Old 12th May 2013, 16:04   #7351
Parthasarathig's Avatar
Thanked: 494 Times
Originally Posted by Styler View Post
Dear Experts on Car Detailing,
Please add your inputs, I plan to do this over once I get all the things required
Styler
I think it would be best to get the initial phase of compounding and polishing done by notorious as his work is superb.
You can diy in the maintenance part as its less of a headache.
Originally Posted by archat68 View Post
Use either C845 or C476. Both of them are unnecessary. If you plan to use Relaod it is better to avoid C845 or C476 entirely. Both of these are extremely tough sealant. Reload over this will reduce the durability of Reload. It will be better if you use reload after Meg's UP.
Reload needs to be sprayed on the bare paint after having clayed compounded and polished the paint. Do an IPA wipedown or use eraser and then apply reload to the paint. Once it cures you can top up with 915.
Id say to avoid 845/476 because they have a petroleum base and that may affect the sealant.
Originally Posted by thoma View Post
Does pressure washing every weekend, with less frequent application of Eagle One liquid nano-wax, deteriorate the paint layers?
Im doing it almost every week shouldnt affect the wax coating at all. You may need to top it up after a few washes or can use a spray wax to top up the diminished layers since the mud will take away some wax with it.
Parthasarathig is offline   (3) Thanks Reply With Quote
Old 13th May 2013, 10:39   #7352
Arch-Angel's Avatar
Thanked: 277 Times
Hi ParthasarathyG,
How much did the karcher pressure washer cost you and how did you obtain it?
Secondly, what carpro products would you recommend?
My current stock of stuff would last me a lifetime . I am currently reading on the processes one must do for a minor scratch/major scratch and also dent removal as i felt it would be very helpful. Planning on making a dent repair kit and getting myself fine touchup brushes and a paint thickness gauge.
Arch-Angel is offline   Reply With Quote
Old 13th May 2013, 13:28   #7353
Thanked: 200 Times
3. Clay (Claybar : ClayMagic /Mother Claybar or something)
Try getting Megs or something else, Mothers Clay is not that good. I have used it personally and found them to be very mild to my liking.
4. Polish (I guess this is what is called Rubbing in our local dialect) Meguiar's ultimate Compound
Rubbing compound usually have only cuts. But what polish provides is cutting + restoration of essential oils to the paint, which gives paint a shiny/new look. My suggestion is to use a good polish.
5. Sealant : Collinate 476
Then after this every 3 months I can plan
6. LSP (I know know what it means ) Reload Spray / Colinate 915/845 periodically.
Wrong, C476 is considered as a wax more than a sealant and 845 is considered as a sealant. Please use 845 after clay and polish, then you can use 476 as a top up between the sealant applications. Moreover 845 lasts longer than 476. What you need is a strong base, and 845 provides that.
The above statement holds good for 845 as well as Reload. Both are sealants.
Here is some reading for you.
http://www.autogeek.net/qude101.html Syntetic sealants lasts longer than a wax. Please use them first followed by wax ( Optionally ) for more shine + added protection.
linuxmanju is offline   (1) Thanks Reply With Quote
Old 13th May 2013, 18:47   #7354
blackfire_9's Avatar
Thanked: 187 Times
Hey buddy, are you sure about this? I ask because I have almost always heard the opposite.
Old 13th May 2013, 19:01   #7355
Thanked: 200 Times
Ooops, Just checked a few reviews of both, and I stand corrected, C476 lasts longer than C845. Thanks for pointing that out to me mate.
However usually sealants have better durability than Waxes, and it is always recommended to use sealant first or as a base coat.
linuxmanju is offline   Reply With Quote
Old 13th May 2013, 21:44   #7356
Thanked: 494 Times
Originally Posted by Arch-Angel View Post
Hi ParthasarathyG,
My current stock of stuff would last me a lifetime I am currently reading on the processes one must do for a minor scratch/major scratch and also dent removal as i felt it would be very helpful. Planning on making a dent repair kit and getting myself fine touchup brushes and a paint thickness gauge.
Hi Arch-Angel
It cost me 13k and I got it from eBay.
CarPro products I can recommend are TarX, IronX and P.E.R.L. I haven't tried reload, but I hear its good too.
A paint thickness gauge is gonna cost you.
Well like I said earlier - Detailing stuff are like peanuts. You can never stop after trying one
I know that 476 and 845 are the same just they are in different states - solid and liquid.
