Old 10th June 2011, 11:26   #16
anilisanil's Avatar
Thanked: 288 Times
Default Re: Using an AC in an open car?
The only difference from a closed cabin is that the compressor is always on max load. If you have a closed cabin at say 40 C, then the a/c works by sucking in and slowly there will be a thermal equilibrium and a constant temperature is attained.
In an open cabin, the a/c would effectively be sucking in air always at higher temperatures and the compressor is always at load. It is more akin to using a/c in fresh air mode. Apart from that, the a/c air filter will choke more often and needs replacement. Apart from this I don't think we have other issues!
anilisanil is offline   Reply With Quote
Old 10th June 2011, 11:32   #17
GearOn's Avatar
As the compressor would never cut-off because of no reduction in cabin temperature, you are looking at lesser service life as well as higher maintenance costs. Would help if you atleast put a soft top.
GearOn is offline   Reply With Quote
Old 10th June 2011, 11:35   #18
Tejas@perioimpl's Avatar
Thanked: 5,475 Times
My project jeep was supposed to be a half hard top. However, as discussed in this thread (http://www.team-bhp.com/forum/4x4-te...p-hardtop.html (Flexural Stresses on Jeep Hardtop)) the flexural stresses on the top are an issue.
So we modified it to another design which may not allow doors. Thus, the question.
We are still working on a compromise.
Tejas@perioimpl is offline   Reply With Quote
Buy car using cash OR Take car loan & prepay home loan? rajshenoy Indian Car Loans & Insurance 13 2nd August 2013 18:16
Open open open Sesame!! VJ_MAVRICK Shifting gears 12 10th January 2008 15:24
First Open-Source Car Unveiled navdeep The International Automotive Scene 2 2nd April 2007 11:51
