Old 20th June 2011, 02:22   #1
aditya.86's Avatar
Thanked: 17 Times
Default 2002 Honda Accord 4 cyl idling issues!
Hey guys,
I picked up a 2002 Honda Accord Lx 4 cyl in April 2011. The car had 97k miles on it and is a manual transmission. Have done close to 7000 miles and everything was perfectly fine.
Offlate, i have been facing issues with the idling. The car idles normally at all times even with the AC on. While driving i face this really weird problem. On coming to a halt when i depress the clutch and hit the brakes slightly the engine rpm goes down to almost 0(jus above 0 on the tacho). This happens once in a while and i do not face this issue everytime i do the above. And when this happens i just tap the accelerator a bit and the idle comes back to normal, just below a 1000 rpm.
What can be the cause for it? Would like to have your valuable opinion before i consult a mechanic so that i have an idea of what could be wrong instead of blindly believing what the mechanic tells me.
Thanks,
Adi
aditya.86 is offline   Reply With Quote
Old 20th June 2011, 02:51   #2
shuvc's Avatar
Thanked: 287 Times
Default Re: 2002 Honda Accord 4 cyl idling issues!
I been facing a somewhat similar issue and while reading up came across a possible Idle Air Control (IAC) valve problem. Might be worth checking out.
Old 20th June 2011, 03:56   #3
aditya.86's Avatar
Thanked: 17 Times
Which car are you using????
Old 20th June 2011, 12:07   #4
dhanushs's Avatar
Thanked: 4,504 Times
In addition to IAC valve, o2 sensor might also be at fault here.
Old 20th June 2011, 15:12   #5
Thanked: 111 Times
Just check the air fuel mixture pipe. It usually goes on without a clip & has a tendency to come off.
mb_jg is offline   Reply With Quote
Old 20th June 2011, 15:26   #6
shuvc's Avatar
Thanked: 287 Times
I've been having this issue with the Baleno.
Old 20th June 2011, 20:53   #7
aditya.86's Avatar
Thanked: 17 Times
Even i think its the idle air control valve. Will be taking the car to the mechanic today evening. Will keep you guys updated. In the mean time more suggestions are welcome.
Adi
Old 20th June 2011, 20:54   #8
aditya.86's Avatar
Thanked: 17 Times
I guess the CEL should come on if there is something wrong with the O2 sensor. Not sure though.
Old 20th June 2011, 21:06   #9
Jaggu's Avatar
Thanked: 8,670 Times
Get the throttle body and all associated sensors cleaned. Its a clear sign that they need cleaning.
Old 21st June 2011, 14:15   #10
Thanked: 103,359 Times
+1 to that. My OHC Vtec showed similar idling symptoms. All she required was a throttle body + sensor cleaning job (IIRC, cost 400 bucks at the authorised outlet). Importantly, the service engineer blamed the conical K&N filter for dirt accumulation. You running one too?
GTO is offline   (1) Thanks Reply With Quote
Old 21st June 2011, 20:32   #11
aditya.86's Avatar
Thanked: 17 Times
GTO,
Thanks for the valuable input. I will get the throttle body and the sensors cleaned immediately. I was planning to go for a conical filter but decided against it. I jus put in a K&N stock replacement filter a week back. The major problem i face here is stop signs where one uses the clutch and the brake simultaneously. Its become comparitively better after the filter replacement. I dont know whether this is actually true or it is just psychological.
Adi
6 Cyl. Turbo + 410 Nm Torque + 7 Wheels = ? EDIT: Pics on page 7! raj_5004 Commercial Vehicles 302 28th May 2012 11:53
Hyundai's new Kappa 1.0, 3-cyl engine: Will it come to India? Mpower The Indian Car Scene 4 25th January 2011 22:18
Honda Accord VTi vs Honda Accord V6 Dinesh99 Technical Stuff 48 9th March 2010 02:08
Ambassador with a 4.5 Liter, 6 cyl FORD engine!! n_aditya Modifications & Accessories 70 7th November 2009 08:07
A New type of engine -> NEVIS Engine, 2x Fuel Economy, 2 Stroke 2 Cyl 1000 cc 250hp 1Day Technical Stuff 16 2nd January 2009 18:24
