Old 30th May 2011, 17:21   #1
wildchild4lyfe's Avatar
Default RPM Issues in Chevrolet Aveo
hey guys , i drive a chevy aveo with a FFE & Filter.
for some reason my car idles on 1000 without AC and 800 with AC when its supposed to be the other way around.
all the sensors are new, the engines rebuilt and pretty much everything else.
anyone faced the same sort of issues?
wildchild4lyfe is offline   Reply With Quote
Old 30th May 2011, 19:07   #2
vikram_d's Avatar
Thanked: 940 Times
Default Re: RPM Issues
Looks like the wiring of your idle control valve is mixed up. Looks like the wires have been crossed. The position of the idle control valve may also be wrong. Look at these couple of things and you should probably find your problem.
vikram_d is offline   (1) Thanks Reply With Quote
Old 30th May 2011, 20:43   #3
Thanked: 2,408 Times
FID not working would be my guess.
Is the Aveo a throttle by wire design? What is the fast Idle mechanism?
Compressor load brings down rpm, but closed loop control should have corrected.
Sutripta
Old 31st May 2011, 10:39   #4
Default Re: RPM Issues in Chevrolet Aveo
thanks vikram & Sutripta!
ill have these issues checked and get back.
Is Fuel efficiency strictly a function of RPM or is it speed+gear+RPM? Astleviz Technical Stuff 54 25th November 2011 09:22
Chevrolet Aveo 1.4: 10000 kms report and some niggling issues Raj'sGlory Long-Term Ownership Reviews 11 16th November 2009 12:34
Aveo vs Verna EDIT: Bought Aveo an10 Sedans 82 8th April 2008 17:01
rpm below idle rpm tortoise Technical Stuff 12 2nd April 2007 00:51
Chevrolet Aveo. v12 The Indian Car Scene 24 16th June 2006 20:46
