Old 14th December 2009, 13:49   #1381
Atul-C's Avatar
Originally Posted by akshay_b View Post
I was on the look out for such a thing since a long time, Could you please pick one for me if you happen to visit that place again?
Could someone help me locate that kind of spray nozzle in BLR?
Hey Akshay, if you happen to come to koramangala, you can buy it from a guy who is selling the same thing on roadside. if you want exact location, i will attach a map to that location.
Atul-C is offline   Reply With Quote
Old 14th December 2009, 14:14   #1382
Atul-C's Avatar
Default Map of the location of the street hawker
Here is the map with the location of the street hawker who sells these kind of spray nozzles for 100 bucks. I have been using the one from him and its good quality for that kind of money. Now no more running to the tap to close the water flow or yelling at a family member to stop the water flow holding the pipe in your hand. God!!! I hated doing that everytime I washed my car.
Old 14th December 2009, 14:32   #1383
akshay_b's Avatar
Originally Posted by sharma_sanjeevi View Post
@Akshay, no problems, i can pick it up for you, the exhibition is till 20th December.
But, how will you pick it up from me ? are you coming to Mumbai ?
I was wonderinf if you can send it to me to Bangalore if it is not a problem to you, I will Bear all the expenses.
Hey there Atul, Thanks a lot for the map man, I've even tried ordering it from HK, DealExtreme: $6.74 Nozzle Adjustable Gardening Water Spray Gun
It will be of a great help for people who wash their cars often, Like me.
I'll try finding the vendor if i vist that locality.
akshay_b is offline   Reply With Quote
Old 14th December 2009, 14:52   #1384
sharma_sanjeevi's Avatar
Thanked: 62 Times
@Akshay,
Thanks to Atul-C, your search seems to end in Bangalore itself if you cant find the product there, do let me know, i will pick it up for you from the exhibition, i may be going there again on 19th.
sharma_sanjeevi is offline   Reply With Quote
Old 14th December 2009, 19:23   #1385
blackasta's Avatar
Thanked: 988 Times
Hey folks what kind of an exhibition is it? car and bike ? or industrial appliances?
blackasta is offline   Reply With Quote
Old 15th December 2009, 10:48   #1386
Thanked: 62 Times
It is an Arts & Handicrafts exhibition, held at Nerul, Navi Mumbai, near Moraj Residency.
Old 16th December 2009, 00:18   #1387
-NUT-case's Avatar
Thanked: 11 Times
Brought this simple Four Step Water Sprayer from an exhibition today, the guy demonstrated the four steps of the water spray, i quite liked it if anyone of you have used this thing, do share the experience, i will be using this on next Saturday.
I have had it for the last 6-8 years and it is still working. Does the job well but the water pressure is not very good, at least for me as i am in an independent house. For those in flats , it will give much better results. I have attached a a slightly bigger hose than my garden hose to the sprayer so i can easily fit it and remove it .You can use the knob behind the lever to adjust and hold the spray pattern as well without pressing the black lever.
At $6.74 it is too costly for a plastic one. The best nozzle you can get for the money is this one and it is better than a lot of more costlier ones. Amazon.com: Gilmour 528 Solid Brass Twist Nozzle: Home Improvement This nozzle combined with a quick release coupling works great. The pressure you get out of this nozzle is really good and it is easy to adjust the spray pattern ( just turn ). It is made of brass and rubber and so is durable.
  • The quick release coupling - disassembled
  • Everything put together and ready to use.
  • Got all this with a few more detailing products from America. Will post pics soon
-NUT-case is offline   Reply With Quote
Old 16th December 2009, 10:22   #1388
came across this article recently :
Citizen Matters, Bangalore: Wash your car, but with almost no water
crkishore is offline   Reply With Quote
Old 16th December 2009, 10:22   #1389
Thanked: 62 Times
Nut-case, thanks for sharing the information, yesterday, i was just trying the product for washing the Glass Window, it worked perfectly and gave a good pressure, but as soon as i released the lever, the pipe connected to the tap came out, i think it created a back pressure when i released / stopped using the spray.
Have you experienced this situation ?, if yes, do suggest what needs to be done to avoid the pipe coming out of the tap, or the back pressure is not created.
Old 16th December 2009, 13:13   #1390
-NUT-case's Avatar
Thanked: 11 Times
Well it happens even without the sprayer attachment as soon as you close the hose end with your finger or if the hose kinks, it creates pressure in the tube and it slips off the tap. To prevent this happening you can use 2 methods.
1. Tie a piece of strong thread about 1 - 2 inches from the end of the tube leaving both ends of the thread free and after attaching it to the tap tie the thread/rope onto the tap firmly.
2. Get an attachment ( from a plumbing/hardware store) that has an end to attach your hose and the other end goes on the tap which will have a plastic strap and a knob which can be tightened around the tap mouth.
Old 16th December 2009, 13:55   #1391
akshay_b's Avatar
Thanks for the amazon link, I'll try ordering if there's someone coming from the US.
Do you really get this kind of stuff? Could you share a pic?
Old 16th December 2009, 15:35   #1392
Thanked: 62 Times
Thanks for the inputs, i will try out both the options
@Akshay,
Did you get the sprayer on the location suggested by Atul-C ?
Old 16th December 2009, 16:54   #1393
Gansan's Avatar
Thanked: 883 Times
What will be the approximate cost of getting the car washed and waxed on a quarterly basis? Though my car is parked inside our premises, it is bang on the main road with heavy traffic and open to sky. I have to always keep it covered due to the heavy dust, and am afraid I will cause scratches if I try to wax it myself in that place.
I would like to get it done in a covered, dust free place. I understand the dust can simply be brushed off if the car is properly waxed? Please suggest a good place in Chennai where the price will not be daylight robbery!
Old 17th December 2009, 14:29   #1394
falcon009's Avatar
I have recently waxed my one month old car with 3M Liquid wax (80 INR), but i hardly notice any difference in the shine etc. I followed the instructions as written on the wax container. I left it to haze (3 mins max) and then rubbed the wax off. Am i missing something here or as my car is new i am not seeing a noticeable difference?
falcon009 is offline   Reply With Quote
Old 17th December 2009, 15:22   #1395
aks_karthik's Avatar
Thanked: 215 Times
What is the color of your car?
If it's a light color,Ex. Silver Gray,the shine will not be seen easily.
Waxing looks very gorgeous in dark shades Ex. Black and Red
aks_karthik is offline   Reply With Quote
Car Detailing and Cleaning - 3M Car Care (Koramangala, Bangalore) nareshtrao Bangalore 26 16th September 2017 22:38