Parthasarathig is offline   (1) Thanks Reply With Quote
Old 14th May 2013, 12:16   #7357
alstonlobo's Avatar
Thanked: 98 Times
Originally Posted by Parthasarathig View Post
Now Mr. Nirmal is the dealer for CarPro and Mr. Hari is the official distributor of Car Pro products for India. His website is www.greenzcarcare.in.
Hi Partha, I checked the CarPro official site and Greencarcare is not the official distributor. In fact he is the Reseller. There can be many resellers in India. There is no Official Distributor or Official Dealer for CarpPro in India so far!
alstonlobo is offline   (1) Thanks Reply With Quote
Old 14th May 2013, 13:07   #7358
Chris_Xtreme's Avatar
Thanked: 27 Times
Hi ParthasarathyG,
Hi Arch Angel,
Do you have any info on a good paint thickness gauge? Also let me know its price if you have one in mind. Would see if I can consider buying one for myself.Thanks!
Chris_Xtreme is offline   Reply With Quote
Old 14th May 2013, 14:06   #7359
Thanked: 494 Times
Hi Alston
My knowledge comes from the post by @Pedaltothefloor as shown in the pic above, Greenzcarcare is authorised to distribute CarPro products in India. From my talks with Mr. Hari, his supply comes from the CarPro's factory in Korea rather than resellers in the UK or US. And in case anything goes wrong with the product, he can give backup.
Better to buy these costly stuff from authorised people only because in case of problem they are ready to support. That gives me peace of mind to buy these items.
Originally Posted by Chris_Xtreme View Post
Hi Arch Angel,
Hey Chris, contact Mr. Nirmal. He can get you a paint thickness gauge at good prices and in a short time. I had spoken about it to him a few weeks back. He also has got one for himself. And just like every purchase from him, it will come with free training how to use the instrument whether its a DA, Rotary or a Paint depth gauge
Old 14th May 2013, 14:42   #7360
alstonlobo's Avatar
Thanked: 98 Times
Attachment 1083316
Hi Alston
Thanks Partha,
This is where I got the info from - http://www.cquartz.com/pages.php?page_id=98
Red Legend is for CarPro Resellers!
alstonlobo is offline   Reply With Quote
Old 14th May 2013, 14:46   #7361
lapis_lazuli's Avatar
Thanked: 449 Times
Might be useful for ONR users: I find it very useful...
http://www.autogeekonline.net/forum/...ve-thread.html
lapis_lazuli is offline   Reply With Quote
Old 14th May 2013, 14:51   #7362
n_aditya's Avatar
Thanked: 2,753 Times
I have asked this before in the Collinite 845 thread and have received responses to my query but am still confused.
Please clarify - is collinite 845 a wax or a sealant?
Which one do i use after a wash - 845 or turtle wax / meguiars nxt?
I've read that 845 is recommended to be applied first since it bonds to the painted surface better and then to apply the turtle wax, while others suggest in the converse.
Which is the best method to get the best wet look and shine on my car/bike with most durable results?
Old 14th May 2013, 15:01   #7363
mkh
Thanked: 107 Times
Collinite is a HYBRID, i had posted a link from the manufacturers own site here it is again
http://www.collinite.com/about-us/faqs/
Now to answer your question, let me give some gyan
To have ANY wax/sealant bond best to the surface, the surface must be prepared well, better the prep the better the bonding which means more durability.
You must wash and decontaminate( using clay) and then polish ( to cleanse the surface)
Finally apply a wax/sealant. Now sealants are surely more durable and since 845 is a hybrid, common sense( forget what manufacturers marketing talk says) tells that it will NOT be as durable as a PURE sealant. This can be debated forever and has been done so at many forums!
Applying a pure sealant is a best bet to get the max durability IMHO
mkh is offline   Reply With Quote
Old 14th May 2013, 15:10   #7364
n_aditya's Avatar
Originally Posted by mkh View Post
You must wash and decontaminate( using clay) and then polish ( to cleanse the surface).
Thanks for your response. So after a wash, which one goes on first? C845 or turtle wax/meguiars nxt?
I don't have clay bars as yet. Will buy them sometime in the future.
Old 14th May 2013, 15:21   #7365
blackasta's Avatar
Thanked: 1,119 Times
After a lot of permutations & combinations, I have found that till now Megs NXT followed by Collinite 845 gives the best result - both for water beading and shine.
Have a few more planned trials in the coming weeks.
blackasta is offline   (2) Thanks Reply With Quote
Car Detailing and Cleaning - 3M Car Care (Koramangala, Bangalore) nareshtrao Bangalore 27 19th June 2018 09:32
