Old 1st June 2011, 19:06   #31
1self's Avatar
Thanked: 270 Times
Exclamation Re: Intercooler: benefits and spray cooling?
Originally Posted by condor;2374554
@[B
1self[/b]: your point about sealing the escape routes is valid. But regarding directing the air, your method will work better on highways. For city traffic, a good stream of air on the rear surface of the IC may really help.
You are correct. But remember the IC needs to dissipate kilowatts of power as heat. A PC fan will just not cut it. A small radiator fan of an 800 or a/c fan will do the job.
1self is offline   Reply With Quote
Old 1st June 2011, 19:15   #32
Thanked: 420 Times
Default Re: Intercooler: benefits and spray cooling?
@1self & Dhanush, thanks for that. Will definitely keep that in mind when I work on this. The SMPS fan was an example, but can you think of a better fan I can use ? Something small enough, yet one which can generate good flow ? I can also explore the possibility of running it on 12V if required.
Check the Gurkha thread Mohan has added an additional radiator fan since stock was not sufficient.
I think you can mount an additional radiator fan of some smaller vehicle ( 800 , Alto) and then create a channel to scoop air from radiator to IC ( Please use metal pipe not plastic / thermocol becuase that can create fire hazard)
amitk26 is offline   Reply With Quote
Old 2nd June 2011, 02:41   #33
dhanushs's Avatar
Thanked: 4,504 Times
The fan and the channel has to be installed and routed in such a way that the fan draws ambient temperature air and both do not block the normal air flow to the intercooler or radiator.
Is that possible? With the space given? And even if its possible, is the delta change in temperature, by cooling the rear of the IC, worth the effort?
Old 2nd June 2011, 04:11   #34
1self's Avatar
Thanked: 270 Times
Yes it is very much possible. He won't be cooling the rear of the IC. He intends to install a fan there & draw air from the front of the IC to the rear.
Condor, if installing the fan it becomes imperative that you don't allow air to escape from anywhere but the IC area. Plastic & thermocol, as long as it is not touching any part of the turbo or exhaust, will be fine.
Old 2nd June 2011, 12:26   #35
Thanked: 420 Times
Given the space in engine bay of Sumo it is fully possible , By installing a second radiator fan you can actually double the airflow like Mr. Mohan did in his Gurkha.
There will be additional electrical load of second fan which is not very high about how much effective it will be I don't really know if someone can implement and measure it is the only way out.
Old 13th March 2016, 23:28   #36
This link is of a video that shows the reduction in temperature (tested on a dyno) by an intercooler spray.
This one's a silly DIY intercooler spray that actuay does the job.
Taha Mir is offline   Reply With Quote
Touch Up spray/paint amit Technical Stuff 12 10th July 2011 11:06
Thinner or spray paint (for my SX4)? sathya_nars Technical Stuff 33 11th March 2009 14:15
Swift scratched while parking in Pune...need paint spray abhaybakshi Technical Stuff 19 7th March 2007 15:34
Spray painted Esteem!! X-Machine Shifting gears 4 12th August 2004 01:23
