Old 17th June 2011, 22:10   #31
sgiitk's Avatar
Thanked: 3,883 Times
Default Re: All 4shock absorbers gone in 1000kms
There is a possibility that those were spurious parts. OEM parts generally do not fail this quickly, and in a batch.
They were OE. 3 replacement sets all from A$$ cannot all be fake. Also, it seems that Hyundai switched from Korean dampers, to Chinese Dampers, to Gabriel in the period. One reason for the last was to reduce the shelf time, which can contribute to failures. Some changes in the rear suspension were made around 1996, so they were aware of the problem.
Old 20th June 2011, 17:01   #32
msupercool's Avatar
Thanked: 26 Times
I have opened up the springs again. I think that guy has given me the wrong springs, these don't seem like they are for Accent petrol maybe they are for Accent diesel. Im posting the pics of the front springs, just have a look. The short ones are the ones that were there in the car.
msupercool is offline   Reply With Quote
Old 21st June 2011, 14:50   #33
sgiitk's Avatar
If both are front, then just see the lengths. Differ by at least an inch! Something very fishy here.
Old 22nd June 2011, 11:33   #34
Thanked: 1,078 Times
It seems that the short ones are weak and have got compressed, as the number of coils is same. Could be bad material else old over used springs.
Old 22nd June 2011, 23:54   #35
Mr.Boss's Avatar
Thanked: 2,535 Times
Originally Posted by msupercool View Post
......these don't seem like they are for Accent petrol maybe they are for Accent diesel.......
Could be.
Do you have the part numbers of the new ones?
Even a weaker used one should not be compressed around 1.5~2 inches. Think of this compression in the vehicle, it loses around 40~50mm ground clearance.
In case of older springs or the one which is extensively used, load vs deflection curve should fall below the actual value. But the change in open height will not be in the same rate.
Mr.Boss is online now   Reply With Quote
Old 23rd June 2011, 11:19   #36
msupercool's Avatar
Thanked: 26 Times
Spent the whole day yesterday searching for the right springs and guess what, found 3 different sizes of front springs for Accent petrol1.5 . The shopkeeper was also wondering and all 3 had different part numbers. It seems that Hyundai made some changes in post 2003 models, they come with bigger springs and gas filled shocks. The prices of the 2 springs that almost matched my springs was much more than earlier springs which i had bought. Rs.2100/spring, now that is expensive for a spring.
Old 23rd June 2011, 11:27   #37
sgiitk's Avatar
Spent the whole day yesterday searching for the right springs and guess what, found 3 different sizes of front springs for Accent petrol1.5 . ......
I am not surprised since the model had a long run. Also, it verifies my info (thanks Drifter) that the suspension had major changes in/after 2003.
Ranikhet and Kausani, 1000kms 3 days! tsk1979 Travelogues 33 12th June 2014 14:00
1000kms TSD Rally in Karnataka shettysunil Indian Motorsport 8 20th September 2006 22:08
Mclaren's take on the baleno over the 1st 1000kms, believe it or not in 2 days.. mclaren1885 Long-Term Ownership Reviews 123 8th September 2006 16:26
chevrolet optra royale 1.6 1000kms xtr21 Long-Term Ownership Reviews 13 27th July 2006 14:41
