Old 8th July 2011, 15:40   #16
condor's Avatar
Thanked: 4,894 Times
Default Re: What's your sweet spot? (RPM)
Ikon- thats ULTRA low!
EDIt: Oh, TDCi.all clear!
No, I would never lug my engine.
On highways, it's typically at 2.5k RPM, unless I am at my top speeds when it's at 3k
Old 8th July 2011, 15:47   #17
A350XWB's Avatar
Thanked: 620 Times
Originally Posted by anilisanil View Post
Car -TDCi Figo.
3 rd gear above 1800 rpm is like fun. No other gear matches this fun, the car just takes off. That's my sweetest spot
Same here. The TDCi in Figo develops it's peak torque @ 2000 rpm (according to the specification sheet) and you can feel it too. You can feel the eagerness of the engine when the tacho needle crosses over the 2000 rpm marker. 2nd and 3rd gear and the rpm hovering over the 2000 mark is the sweet spot for me.
For the Santro, there is no tacho and I have to rely on the music from the engine. (Peak torque of 9.8Kgm @ 3000 rpm) So, it should be around 3000 I guess.
A350XWB is offline   Reply With Quote
Old 8th July 2011, 15:58   #18
fuel_addict's Avatar
Thanked: 115 Times
Car - Swift ZXi
Sweet spot - 2500 rpm and above. 3rd gear generally works best. Haven't gone beyond 4800 rpm.
Sedate driving - 1800-2000 rpm
Car - Corolla Altis
Any gear, any rpm is fine. The car pulls very well. 15kph in 3rd is also do-able at times.
Sweet spot - 2500 rpm and above. Haven't revved beyond 4400 rpm.
Sedate driving - 1500-1800 rpm
fuel_addict is offline   Reply With Quote
Old 8th July 2011, 16:08   #19
nkg77's Avatar
Thanked: 141 Times
Car - Grande Punto EPack (FGT)
Sweet spot - 2000 rpm and above, 3rd gear, it just pulls like crazy
Sedate driving - 1600 - 1800 any gear
nkg77 is offline   Reply With Quote
Old 8th July 2011, 16:17   #20
mayankk's Avatar
Thanked: 3,559 Times
well, this is added beep,beep research.
About the 3rd gear.
most fun gear to be in, it seems.
i think its that perception of speed and the "delta" of speed that is most apparent in 3rd, no?
what i am trying to put in words, wht i have in my mind, is that the average speed in 3rd, and sudden change in speed in 3rd in the sweet spot is the one felt most.
in 1st and 2nd, you arent in high enough speed.
in 4th and higher, the delta(math one.ie,change) in speed isnt all that perceptible.
oh wait,when did i start rambling??
mayankk is offline   Reply With Quote
Old 8th July 2011, 16:22   #21
Thanked: 115 Times
About the 3rd gear.
Also the belief that you still have the 4th gear to play with makes acceleration in 3rd even more sweeter.
Old 8th July 2011, 17:28   #22
Maverick79's Avatar
Thanked: 527 Times
Car: Manza QJT
ODO: 6782.
Sedate Driving :- 1600 ~ 1800. Change gears only when it drops to 1200 or even less than 1000.
(DIS is showing a kmpl of 21.2 AVG. Actual differenc is .85kmpl from the Tank full to tank full method.
Fuel indicator reached only half now. Was particular not to do any agressive driving since the last tank full to check the actual city driving mileage w/o AC in the sedate driving mode. Hope its possible till I finish another half tank of fuel left.)
Sweet spot/ range :- 1900 ~2200. It just zooms in any gear in this range. Feel the maximum torque for disposal here.
Aggressive driving:- Tried only once on a highway to over take. Touched 4000. But it was very harsh. Just after completion of 5k kms.
Need to redline it. Waiting for 10k kms completiong to see this happen.
