Old 28th March 2011, 15:12   #16
Samurai's Avatar
Thanked: 15,775 Times
Default Re: Somvarpet OTR 2010: Escape to Nature
Originally Posted by SPIKE ARRESTOR View Post
Please explain how measuring with a tape will create parallax error? Does that mean tailors make clothes with parallax error built into it? Nah!
Screw gauge cannot eliminate parallax error, why do you think Screw gauge eliminated parallax error?
Because I thought you did not know that. I guess you are referring to "Zero error" of measuring instruments
Never mind Spike. If you don't understand it already, no amount of explanation will help you. You are probably happier using a measuring tape instead of screw gauge to find the thickness of a pipe, just have to divide the result by Pi.
Trust me, I am not an illiterate, I did go to school.
Old 28th March 2011, 16:47   #17
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
Unhappy Re: Somvarpet OTR 2010: Escape to Nature
Now you will teach me parallax. I have become the culprit now. Samurai, I think you got me wrong here.
Wrong again! The topic of measurement here was "tire". Throughout my life I have never seen anyone measure a tire using a screw gauge, the simplest method is as pointed out by Fazal Saab- measuring tape.
BTW, thickness of a pipe cannot be obtained by dividing the measured value of a pipe by Pi, what you get by doing this ( (2 * Pi * R / Pi) = 2*R) is the diameter / radius. You don't require Pi to calculate the thickness of a pipe.
Thanks, but you are assuming this is an OE Jeep, Sibi generally mixes that stuff a lot.
Oh, that is surprising, I thought these were stock! Any idea what was done to this one?
Thanks, I am clear now.
PS- I guess whatever I explain, will never be satisfactory to you. Let me stop here.
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 28th March 2011, 17:23   #18
Samurai's Avatar
As I understood, Fazal wanted sidewall to sidewall thickness of a 235mm tyre. I hypothetically mentioned a giant screw gauge since I couldn't imagine how to measure it, I didn't think such giant guage is available. However, Tanveer came up with a neat way to measure it using hi-lift jack, which almost works like a giant screw gauge. Basically, the need is for a U shaped measuring device which accommodates the tyre.
I am still not sure how to use a measuring tape to measure the outer-to-outer diameter of a tyre. A diagram would surely help.
When I say thickness, I mean the outer-to-outer distance or diameter of the pipe. If I am not totally senile, I remember circumference of a circle = Pi X diameter. You can use a measuring tape to find the circumference and then divide by Pi to get the diameter or thickness. Obviously this method of measuring a pipe can't be used on tyre since the tyre cross-section is not a perfect circle.
Old 28th March 2011, 17:52   #19
jalsa777's Avatar
Thanked: 1,065 Times
That wold be called the Outer Diameter of the pipe (OD).
'Thickness' will always denote 'wall thickness' of the pipe
jalsa777 is offline   Reply With Quote
Old 28th March 2011, 18:00   #20
Samurai's Avatar
The original context of the posts was about outer diameter. Since I am not a mechanical/civil engineer, I tend to use thickness and OD interchangeably.
Most of us technically challenged people say 3 inch thick pipe instead of saying pipe with 3 inch diameter. You experts just have to understand that instead of getting all technical on us.
Old 28th March 2011, 19:26   #21
Thanked: 809 Times
Default Re: Just a thought - Units of measurement
Ha ha, Samurai is right, colloquially 3" thick pipe means 3 " diameter.
Spike
Old 28th March 2011, 20:51   #22
Thanked: 2,404 Times
Pipe are normally referred to by their inside diameter - the nominal bore. Wall thickness will be based on the schedule.
Ducking for cover now
Sutripta
Old 28th March 2011, 20:55   #23
Thanked: 809 Times
Dada, what is your view on "Parallax" discussed above?
Spike
Old 28th March 2011, 21:39   #24
(Cautiously coming out of cover)
Both of you are correct. Because you are not addressing the same issue.
Sutripta
Old 28th March 2011, 21:52   #25
Thanked: 809 Times
Wait a minute, are the two issues :- Parallax, Precision (L.C.)? Is that what you meant?
Spike
Old 28th March 2011, 22:06   #26
No. If I have understood the posts.
Samurai is talking of the parallax issues if you try to guess the position of the sidewall by holding a scale next to the tread. It will be major.
You are talking of parallax in reading a micrometer. It will be there because the sleeve physically cannot be at the same level as the thimble.
I must add that Samurai's parallax issues will dwarf yours.
Sutripta
Old 28th March 2011, 22:38   #27
Thanked: 809 Times
Just measuring tape, won't that create parallax error? I am assuming you mean sidewall to sidewall.
I thought Screw Gauge eliminated parallax error. Please explain how parallax error can happen in screw gauge?
Yeah, got your point. You are right when you say measurement with a scale will lead to major parallax when compared to a micrometer, I fully agree on this.
My point was using a micrometer does not necessarily eliminate the parallax error. The error is still a function of the viewing angle (human factor). Isn't it?
Spike
Old 28th March 2011, 22:53   #28
Spike
Yes. Because the thimble and sleeve are at different distances from the eye. In fact in a micrometer with a vernier, it can lead to an error of a couple of counts. Incidentally, one can design a vernier caliper with no parallax error.
Sutripta
Old 28th March 2011, 22:59   #29
Thanked: 809 Times
Yes, that is what I was looking for. ^^
Spike
Old 29th March 2011, 00:50   #30
Samurai's Avatar
Thank you, that's exactly what I was trying to say. BTW, it would be Fazal's parallax issues.
Thank you for finally accepting my logic.
That error is so very minute when compared to the width of a tyre. A fraction of a millimeter at the most.
Just a stray thought ! normally_crazy The Indian Car Scene 13 27th January 2005 22:02
