| LinkBack | Thread Tools | Search this Thread |
| | #1 |
| Newbie Join Date: Oct 2010 Location: Bangalore
| Hi, Pardon me if there is already a thread on this, I searched but nothing very relavant popped up. I have a Hyundai Getz 2005 Petrol model, which already ran 56K Kms+. I was getting a rattling noise when I take sharp left or right turns, so I deduced it to be a problem with the drive shaft boot, so went to the Trident Hyundai on Hosur Road to check it up.. The SA had a small drive and declared that its issue with the boots and suggested I change the whole drive shaft, which would cost around 10K exluding labor. I told him I have to pop the question in tbhp and take advice and then only change and insisted on any other solution and its price. He quickly changed track and said I can for now go ahead and do the change of Joints instead of the whole drive shaft. So my question is.. what should I change? Should I go ahead and just do joint change and I wont see this problem for a good amount of time.. or should I do the complete drive shaft change? Costs ------ RH Front drive shaft wheel side joint - Rs 1900 + 350 labor + Tax (Part number 495030B011) LH Front drive shaft wheel side joint - Rs 1780 + 350 labor + Tax (Part number 495030B001) OR Total drive shaft change - Rs 8000 + 500 labour charge + Tax Is the cost which he quoted reasonable? Are there any good independant garages which can do this task at a lower rate? I can spend this much money for sure, but dont want to get fleeced. So please advice. |
| | #2 |
| Distinguished - BHPian ![]() | Hi iikish, Change the CV joints, and the drive shaft boot(~200 bucks). The problem should be resolved. Also, after which, please ensure the driveshaft boot is in prime condition at every service, if worn out, change. It should cost only ~200bucks, but will save you hard earned $$$. P.S - I'm assuming a tak-tak-tak sound comes on full steering? |
| | #3 |
| Senior - BHPian Join Date: Nov 2009 Location: Deutschland
Thanked: 472 Times
| | #4 |
| Distinguished - BHPian ![]() | |
| | #5 |
| Thanks folks for the suggestions.. Yes.. it comes on both sides.. and only on full left or right turns. So I should get the boots changed every service? Does my driving style decide the life of the boots? |
| | #6 | |
Thanked: 472 Times
| No, I asked whether inboard or outboard ones? No, just keep an eye on them, check them every service for grease leaks, worn boots etc. Quote:
Spike | |
| | #7 |
| | #8 |
| How do I check if its inboard or outboard ones which has issue? Sorry for the dumb questions, I am new to these parts ![]() |
Similar Threads | ||||
| Pajero Gen 1 Combination Switch / Steering Shaft Issue | Cloud_Chaser | 4x4 Technical | 3 | 17th October 2010 16:57 |
| Test drive : Hyundai GETZ CRDi diesel | kpzen | Test-Drives & Initial Ownership Reports | 319 | 3rd June 2009 15:41 |
| Yokohama A.drive on Esteem, advice needed! | Raccoon | Tyre & Alloy wheel Section | 23 | 28th November 2008 08:12 |
| Hyundai Getz 50K KMs service - Help Needed | ntomer | Technical Stuff | 2 | 16th January 2008 14:47 |
| Hyundai Getz: The deal I got - comments and advice | JLN | The Indian Car Scene | 8 | 11th October 2005 19:55 |
