ok here is my query..
How good are the products from Eagle One stable.
I am looking for Car Polish...
invincible7 is offline   Reply With Quote
Old 8th May 2009, 19:51   #610
bottle's Avatar
Thanked: 137 Times
having a black car shows up the dust easily so picked this up for occasional dusting
bottle is offline   Reply With Quote
Old 8th May 2009, 22:27   #611
sharma_sanjeevi's Avatar
Thanked: 77 Times
Rudra Sir,
As we are in Mumbai & the monsoon is about to start & i am Parking both my cars (M-800 & Swift Dzire) outside, we dont have stilt parking in our society.
In this regard, wanted to know that when i cover both the cars in the night & in the morning i find mist all over & inside the cover of both the cars, is there any harm caused to the paint when the mist evaporates & the temparature rises as the day progresses ?
Should the car cover be removed in the night itself to avoid the morning mist on the car coming in contact with direct sunlight?
Many of the fellow members may also be encountering the situation who are from Mumbai.
Require your valuable suggestions in this regard.
sharma_sanjeevi is offline   Reply With Quote
Old 8th May 2009, 22:29   #612
Vid6639's Avatar
Thanked: 20,825 Times
Just got my Lancer back after the 3M surface refinement job. Car looks spanking new. Have been in the basement parking lot for the past one hour looking at my reflection on the car. It's stunning. The car looks brand new from the showroom even after 9 years.
Old 8th May 2009, 22:44   #613
Roy.S's Avatar
Thanked: 109 Times
How does one really clean fabric seats? I know what is available commercially and have used them all with varying results. But how do you get rid or that vague sweaty smell that always lingers in your car during summer? I don't like to have the a/c on all the time since I prefer to breathe fresh air (or whatever passes for it in Bangalore). This, however, makes me sweat so much that I might just be able to power a small hydroelectric plant.
Should I just pull the entire seat out, wash it with water and leave it in the sun till dry? I did this with the head restraints and it worked pretty well.
Old 8th May 2009, 23:30   #614
Shakensoul's Avatar
Thanked: 222 Times
Hey bottle,
Is it effective ? Where did u pick it up from and price ?
Shakensoul is offline   Reply With Quote
Old 8th May 2009, 23:42   #615
amarprusty's Avatar
Default Amway Car Care
Amway Car Wash (Rs 200)+Silicone Glaze Polish (Rs 400)+Leather Vinyl Interior Polish (Rs 250)
These are doing wonders to my Red Palio MJD's 1st birthday it is like new out of showroom again.
At the pricing Amway car care products are value for money as comapared to other higher brands.
amarprusty is offline   Reply With Quote
Car Detailing and Cleaning - 3M Car Care (Koramangala, Bangalore) nareshtrao Bangalore 27 19th June 2018 09:32
