Old 6th July 2013, 23:47   #7591
blackasta's Avatar
Thanked: 988 Times
Originally Posted by torque18 View Post
And how does ONR fare against NXT in the shampoo department? And I am assuming NXT can't be used as a lubricant so you have ruled it out
I do not have a NXT wash. I have not used the ONR yet - got a small pack. I have used the UWW, both as shampoo and QD - I like it better as a QD. For washing, previoulsy I used turtle wax platinum car wash. Although it was good in lifting dirt, it also stripped the wax/sealant. Have switched to Meg's soft wash gel and find it to be the ideal one for shampoo - super suds, gliding movement while using the wash mitt, good dirt lifting and does not strip the sealant.
Used the soft wash gel for a shampoo session today, and topped off the Klasse sealant I put in a month ago with a coat of Collinite 845. Maybe when the current shampoos run out I'll get a NXT wash.
blackasta is offline   (1) Thanks Reply With Quote
Old 6th July 2013, 23:54   #7592
Thanked: 591 Times
Originally Posted by Parthasarathig
My latest haul from Keystone Enterprises
1. IronX
2. IronX snow soap
3. 3m blue towels x2
4. Gold plush Jr.
5. Miracle shine
6. Waffle weave drying towel
7. Collinite 915
8. Pinnacle foam pad
9. Super Degreaser
That's a lot of money you blew there, congrats.
Are the prices for Gold Plush Jr. And C 915 any better than BB Impex?
Pedaltothefloor is offline   Reply With Quote
Old 6th July 2013, 23:54   #7593
Thanked: 92 Times
Where did you manage to get Klasse from?
And I think I will get ONR's smallest bottle for claying and go for NXT to use as a shampoo.
torque18 is offline   Reply With Quote
Old 7th July 2013, 00:08   #7594
blackasta's Avatar
Thanked: 988 Times
Autogeek - http://www.autogeek.net/klassekit.html. I carried it back with me while returning from US earlier this year.
blackasta is offline   Reply With Quote
Old 8th July 2013, 23:33   #7595
IronH4WK's Avatar
Thanked: 3,633 Times
so the weekend before last i got some time to kill running errands and chaeuffer duty and thought i'd wash my car, but i didn't have time for full wash in my basement (4-5 buckets of water and almost half a day gone) or the time to take it to 3M (only go to the one in HSR). then i remembered i had got a sample of Ultimate Waterless Wash Plus from Ulitimate Detailerz; thought i'd put that to good use. for the folks who don't know, the UWW is a concentrate and is a spray and wipe kinda deal.
before i washed the car, it was dusty and muddy - top to bottom and hadn't been washed to three weeks (yeah, i know - ain't proud of it) and rain didn't make things any better! after the wash, this is how the car looked like:
A superb Car cleaning, polishing & detailing guide-1043926_10151690344959483_1746098991_n.jpg
A superb Car cleaning, polishing & detailing guide-1016578_10151690344994483_489906577_n.jpg
A superb Car cleaning, polishing & detailing guide-600462_10151690345064483_1029831988_n.jpg
and all it took was 475ml of water + 25ml of UWW and 1hr of my time! yep, it isn't an exaggeration - just 500ml was used to clean the whole car, including the alloys! with this, not only am i saving water, but also time. planning to move from a sample to the full product
disclaimer: i do not have any affiliation to Ultimate Detailerz and don't stand to gain commercially from them. just sharing my experience with my fellow BHPians.
IronH4WK is offline   (6) Thanks Reply With Quote
Old 9th July 2013, 13:10   #7596
arup.misra's Avatar
Thanked: 293 Times
Great stuff mate!!! The car looks as good as new. Have a query if you can help.
Is the product any good on cars that have been through a week's rain and slush? If yes, do you actually hose it down and then use UWW?
I've been using ONR for a while now but somehow its not really upto the mark when you clean with it in the rains. The smooth glossy look is absent, thus necessitating the use of QD.
arup.misra is offline   Reply With Quote
Old 9th July 2013, 13:43   #7597
IronH4WK's Avatar
the car you see above had been through three weeks of rain and slush
no, i did not hose it down first. just spray on the area, keep for 30-45secs and wipe. remember, wipe, not rub. take one section at a time and move to the next. you do not want to keep the solution on for more time than 45secs as it will dry up and you'll need to out extra effort to remove it.
once all the dirt is removed, you might wanna go around the car wiping the surface with dry microfiber cloth. you may not get high gloss out of UWW, but you can see the results
ps: use a different cloth for wiping the running board, below the bumper and the mud flaps. also, do this in a nice shady place and not under the sun.
