Old 6th November 2012, 19:02   #6451
aargee's Avatar
Thanked: 2,125 Times
Originally Posted by el lobo 6061 View Post
Wrong, sealant is applied first and followed by carnauba based wax as LSP
Shoots!!! I was under the impression that sealant is followed by wax.
protect surface for longer and luster is nearly(85%) same as carnauba based wax
If sealant is same as wax, then what makes sealant to outstand than wax?
Sealant's are more than enough, only if you seek an extra layer, carnauba wax is LSP after sealant
Didn't quite understand
Collinte 476 will drain you hands after finishing applying & buffing it off. Its very hard wax and takes a lot of elbow grease to work.
That I don't care, I use GPO 12 CE
Old 7th November 2012, 00:55   #6452
Thad E Ginathom's Avatar
Thanked: 7,483 Times
@Rachit: I would suggest, spray WD40 liberally on the alloys.
Noooooooo!
For gods sake keep it away from brake pads, hubs, disks etc.
In fact, as that must be almost impossible to guarantee, just keep it away from the wheels altogether.
Lubricating your brakes is really a lousy idea, especially with a Super-Lubricant.
Thad E Ginathom is offline   (1) Thanks Reply With Quote
Old 7th November 2012, 23:33   #6453
el lobo 6061's Avatar
Thanked: 984 Times
New Updates :
1. Optimum No Rinse Wash & Wax
Comes with carnauba wax pre-mixed, which means more gloss. Green colored liquid. Small pic below. To be launched in Dec'12 and expected in stock by Eco Car Care in Mar'13.
Source: Eco Car Care.
Optimum No Rinse(Blue) will sell along with the new(Green) one.
Hoping to get one when its available in here since I didn't pick any supplies of ONR.
2. Polishing and Waxing With Meguiar's® DA Power System
An alternate to DA, which works with a corded drill machine. Could be a good option with one machine can be used for two purpose. Saves on cost. Should be launched soon.
Sealant is synthetic and more resistant to chemicals which makes it last more whereas carnauba based wax don't. Only thing sealant lose out on is luster which is nearly 85% of carnauba based wax but longer water beading & protection makes up to it.
Sealant does the job pretty well. But someone needs that extra luster so he wishes to do an extra coat of carnauba based wax over sealant. Good if you want to work your muscles out and want that perfect finish. But even a single coat of sealant is more than enough.
Good for you. How much did it cost & price of pads involved?
el lobo 6061 is offline   (2) Thanks Reply With Quote
Old 8th November 2012, 08:04   #6454
aargee's Avatar
Does it help to vary the RPM's?
Ok, so in that case, shouldn't the sealant be applied as last layer over the wax? So that the protection is more from dust pollution, grimes & tar? Ideally making difficult to penetrate to wax & then to the paint?
Only thing sealant lose...water beading
Quite right; again didn't get that protection part
Though I might've been using the wrong way, the sealant's protection isn't that visible :(
Good enough to run me bankrupt, borrow money to pay EMI & empty the wallet 2 days ago; EXCLUDING the pads
Old 10th November 2012, 18:37   #6455
Thanked: 984 Times
No, since you cannot vary RPM of drill machine. But it makes small circles within a bigger circles, just like a DA polisher.
Most of the folks don't use wax, just sealant. Since sealant out matches traditional carnauba based wax, two coats of sealant will do a better job than a wax over sealant or vice versa.
Since sealant offer better resistance to chemicals, so it gives better protection in comparison to carnauba based wax.
Which sealant are you using? I currently employ Blackfire Wet Diamond AFPP, which is way superior to Collinite 915 which I was previously using.
Still didn't get the price which emptied your wallet.
Hope I have answered all your queries and I'm no way advocating for sealant against carnauba based wax. Just my opinion after using BFWD & 915.
el lobo 6061 is offline   Reply With Quote
Old 10th November 2012, 23:11   #6456
blackasta's Avatar
Thanked: 989 Times
This one looks nice and should be easy on the pockets at around $60. Just need a good drill. I was anyway thinking of buying a drill - so if this one comes out in this year, might as well just get the drill and DA powersystem
blackasta is online now   Reply With Quote
Old 11th November 2012, 07:24   #6457
HighOctane's Avatar
Thanked: 176 Times
I have using wax on all my vehicles for past 10 years and never used sealants.
Can you please list out some good Sealants other than Blackfire Wet Diamond ?
