Old 17th August 2013, 00:05   #7801
NOTORIOUS's Avatar
Thanked: 85 Times
Originally Posted by lapis_lazuli View Post
Notorious ji, how can I effectively clean the seats and fabric trims inside my punto? It is not too dirty, only patches of dirt and oil stains and grease here and there. The fabric trims are grey in colour, if it helps.
Try Diluted APC At Approx 5:1.
  • Spray on door pad fabric.
  • Then Scrub it with very soft nylon brush.
  • Clean it with A M/F Cloth.
  • Allow It To Dry or Use Vaccum Cleaner
  • Repeat if necessary
Please Note :
  • Check the dilution level for any stains by spraying it on a hidden area
  • dont spray on glass
  • Dont Spray directly on roof liner
  • dont scrub roof liner , scrub with M/F cloth insted
I hope It Will Clear Out Your Queries
NOTORIOUS is offline   Reply With Quote
Old 20th August 2013, 16:59   #7802
Thanked: 117 Times
In absence of running water availability, what is the best way of keeping the wheels, tires and wheel arches' wells clean?
Is there any product similar to this one available in India?
http://www.nomad-direct.co.uk/index....dless/c_1.html
Thanks n Cheers
Waxeloquent is offline   Reply With Quote
Old 20th August 2013, 19:35   #7803
nitinralli's Avatar
Thanked: 456 Times
Can anyone tell me if this spray gun is worth buying? It says it has 40 watts motor to spray. Is 40 watts enough to get a good strong spray? Its for 3K approx hence looks tempting.
http://www.naaptol.com/misc/portable.../12178107.html
Anyone?
nitinralli is offline   Reply With Quote
Old 21st August 2013, 00:42   #7804
el lobo 6061's Avatar
Thanked: 946 Times
That's the worst car wash product I have ever seen. Not at all worth the price. It's powered by 12V cigarette socket. You won't like to keep your car running while you wash it.
Invest more and get a proper car high pressure cleaner. Best one is Karcher. Check out below link.
Karcher.
My pick would be Karcher K2.120 and given its COD, no issue what so ever.
el lobo 6061 is offline   Reply With Quote
Old 21st August 2013, 13:38   #7805
hungrygamer's Avatar
Thanks n Cheers
Wax, check out my purchase and details at snapdeal - even I was looking for Nomad but could not find here in India
http://www.team-bhp.com/forum/modifi...ml#post3197234 (Buying & Using a Pressure Washer)
hungrygamer is offline   Reply With Quote
Old 21st August 2013, 14:54   #7806
Thanked: 117 Times
I understand from Partha's one of the earlier posts that Karcher washer can take water from a bucket. Is that rt? Which model, what price and how to source?Is there any caveat on using that? Thanks n Cheers
Old 21st August 2013, 14:58   #7807
Parthasarathig's Avatar
Thanked: 487 Times
I have the Karcher 3.550. Price i think is around 16k currently. You can contact nearest Karcher dealer.
Parthasarathig is offline   (1) Thanks Reply With Quote
Old 21st August 2013, 18:37   #7808
abishek2222's Avatar
Thanked: 158 Times
Could someone help me with
Exactly how many ml of ONR Is to be mixed with how many liters of water for a car wash and for claying solution what is the ratio.
After a wash wherein the car is not really too dirty can I store the ONR wash solution and reuse it again?
abishek2222 is offline   Reply With Quote
Old 21st August 2013, 19:49   #7809
sagarpadaki's Avatar
Thanked: 1,164 Times
After doing some trials , I have found the following ratio to be working very good for me.
1. Quick detailer I use in 1:12 ratio
2. Clay lube 1:7 ratio.
Ofcourse you can re use the solution. You can prepare a quick detaileR ready mix in a spray bottle and use it when ever required.
sagarpadaki is offline   (1) Thanks Reply With Quote
Old 21st August 2013, 22:13   #7810
Thanked: 117 Times
The recommended dilution is 1Oz or 30ml of ONR to 2 gallons i.e. 8 litres of water. For Claying I used 30ml for
4 litres as I wanted more lub.
Yes you can. Then I would suggest you transfer a small quantity of ONR to any small plastic bottle and kept tightly
closed in the boot with an empty sprayer and a bottle/can of water. Just mix up the ONR in the proportions as above
and use with the sprayer and wipe off. Then if the car is too dirty, I'd not suggest this unless you do a good water
rinse/ shampoo first lest you get minor scratches from settled dirt.
Waxeloquent is offline   (1) Thanks Reply With Quote
Old 21st August 2013, 23:50   #7811
Thanked: 946 Times
Dilution Ratio:
Clay bar lubricant : 1:64(ONR:Water)
Quick Detailer : 1:25(ONR:Water)
Yes you can, but see to that you don't store the impurities as well.
That's an overkill. Try the above ratio and you may find it better. The new ONR(Blue Colored) is much better in comparison to what it was earlier. The green ONR is even better.
Old 22nd August 2013, 07:06   #7812
Thanked: 158 Times
Originally Posted by el lobo 6061 View Post
Dilution Ratio:
This is in terms of ML correct I have the green one.
Old 22nd August 2013, 07:39   #7813
Dilution Ratio:
But what I observed with the 1:64 is, its as good as not putting any additive. Its as good as pure water. Even if you use just water t
he effects is the same. Its like a placebo.
For quick detailer , 1:25 is good. But its also not effective on heavy stains. Also since you don't use quick detailer daily and you store it in spray bottle, a higher concentration Will also go a long way.
And ya my onr is 2 years old batch . So maybe many improvements have happened. Or maybe my onr has lost its efficacy leading to use of higher concentration , I don't know.
Old 22nd August 2013, 12:16   #7814
Thanked: 946 Times
Its a ratio, you can use it as ml, ounce or liters and green one is definitely better. Just see to that the liquid doesn't dry out since green one has wax in it.
1:64 is an actual recommendation by ONR manufacturer. I use Meguiars Quik Detailer as clay lube, though expensive but does a good work.
Since yours is a 2 year old one you find it bit less efficient. New blue one or even green colored are far better. You would find 1:25 more than adequate with the newer ones.
Old 22nd August 2013, 12:34   #7815
Thanks. Will buy the new ones once my stock is over.
Among the new ones , is blue better or the green one? Also what is the difference between them?
Car Detailing and Cleaning - 3M Car Care (Koramangala, Bangalore) nareshtrao Bangalore 25 25th October 2016 15:12
Cleaning, Polishing, Painting, etc - Carz Spa (Mangalore, KA) james Other Cities 6 20th December 2013 10:21
