Old 9th November 2014, 19:56   #8941
Thanked: 74 Times
All these years, I only cleaned my cars and never bothered about detailing. When living in the US, I didn't use any of the better stuff either, instead just used some cheap stuff from Target/Walmart , cleaned with California dusters and washed down my cars with a hose or even visited automatic car washes. Nothing changed after returning to India either.
Visited this thread and the other one about waxes/sealants and now I'm hooked.
Had already bought a Jopasu duster, 3M shampoo, Proklear Extreme and Ultimate Quik Wax (UQW) from Meguiar's.
The car was washed during the first service 5 days back and I cleaned it with Proklear before applying UQW a couple days back.
The first two are taken with a phone camera just after I applied the UQW in the evening. The third picture was taken the next morning and there was already a thin layer of dust.
Pretty happy with the shine. Am thinking of getting something like Carpro Reload for the base coat. What will the best options ?. The surface is still quite smooth and I'm thinking of putting off claying for another 6 months.
Are there any good retailers for Carpro/Ultima/etc in south Chennai around Adyar ?. Jeewajee in Nandanam only carries Meguiar and 3M.
vivriti is offline   Reply With Quote
Old 9th November 2014, 22:00   #8942
ptaneja's Avatar
Thanked: 279 Times
Sooo many pages, and so many choices - I am all confused !
Anyways, my car's silver color has become quite dull - not visible when the car is viewed alone, but apparent when the car is next to another silver!
Can someone please let me know what to purchase - cheap and easy to do ?
Or if its just too much effort, a shop/detailing place near Gurgaon/Delhi/NCR to get it done ?
ptaneja is offline   Reply With Quote
Old 10th November 2014, 02:30   #8943
Scorpioman's Avatar
Thanked: 47 Times
I would not suggest Reload for your car as Reload is more of a top up for cars coated with Cquartz. Colanite 845 will be a good option for you, easy to apply and 2 coats will easily last for 2 or 3 months. If you are willimg to spend a bit, get yourself an elastrofoam as well to clay the surface before applying Colonite. A good surface prep is required before any waxes or sealants are applied to get the best out of it.
Scorpioman is offline   Reply With Quote
Old 10th November 2014, 08:30   #8944
Thanked: 53 Times
Is it much easier to use elastrofoam ? claying properly with a regular bar is day's job !
stringbh is offline   Reply With Quote
Old 10th November 2014, 09:17   #8945
sagarpadaki's Avatar
Thanked: 1,257 Times
Claying with elastrofoam would take 2 hours max for a car of Polo size. Besides you need not have to worry about dropping it. Whereas clay would become useless if you drop it elastrofoam would need a rinse to get back to work.
Frankly clay bars are a passe now. Once you use elastrofoam or similar products from other manufacturers you would be kicking yourself why on earth you did not purchase it earlier .
sagarpadaki is online now   (1) Thanks Reply With Quote
Old 10th November 2014, 18:57   #8946
Scorpioman's Avatar
Thanked: 47 Times
I take about 2.5 hours for my Linea but it is done every 2 months. For a polo it should take 2 or 3 hrs max. Safer than clay as it can be rinsed and used again if it falls on the ground.
Scorpioman is offline   (2) Thanks Reply With Quote
Old 11th November 2014, 14:05   #8947
SaurabhSaran's Avatar
Thanked: 111 Times
Not only easy to use, it is economical as well when compared to the cost of claying bar. It costs around Rs.1700 where as clay bar from popular brands starts from Rs.4000
SaurabhSaran is offline   (1) Thanks Reply With Quote
Old 11th November 2014, 20:02   #8948
RiGOD's Avatar
Thanked: 93 Times
Anyone here using Amway Silicone Glaze? Just tried the Amway car wash and was satisfied with the results, so planning to go for Silicon Glaze too. Suggestions?
RiGOD is offline   Reply With Quote
Old 11th November 2014, 20:56   #8949
It's a decent glaze. Will give you good shine. Remember to top it up with a couple of coats of sealant. Else the glaze will just wash off
Old 11th November 2014, 21:51   #8950
RiGOD's Avatar
Thanked: 93 Times
Appreciate the quick response buddy. Could you suggest a VFM sealant too? So the procedure is like :
- Dust with Jopasu Duster
- Wash with Amway Car Wash
- Apply a single coat of Silicone Glaze
- Top it up with two coats of Sealant
Right?
Old 11th November 2014, 22:59   #8951
blackasta's Avatar
Thanked: 959 Times
Right?
Collinite 845, megs nxt tech 2 wax, gtechniq silo seal are a few good sealants
blackasta is offline   Reply With Quote
Old 16th November 2014, 21:25   #8952
RiGOD's Avatar
Thanked: 93 Times
Could someone comment on the long term safety and effectiveness of this clay bar alternative?
Old 17th November 2014, 18:53   #8953
S_U_N's Avatar
Thanked: 380 Times
While cleaning the car, the "2.0" decal came off the car. The adhesive gave up, it seems.
Now, I have cleaned that part and want to stick it back in place. What kind of adhesive should be used?
I am referring to the chrome lettering which is stuck on the car (like the badges that you see on the backside of the car.)
S_U_N is offline   Reply With Quote
Old 17th November 2014, 19:31   #8954
RiGOD's Avatar
Thanked: 93 Times
Check the item description of this ebay listing. It says to use 'Fevi kwik' in addition to the adhesive already present on the emblem. Can't comment on the safety of the same on clear coat.
BTW this one is actually meant exclusively for the purpose you mentioned.
Old 17th November 2014, 20:10   #8955
SunnyBoi's Avatar
Thanked: 2,784 Times
You need to get a roll of 3M Automotive Double sided tape and stick it on the badges like I've done below
Pretty sure no one will ever be able to pull the badges off if you use 3M tape. Fevi Quik is a very bad idea which will leave runs and look bad if you have a dark coloured car.
SunnyBoi is offline   (1) Thanks Reply With Quote
Car Detailing and Cleaning - 3M Car Care (Koramangala, Bangalore) nareshtrao Bangalore 26 16th September 2017 22:38