HighOctane is offline   Reply With Quote
Old 11th November 2012, 20:20   #6458
Thanked: 984 Times
The two best that are same/superior to BFWD are
1. Wolfgang Deep Gloss Paint Sealant 3.0
2. Detailer’s Pro Series Poli-Coat Paint Sealant
Wolfgang gives more gloss, even better than BFWD. The problem is sourcing them in India. Earlier Sanjay at BBImpex imported BFWD, which made it easy to source it but due to higher cost of sealant compared to wax, there were less customer. So he wont be stocking more of it.
But do give paint sealant a try, you did never go back to good old school wax.
el lobo 6061 is offline   (1) Thanks Reply With Quote
Old 12th November 2012, 11:43   #6459
riturajsharma19's Avatar
Thanked: 59 Times
Any opinions on Optimum Opti Coat? Apparently, this one offers permanent paint protection and claims to not require frequent application unlike waxes. Have a look -
http://www.autogeek.net/optimum-opti-coat.html
Anyone who has used this product, please share your views.
riturajsharma19 is offline   Reply With Quote
Old 12th November 2012, 16:50   #6460
arup.misra's Avatar
Thanked: 293 Times
Agree mate, but the problem is sourcing the sealants in India. Autogeek won't ship for orders below USD100. Haven't gone up to shipping page so don't know what they'll charge.
Amazon will not ship here. So what are our options.
Sanjay mentioned Duragloss any idea about it?
arup.misra is offline   Reply With Quote
Old 12th November 2012, 19:20   #6461
Please suggest me, weather should I get a paint job done or any scratch removal product can be beneficial.
cheers
lastmanstanding is offline   Reply With Quote
Old 12th November 2012, 20:28   #6462
That is a job for paint. the scratch is quite wide and has removed the colour coat (and the clear top coat if there is one). Nothing can "remove" a scratch like that.
It has not gone through to the metal. though, so it is not going to rust while you think about it.
I have a similar on my Polo. I even have the imported factory-colour-matched touch-up pens. Now all I need to get is A Round-To-It!
Old 13th November 2012, 09:36   #6463
sohail99's Avatar
Thanked: 163 Times
cheers
If the scratch catches your fingernail, its too deep to be removed by polishing / compounding!
sohail99 is offline   Reply With Quote
Old 13th November 2012, 12:30   #6464
Thanked: 984 Times
Reducing scratches to almost nil.
I wanted to share these pics with you all since I last finished detailing my black Vento on 28 Oct'12.
Due to the kids in my society(which one doesn't have), they had caused a lot of scratches on the RHS. They looked pretty bad. Repainting is not an option since its expensive and kids will again scratch the surface.
Since I got the Meguiars Ultimate Compound(UC) from Sanjay at BBImpex, it been a life saver. It works so easily by hands. Megs SwirlX just doesn't hold a candle to it. I stand corrected that UC can be worked easily by hands.
Washed the car, clayed the surface using Megs claybar and then used UC with Megs applicator pads to get rid of those scratches and finally applied Blackfire Gloss Enhancing Polish followed by Blackfire Wet Diamond paint sealant. I would let the pics do the talking.
Pure magic.
Opti coat is a very tough coating which helps prevent the paint surface from damage. Its almost as tough as a clear coat. One needs professional help to do it, not any regular Joe can do it.
Ultimate Detailerz, Banglore recently applied Opti-Coat on a car yesterday only. Awaiting pics.
One of bhpian recently ordered an purchase from Autogeek. Let me ask him about shipping and get back to you.
Since there is hardly any available paint sealant, that leaves DG as the only choice.
Read it on Autogeek, that you can use DG101 as to prep the surface and later apply DG 105 as the paint sealant over it. If I were to look for a paint sealant DG101 + DG105 would be my choice.
cheers
I did suggest same as @Sohail99. If you didn't want to get it repainted, you could use a rubbing compound like UC, as I have detailed it above. I'm sure it can easily reduce the scratches by 70-80% or even more. Repainting is too expensive for such regular occurrences.
Old 13th November 2012, 14:25   #6465
The top coat[s] is gone, the undercoat is showing: how can you reduce such damage except my repainting? Scratch "reduction" relies on one or both of two things: rubbing (abrading) away more paint work around the scratch until it is reduced to the scratch level, and/or filling the scratch with some transparent substance so that it is not noticable. You can only do those things when the scratch does not go through the top coat itself.
Such a scratch would be easily dealt with by touch-up products and services available in other countries.
Car Detailing and Cleaning - 3M Car Care (Koramangala, Bangalore) nareshtrao Bangalore 26 16th September 2017 22:38
