Old 5th February 2006, 12:52   #1
khaadu75's Avatar
Thanked: 11 Times
Default Changing the Timing Belt .. ??
Hey, Yesterday after going thru the manual of my Palio by mistake I noticed that they have stated that the timing belt shud be replaced at 60K !! I wanna ask all the Palio owners if they are aware of this ... also why does Fiat have this recomendation and not other manufacturers or do they all have it ??
Anyways went straight to the Fiat workshop ( i hate going there ) and asked them and they said it HAS to be replaced or else it could snap and do a lot of other damage as well. So I asked him how to much for changing the timing belt and also the clutch plates as I feel they r pretty finished and they said about 10K ... as I don't trust them too much is that a gud enough figure or does it seem high ?? Will have to get it done in a day or two so any feed back on this wud be highly appreciated !!
One last thing .. for the clutch plates should I put the ones by the dealer or can I get some other good ones in the open market ??
khaadu75 is offline   Reply With Quote
Old 5th February 2006, 13:31   #2
viper's Avatar
Thanked: 9 Times
Hi Khaadu,
Firstly it is advisable for you to change the timing belt. As far as the cost goes I think if you do it from a reputed garage outside the total job should not cost more than 6-7K including labour.(clutch&pressure plate+release bearing+timing belt+tensioner)
You can get the OE clutch plates cheaper in the market. Valeo is also a good make.
Viper
viper is offline   Reply With Quote
Old 5th February 2006, 13:47   #3
khaadu75's Avatar
Thanked: 11 Times
Originally Posted by viper
Hi Khaadu,
Viper
Viper, Thanx mate !! Any idea about the timing belt, I mean will I get that as well in the open market or will I have to get it from the company ?
Old 5th February 2006, 15:04   #4
viper's Avatar
Thanked: 9 Times
Hey,
You can get all the spares cheaper in the market. Only buy from someone reliable so that you dont get stuck with fakes.
Viper
Old 5th February 2006, 17:13   #5
SLK
SLK's Avatar
Thanked: 192 Times
Maruti says 1 lakh Kms.
SLK is offline   Reply With Quote
Old 5th February 2006, 19:38   #6
Awaiting Email Confirmation
Thanked: 319 Times
Default Spare parts not always cheaper in the open market.
Please note that the cost of the air filter assembly for the Palio GTX at the FIAT service centre is Rs698/- only inclusive of the new filter which comes fitted into the assembly. The same assembly in the open market in COCHIN in four different shops are between Rs1800/- and Rs1920/-. I have enquired in all the reputed shops in cochin which keep a stock of Palio spares. I had to buy two assemblies because of my own fault resulting in backfire and destruction of the airbox when using LPG gas. It happened on two occassions when I was not very comfortable with the auto changeover switch to LPG gas. Majority of the original fiat parts are atleast 60 percent more expensive in the open market atleast in COCHIN. Bye and wear your seatbelts.
drpullockaran is offline   Reply With Quote
alternator belt damages timing belt??? jalsa777 Technical Stuff 21 8th March 2015 10:52
Timing (cam) belt vs chain sbasak Technical Stuff 33 10th November 2009 16:00
Lancer diesel Timing belt Tensioner - Help! dilipkumar7278 Technical Stuff 6 9th November 2007 15:18
Trouble after timing belt change hamadrayad Technical Stuff 1 6th November 2006 20:05
