Old 30th June 2011, 16:05   #16
SPIKE ARRESTOR's Avatar
Thanked: 809 Times
Default Re: Odometer Inaccuracies
Yeah, sort of. The above point is also a reason for preference over positive error over negative error. We have to keep in mind that the instrument cluster / components provided by a supplier may be used in various platforms of a particular OEM.
Spike
SPIKE ARRESTOR is offline   Reply With Quote
Old 30th June 2011, 20:34   #17
rahul4640's Avatar
Thanked: 309 Times
I have the following free GPS based speedometer installed in my HTC mobile, a software downloaded from Android market.
http://market.android.com/details?id...=search_result
Several times I have seen that in my car the speedometer displays 110 KMPH when the GPS shows 100! And I have not upsized my tires.
Rahul Biswas
Calcutta
rahul4640 is offline   Reply With Quote
Old 30th June 2011, 23:31   #18
Thanked: 94 Times
My car's speedometer is calibrated to be +10% of true value under most circumstances. Checked with Satnav system & GPS enabled phone. Tripmeter readings don't deviate more than the nearest hundred but, there is actually no way to verify the exact magnitude of deviation as there is only one digit after decimal.
JustCause is offline   Reply With Quote
Old 1st July 2011, 00:26   #19
Sheel's Avatar
Thanked: 5,647 Times
When the Palio NV (the purple colored one) was launched, there were reports about Fiat calibrating the odo reading as it would show a bit more kilometers than it actually covered.
Reason? A slight bump while calculating FE figures so that owners would feel happy that their Palios are fuel efficient too.
Old 1st July 2011, 01:00   #20
lloydofcochin's Avatar
Thanked: 180 Times
I have not noticed any Odometer error with my Palio SDX (Stock tires) but I have observed that post getting my Garmin unit the Top Speed that the Car touched was 140 kmph on the Speedo and on the GPS it showed the max speed of only 134 kmph which I guess is a minor error.
lloydofcochin is offline   Reply With Quote
Old 1st July 2011, 03:55   #21
Mr.Boss's Avatar
Thanked: 2,541 Times
Speedometers & Odometers are always manufactured with some tolerance (I'm not sure on the need though)
Even tyre wear affects speedo/odo readings. Approximately for every 1mm of tyre wear 0.5% error gets accumulated (recheck this values from the dynamic rolling radius of tyres)
Mr.Boss is offline   Reply With Quote
Old 1st July 2011, 11:31   #22
BBR_SHR's Avatar
Thanked: 72 Times
The instrument cluster has tolerances. Some leading auto magazines even publish the actual/measured values in their reviews. I would trust a GPS for distance/speed measurements over odo.
BBR_SHR is offline   Reply With Quote
Old 1st July 2011, 14:42   #23
dhanushs's Avatar
Thanked: 4,504 Times
AFAIK, GPS systems available commercially does not count the road gradient, and hence always will give slightly less than actual readings.
Old 1st July 2011, 17:19   #24
BBR_SHR's Avatar
Thanked: 72 Times
That is a very valid point to consider. Natural gradient + man made gradient et. al.
Highest reading in the odometer! Surprise The Indian Car Scene 602 18th April 2018 19:39
Cars with 7 digits on their odometer (over 1 million kms / miles) supremeBaleno The International Automotive Scene 18 31st March 2016 19:40
Odometer recalibration rishibravo Technical Stuff 26 21st April 2011 22:39
Can this odometer be repaired? tsk1979 Technical Stuff 12 21st March 2007 03:17
Which odometer is correct? hasopi The Indian Car Scene 8 14th October 2005 08:47
