Old 15th January 2015, 22:13   #9091
rishi_kapoor's Avatar
Thanked: 326 Times
Talking Re: A superb Car cleaning, polishing & detailing guide
You get most of the good sealants in India. So no point is getting what you get here from the US.
I would suggest you get this wax
http://www.autogeek.net/son1c-wax-carnaubavore.html
It is an awesome hand crafted wax which will give dazzling reflection, beading as well as protection. This product has rave reviews which you can read up and will truly be a unique wax in your detailing arsenal!
Took the plunge, ordered this from Autogeek, a friend would get it back here from US. This looks bitterly expansive but I guess my Audi would appreciate it
PS: Also ordered Klasse High Gloss Sealant from ebay India.
rishi_kapoor is offline   Reply With Quote
Old 15th January 2015, 22:36   #9092
sagarpadaki's Avatar
Thanked: 1,328 Times
Looks good.
Do you intend to do machine polishing?
sagarpadaki is offline   (1) Thanks Reply With Quote
Old 15th January 2015, 23:19   #9093
Thanked: 326 Times
Looks good.
I have a battery Random Orbital but since I am not confident, I will stick to hand polishing.
If there is another detailing enthu in Delhi or Noida then this is shout out for them for help.
Old 17th January 2015, 09:14   #9094
Thanked: 140 Times
I plan to lap up coats of Klasse AIO, Klasse Glaze Sealant and top them off with Collinite 845 in my new Pearl White Storme. I will use my hands and elbow grease.
I did the baggy test and the surface seems clean. Few questions:
1. Can i apply KSG right after KAIO? Is there any time needed between these 2 coats?
2. Everyone advices to give a 8-12 hour curing time after KAIO and before 845 - during this period if i use the car for daily drive, can i use Jopasu and QD to remove the minute dust that accumulates during the day and use 845?
hyper-VTEC is offline   Reply With Quote
Old 17th January 2015, 15:03   #9095
1. Yes, you can. No problem.
2. You mean KSG? Yes you can use the car. But do a rinse less wash before applying 845
sagarpadaki is offline   (2) Thanks Reply With Quote
Old 17th January 2015, 15:17   #9096
Thanked: 140 Times
Thanks Sagar. One final question?
Since mine is a new car with a pristine paint, do i need to apply AIO or can directly go to KSG and 845
Old 17th January 2015, 22:22   #9097
I would recommend KAIO followed by 2 coats of KSG with 8 hours between coats and Collinite after another 8 hours or a week whichever is convenient
KAIO + KSG is a system which acts in synergy . So it is always recommended to use them in pairs.
Another famous pair is Black Fire gloss enhancing polish + Blackfire wet diamond sealant
Old 18th January 2015, 18:28   #9098
Thanked: 326 Times
Sagar, are you saying that between AIO and KSG there should be a gap of 8-12 hours?
Another question to all, has anyone tried ceramic coating? Your feedback would be much appreciated. I ordered a very expansive ceramic coating "Pinnacle Black Label diamond surface coating" and Pinnacle Black Label synergy wax to top-coat it. Any feedback and experience sharing would help.
Also, any member with DA polisher offering help with paint prep for this expansive experiment is most welcome
Old 18th January 2015, 19:04   #9099
No Rishi, betwen AIO and KSG there need not be any gap. Gap is between two or more coats of KSG
Old 19th January 2015, 12:04   #9100
Sahil's Avatar
Thanked: 2,626 Times
Which is the best rubbing compound one car use to remove scratches? Have tried scratch removers before but they don't work as well.
Old 19th January 2015, 12:45   #9101
ghodlur's Avatar
Thanked: 2,386 Times
Question Re: A superb Car cleaning, polishing & detailing guide
I was about to post the same question. Right now confused between Meguiars Scratch X 2.0 and Formula 1 Scratch out. Megs is quite costly around 1K whereas F1 costs in the range of 300 bucks.
Reading the posts on this thread regarding scratch removal, many suggested to take help of good detailers like 3M. Waiting for experts to respond.
ghodlur is offline   Reply With Quote
Old 19th January 2015, 14:43   #9102
Originally Posted by ghodlur View Post
There is one one compound which will work . Of course , if you get the most aggressive compound then you can cover all the scratches but you will be abrading the clear coat more than what was required.
For minor scratches , this thing works
http://www.ebay.in/itm/like/131358816421
Check local hardware stores. They also carry this product. Very famous with local car painter and body shop guys.
Old 19th January 2015, 15:02   #9103
S_U_N's Avatar
Thanked: 383 Times
I have got pretty good experience using Quixx scratch remover
http://www.amazon.com/Quixx-00070-US.../dp/B000UVUAFO
I am not sure where I got this product from in India, three years ago, but I have still not run out of the liquid in the tubes so I have not bothered to look around for anything else.
The product can lighten the surface scratches quite well. If you are in Pune, I would be happy to put it to work on your cars.
Edit: It comes with sandpaper for wet sanding as well. That is more aggressive and to be used only if the results are not satisfactory with the two liquids.
S_U_N is offline   (1) Thanks Reply With Quote
Old 19th January 2015, 15:54   #9104
ghodlur's Avatar
Thanks mate for the suggestion. I hope this product will be available at 3M outlets.
Thanks for the suggestion.
A general question - Should the compund be applied directly and buffed with a MF towel or do I have to sand paper the area first before application of the suggested compound. The area in question is in the post where I asked the question earlier and contains the pic with damaged section.
http://www.team-bhp.com/forum/indian...ml#post3614109
Old 19th January 2015, 18:10   #9105
S_U_N's Avatar
Thanked: 383 Times
In case of Quixx, they give you a very fine sandpaper which should be used along with a little water. That would remove the clearcoat of your paint and the scratches would flatten out a bit.
Now, looking at your damage, I don't think any product can remove the scratches. There is metal visible, I suppose. So, touchup is the only way to do this.
However, the black marks can be lightened with the scratch remover. It will probably take an hour or two to carefully do this, since the damage is quite a bit.
Car Detailing and Cleaning - 3M Car Care (Koramangala, Bangalore) nareshtrao Bangalore 26 16th September 2017 22:38
