Thread Tools
Old 4th February 2006, 22:21   #1 (permalink)
superunknown's Avatar
Default Car Key Broken Inside Ignition..suggestions???
i have a maruti zen..i had a key which was on the verge of breaking and it was mistakingly used instead of my spare...when i tried removing it it didnt come out..so i drove teh car a bit and when i switched it off the key broke!.. there is a piece of it still stuck in the ignition hole and i cant start the car now..what suggestions can u guys give me.. its im,possible to take it out..what should i do?..it has central locking, and luckily its in the safetly of my house
__________________
V-6 ours one
superunknown is offline   Reply With Quote
Old 4th February 2006, 22:27   #2 (permalink)
falcon's Avatar
Do you have any tools ?
If you have got a good long nose plier, or a good set of tweezers, you can use that to pull the broken bit out of the ignition.
Be careful when doing it, u might push it in further!
Better would be to get the local chaviwalla who u trust and ask him to pull the bit out...
Best would be to go to the maruti authorised service center and get one of those guys home to get it done for you.
__________________
The price of freedom is eternal vigilence.
falcon is offline   Reply With Quote
Old 4th February 2006, 22:45   #3 (permalink)
thanx falcon..ill try wot u sed..have u faced a similar situation?..
__________________
V-6 ours one
Old 5th February 2006, 06:58   #4 (permalink)
falcon's Avatar
Yes i have, not in the car, but in locks at home.
Let me know what worked for you...
__________________
Old 5th February 2006, 09:56   #5 (permalink)
msprabhakar's Avatar
...the key broke!.. there is a piece of it still stuck in the ignition hole and i cant start the car now..what suggestions can u guys give me...
DISCLAIMER: I am about to advise you a minimally invasive surgical technique which requires supreme care and surgical precision and skill. Try this advice at your own risk! It worked for me several years back when my ignition key broke inside while trying to restart a disused Kinetic Honda.
Apply half-a-drop of FeviQwiK (the cyanoacrylate super glue from Fevicol available at any hardware shop) to the free end of the key (still in your hand). Tell your prayers and invoke His blessings. Re-insert into the ignition hole (or what's left of it). Allow reunion/ bondage to take place in-situ (allow 10 minutes). Pull out. Breath easy. Thank Him!
As with all surgical procedures, realise what complications can happen. Cyanoacrylate adhesives are known as "super glues" not without a reason. It can stick metal to metal or metal to skin or skin to skin. Do not let even a micro droplet to overflow outside the broken cross-section, else your key will be bonded to the ignition cylinder. Take care not to spill even a micro droplet on your skin, else you will require a maximally invasive surgery.
Best of luck! Let me know if the operation was successful and if the patients have survived...
__________________
Please, God, grant me the spark to imagine and a good car to ride over our potholes...
msprabhakar is offline   Reply With Quote
Old 5th February 2006, 21:02   #6 (permalink)
manaa45's Avatar
i m not sure this will help but if the key which is inside the ignition hole is in normal position then try using a powerful magnet to pull out the part which is inside the hole, the magnet might be able to pull it out.
hope this helps.
shubbhi
__________________
shubbhi.blogspot.com
manaa45 is offline   Reply With Quote
Old 5th February 2006, 21:15   #7 (permalink)
srasania's Avatar
I would suggest call a local keywala first,if he can't handle it,go ahead with the experts..(Maruti Authorized Service/On-Road Assistance).
Also,the feviquik idea,as someone posted seems like a minimally invasive surgical procedure,but with a very very high degree of complications !..so,I personally wouldn't opt for that..!
Keep us updated on what happens.
Cheers,
-sr
__________________
Driven by Dreams !
srasania is offline   Reply With Quote
Old 5th February 2006, 22:28   #8 (permalink)
adya33's Avatar
hope this helps.
shubbhi
no manaa, problem with that is, a very large magnet will be required to generate enough force to pull out that metal part (which is holded tightly inside)
but if you can somehow get electromagnet there, then it might be different story (highly unpracticle though)
best choice call Maruti people, second choice industrial adhesive but you must know what you are doing
ps: what were you doing by keeping half broken key ?
adya33 is offline   Reply With Quote
Old 6th February 2006, 09:23   #9 (permalink)
extreme_torque's Avatar
I think this shud work... even i was thinking exactly like this.
extreme_torque is offline   Reply With Quote
Old 6th February 2006, 10:03   #10 (permalink)
hehe thanks "DR" msprabhakar..the idea seems good enough but honestly it scares the c**p outta me!.. the problem is that before the key actually broke it was stuck inside..i will try and get it rectified by the a service centre first..thanks for all the suggestions neway
__________________
V-6 ours one
Old 6th February 2006, 13:11   #11 (permalink)
DRC
DRC's Avatar
I had a similar situation when the key broke inside the keyhole of my office rack.. Luckily it was open, and got the lock key assly replaced.. MOS should be the best way out..
__________________
_____________________
Stand on your head, upside down..
The world does not look any different, but you sure will look different!
DRC is offline   Reply With Quote
Old 12th February 2006, 22:57   #12 (permalink)
hey just thought ya'll shud know that the key problem was fixed..turns out that the entire assembly dint need to be replaced, the broken bit of key was removed in a couple of minutes using a pair of twisted wires...and just for safety sake i got an extra key made... total damage rs 100..thanks agen for ur suggestions
__________________
V-6 ours one
Thread Tools
Removing key scratches from a car? FaeLLe Shifting gears 10 3rd October 2008 02:00
Help!Water getting inside car sans33 Technical Stuff 7 13th July 2008 15:20
16" alloys, dark inside, chrome lip. Suggestions? theEnd Tyre & Alloy wheel Section 8 10th May 2008 16:54
Cellphone may erase your car key! tsk1979 Technical Stuff 9 30th May 2007 23:09
Home, car loans to rise further; RBI hikes key lending rate navdeep Indian Car Loans & Insurance 4 4th April 2007 04:59
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