IronH4WK is offline   (1) Thanks Reply With Quote
Old 9th July 2013, 14:09   #7598
Vid6639's Avatar
Thanked: 19,591 Times
You did this on a detailed car right? As in your car was recently detailed and has a wax coat on top of it?
If yes then results are as expected since the slush will settle on the wax which is easy to remove.
If this was on an undetailed car, it will not work as well as the slush will end up putting minor swirls on the car even with the UWW.
Old 9th July 2013, 14:19   #7599
IronH4WK's Avatar
um.. no detailing done, but had got it waxed 4 or 5weeks back IIRC
that being said, i've used UWW on my car without any waxing done and i get the same shine. i'm not sure if shine is from UWW or the original surface
let me see if i can find some pictures of back then.
IronH4WK is offline   (2) Thanks Reply With Quote
Old 9th July 2013, 14:36   #7600
alstonlobo's Avatar
Thanked: 98 Times
My review and experience with the product is here, hope it helps:
http://www.team-bhp.com/forum/indian...ml#post3099262
In my case, I did water down the car as there were minute pebbles stuck along with the muck/slush.
You can use UWW as a QD and it works well.
+1 to that, from spotting to detailing, looks like your doing it all , I like the smooth slick finish once UWW has done its work. Saves water and time, with the car ending up looking clean
alstonlobo is offline   (1) Thanks Reply With Quote
Old 9th July 2013, 14:47   #7601
mkh
Thanked: 107 Times
When a car is heavily dirty, its always best to remove the top level mud with some water but that said any quality product that can be used as a waterless wash or rinseless wash can also do the job if done carefully. I have not washed my own car which is used almost daily for over 5 months and not even in these rains and it has no protection on it. The road approach to my house is a mud fest with BWSSB digging so the car does get quite dirty at times. Yes there are chances of putting minor swirls but then there is nothing that we do which will not inflict those in indian conditions. The important part is to ensure a clean microfiber runs over the surface each time and as put rightly wiping and not rubbing the cloth is needed.
mkh is offline   (1) Thanks Reply With Quote
Old 9th July 2013, 15:21   #7602
arup.misra's Avatar
Thanked: 293 Times
the car you see above had been through three weeks of rain and slush no, i did not hose it down first. just spray on the area, keep for 30-45secs and wipe. remember, wipe, not rub.
Thanks for the feedback. Will try and get a sample and see how good it works. My only concern is that if you simply wipe over the sprayed surface would it not attract swirls. For the gloss part I think what I see from your car pics makes me happy
Yeah exactly my point hose it down and then use UWWC else you'd invite swirls.
arup.misra is offline   (1) Thanks Reply With Quote
Old 9th July 2013, 15:32   #7603
IronH4WK's Avatar
in case there is heavy coat of mud, like you said, it is always better to hose it down before using UWW. in my case the wash was completed between running errands; i didn't have time to get water to my car (was parked at a distance from my in-laws house). however, i was very gentle with the wipe on really dirty parts, specially the bottom part of the doors and bumpers.
i'm happy i could help
Old 9th July 2013, 19:59   #7604
blackasta's Avatar
Thanked: 988 Times
For the past few weeks, I have been aggressively looking for a full sized DA to add to my armory. The Meguiar's DA power system is good, but the small pad size and heavy drill takes it's toll.
Now I see it is almost impossible to buy a DA in India as no one sells it. Greenzcarcare.in are out of stock for Kestrel DAS6.
Can anyone provide any pointers on how I can get a genuine DA in India?
Rotaries on the other hand are available freely - but I am thinking twice before picking one up as one wrong step with the rotary can cause irreversible damage to paint.
Old 9th July 2013, 20:31   #7605
Parthasarathig's Avatar
Thanked: 489 Times
For
Greenz is yet to sell the DA is what I heard. They are getting them soon. So you can place a pre order. Ive the Kestrel DAS6PRO got it from UK. Greenz is having both listed in his stock I see. You can either import from UK or buy in India with the warranty. Whats your budget? There is flex machines also available. But they are a bit costly.
Better not to pickup a rotary as you know why.
Parthasarathig is offline   Reply With Quote
Car Detailing and Cleaning - 3M Car Care (Koramangala, Bangalore) nareshtrao Bangalore 26 16th September 2017 22:38
