Old 30th November 2015, 08:31   #9511
ghodlur's Avatar
Thanked: 2,405 Times
Question Re: A superb Car cleaning, polishing & detailing guide
Detailing gurus,
Need your help. Today morning while cleaning my Punto, found some burnt type marks on the rear left C pillar section. I tried using a rubbing compound, but the mark faded slightly and did not come off. There was no welding activity near the car neither was any wax material (Suspected candle flying of the house). What could be it? I suspect the paint has been damaged. Is there any way I can remove them using any detailing products??
Pic attached (taken from mobile, so pls excuse the quality)
ghodlur is offline   Reply With Quote
Old 30th November 2015, 09:08   #9512
FuelInjector's Avatar
Thanked: 257 Times
Originally Posted by hyper-VTEC View Post
By AIO you mean a APC or the Klasse AIO or something similar?
sorry, i meant the Klasse AIO. i have never used an all purpose cleaner
Sorry to see this on your car. Maybe best to take it to your nearest detailing guy or a 3M outlet?
FuelInjector is offline   (1) Thanks Reply With Quote
Old 30th November 2015, 11:30   #9513
prithm's Avatar
Thanked: 485 Times
Originally Posted by ghodlur View Post
Detailing gurus,
More than the paint damage, I am worried about the location where this happened. How did someone manage to get a lit candle so close to fuel cap ?
The best option is to sand this area and do touch up and wax. Auto detailers will have ultralow coarse grits to do this fine work.
prithm is offline   (1) Thanks Reply With Quote
Old 30th November 2015, 11:49   #9514
ghodlur's Avatar
Red face Re: A superb Car cleaning, polishing & detailing guide
I am not saying someone lit a candle, just assuming that since it looked like burnt spots, the possible causes could be welding or some one carelessly tossing a candle which landed on the car and caused the burns.
But more surprising is that there was no smell maybe because it was not a recent one. Also the paint did not show any aberrations, it was quite smooth. Looks like the lacquer below the paint got burnt. But how that's a mystery.
Old 30th November 2015, 12:06   #9515
teemus's Avatar
Thanked: 501 Times
That's sad man!
Perhaps it's caused by a cigarette or a cigarette lighter?
teemus is offline   Reply With Quote
Old 30th November 2015, 13:47   #9516
Thanked: 140 Times
Thanks. As suggested by someone, i ordered AutoFinesse Citrus Wash. Will try that and then with the BH Auto Wash. I hope this will not strip the Klasse SG.
If the above things doesnt work, will use AIO. How much AIO do you suggest in a bucket, let's say 3 litres of water?
hyper-VTEC is offline   Reply With Quote
Old 30th November 2015, 14:06   #9517
sjcherian's Avatar
Thanked: 362 Times
Detailing gurus,
Did you park underneath any drainage pipes or under airconditioning equipment. Seems like some corrosive drips. However cannot explain how the surface is smooth.
sjcherian is offline   Reply With Quote
Old 30th November 2015, 14:12   #9518
Thanked: 257 Times
normally one capfull for a 3/4th bucket. in terms of metrics and if you have a spray container - lets say ~50 ml for 1ltr (i guess). you can then shake/spray and wipe off.
Old 3rd December 2015, 09:11   #9519
mav2000's Avatar
Thanked: 121 Times
Recently saw something called always dry on FB. And they claim resistance to water and mud. Does this product work?
Does anyone do this treatment in Bangalore and how much would it cost?
mav2000 is offline   Reply With Quote
Old 8th December 2015, 15:30   #9520
RAC
RAC's Avatar
Hi
An accidental spay with the water hose into a bowl of enamel paint (the type used to paint gate, window grill, doors, etc) kept near the car lead to spots of paint all over the rear door and back panel. The car has gone through a couple of washes and the paint splash marks are still visible. How can I remove the marks? Will wiping the car panels with cloth dipped in thinner work?
RAC is offline   Reply With Quote
Old 8th December 2015, 16:10   #9521
Thanked: 257 Times
Originally Posted by RAC View Post
Hi
Please DO NOT use thinner for multiple spots. Maybe you should take it to a nearby detailing shop or 3M outlet and get their advise.
if its a single spot, its a much easier DIY.
FuelInjector is offline   Reply With Quote
Old 8th December 2015, 18:20   #9522
KkVaidya's Avatar
Thanked: 271 Times
Hi
Don't even think of applying thinner. You will have to do proper sanding with a rubbing compound. These marks should only be on the clear coat so can be removed.
KkVaidya is offline   Reply With Quote
Old 9th December 2015, 10:52   #9523
SRK
SRK's Avatar
Thanked: 356 Times
Hi
Do not use any chemicals.
You can try using a clay bar. I think an aggressive clay bar could help remove those spots, this can be followed by polishing and then an application of a sealant.
SRK is offline   Reply With Quote
Old 9th December 2015, 16:09   #9524
KkVaidya's Avatar
Thanked: 271 Times
I have tried using clay of all sorts but it doesn't work. But an aggressive rubbing compound will.
Old 9th December 2015, 16:22   #9525
Raja's Avatar
Thanked: 61 Times
Picking up a new car this Saturday and checked with a local detailer about options.
One of them was ceramic polishing at a cost of Rs11K. Detailer says keeps mirror finish for 2 years or more.
Has anyone applied this type of finish? Is it worth the money (colour of car is dark grey).
Raja is offline   Reply With Quote
Car Detailing and Cleaning - 3M Car Care (Koramangala, Bangalore) nareshtrao Bangalore 27 19th June 2018 09:32
