Old 5th December 2016, 14:47   #31
earthian's Avatar
Thanked: 671 Times
Infractions: 0/1 (5)
Default Re: Starting off in 2nd gear - Advisable?
For optimum performance and to keep the engine in its power band, you need to go through all the gears.
In my Santa Fe , there are 2 OD gears. 5th and 6th. I may shift from 4th to 6th sometimes.
Originally Posted by libranof1987 View Post
As long as you downshift to the appropriate gear, it is not a problem to shift from 5th to the 1st.
Is that right? I would have thought that a drastic gear reduction at speed, may strip the gears?
I do try some stuff like not using clutch while shifting etc, but this s shouldn't be done frequently.
I first used to do this on my Jawa 250. When you sync with the vehicle, you get tuned to the right synchronous speed for shifting the gears without engaging the clutch.
earthian is offline   Reply With Quote
Old 5th December 2016, 21:18   #32
Thad E Ginathom's Avatar
Thanked: 7,472 Times
Originally Posted by HappyRoadie View Post
Reviving this old thread. I have a Tata Safari Dicor. I have noticed that my driver reverses the car and when its time to move the car forward he directly slots it in 2nd gear and moves on. Is it a correct practice? Also 6 months back I had to get the clutch plates changed ( car had travelled around 43k kms then). The excuse my driver gave was that since the car is driven in bumper to bumper traffic thats why clutch plate got damaged. Hope to hear soon.
Take it out of the driver's wages. The clutch replacement points to, or at least strongly suggests, he is doing the wrong thing, or doing it in the wrong way.
By the way: a source of clutch wear is resting the foot on the clutch pedal. Check he doesn't do that,
One of my early gurus told me that (as I had learnt earlier) it is fine, within reason, skipping gears on the way down, but not on the way up. But an article I recently read put a compelling contrary case. say... you wanted to accelerate hard, so did so in second, and reached the speed you want to cruise at: so what's the point in changing to 4th via 3rd. None at all! But old habits die hard.
5th to 1st seems too big a change to me.
Err... I think you mean disengaging. You can do anything you like with the gear lever if you don't engage the clutch
My dad used to show off clutch-less driving, but he was a grand master, and had cut his teeth (and maybe those of a cog or two while learning) in pre-syncromesh days.
Old 5th December 2016, 22:09   #33
earthian's Avatar
Thanked: 671 Times
Yes, i meant disengaging, though "engage" in the present context was meant to be "employ"
earthian is offline   (1) Thanks Reply With Quote
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 85 2nd September 2009 18:47
Is it advisable to fit a Roll Cage for Maruti 800 model? vinfriend Modifications & Accessories 8 1st August 2007 22:34
Why it's advisable to have coloured helmets or stickers on helmets ? mithun Motorbikes 12 9th January 2007 16:51
Fiat Palio 1.2/1.6, Is LPG conversion advisable. Dhanan Hatchbacks 9 27th September 2006 18:09
Neon is it advisable kooldude Modifications & Accessories 37 3rd May 2005 14:47