Maverick79 is offline   Reply With Quote
Old 8th July 2011, 18:17   #23
vinya_jag's Avatar
Thanked: 177 Times
Figo Petrol-
Sedate driving: Never noticed the sweet spot. I guess it falls in the 1800-2400 range
Redline driving:
1st gear - Sweet spot - cannot notice, redlines at around 6K
2nd gear - Sweet spot - 3K-4.5K after which it feels a little strained, redlines a little less than 6K (Am afraid to push it further as it feels as though something is going to give way)
3rd gear - Sweet spot - 3.5K - 4K after which the acceleration overwhelms my nerves and I shift to 4th. Never tried to redline in 3rd though
4th gear - This is of not much use either in cities or highways.
5th gear - sweet spot - 60Km to 110 Km range (After 2nd service, i can fell that extra rush which wasn't there before) After this, it takes a little longer to reach 140. (Never tried beyond 140 though)
vinya_jag is offline   Reply With Quote
Old 8th July 2011, 21:02   #24
dot
dot's Avatar
Thanked: 714 Times
Civic (07)
Best place to be is 4000-6000RPM. The cars takes time to reach 4k, then rips to 7k in a flash. Ahhhh.
Which gear? 1st. Ok, sometimes 2nd.
What about other gears?
Relatively similar behavior. The needle takes time to reach 4k, then the flash occurs. However I have not yet redlined in 4th and 5th gear, because usually by that time, the road is over.
dot is offline   Reply With Quote
Old 8th July 2011, 21:35   #25
humyum's Avatar
Thanked: 2,502 Times
Swift Diesel -
Sedate City Driving - Anything Below 2000 rpm and a light accelerator, she ll respond with a mild speed increase. Perfect for city Driving
Highway Drives - 3rd gear is a murder weapon and will make the car reach 90 kmph in a jiffy after which 4th and 5th take over the pull till 150 after which things slow down a bit.
Sweet Spot for fun driving 2000 to around 3500 after which its pointless.
80 kmph comes in 5th gear at 2000 rpm so for highway drives its best to maintain 80 + for being in the meat of the powerband.
Old 9th July 2011, 00:01   #26
mayankk's Avatar
How many people here have experienced the sweet spot with and without the oe airbox?
Just curious.
Any perceptible difference?
My problem is I don't remember life before the conical
but I do remember things used to be quieter
Old 9th July 2011, 00:54   #27
BuRnT RuBbEr's Avatar
Thanked: 11 Times
linea mjd.
roam around: 1600 -1700rpm.
daddy will go first: 1900-wherever the world takes us.
BuRnT RuBbEr is offline   Reply With Quote
Old 9th July 2011, 01:13   #28
Thanked: 207 Times
Maruti Suzuki Swift Diesel -2000-3500 Rpm is Simply a blast to drive.
My Alto LXi doesn't have a Tacho but still I love to rev it to the max in 2nd Gear to hear the roar from its engine.
CRtorquefan is offline   Reply With Quote
Old 9th July 2011, 06:42   #29
venkateshkm's Avatar
Car - Polo 1.2 TDI, anytime I can get 200 mtrs of open roads ( very rarely ) 3rd gear above 1800 rpm. Pulls very well , is relatively smooth and seems to have a lot of power on offer.
venkateshkm is offline   Reply With Quote
Old 9th July 2011, 08:53   #30
SushilBajpai's Avatar
Thanked: 116 Times
Default Sweet Spot for RPM - Skoda Yeti
Skoda Yeti - Elegance.
Shift pattern (RPM) -
Moderately aggressive
1st: 2500 - 3000
2nd:2500 - 3000
3rd:2500 - 3000
4th: 2500 - 3000
5th: 2500 - 3000
6th: 2500
Eco/sedate mode:
1st:1800
2nd:1800
3rd:1800
4th:1800
5th: 1800
6th: 1800 - 2000
Yeti's sweet spot is apparently, from 1500 to 3000.
Most bang in this spot is in 3rd and 4th gear.
SushilBajpai is offline   Reply With Quote
PICS: Your Garage / Parking Spot anekho Street Experiences 66 6th July 2018 20:22
Which is your worst traffic spot? pjay_in Street Experiences 133 14th December 2017 11:29
Is Fuel efficiency strictly a function of RPM or is it speed+gear+RPM? Astleviz Technical Stuff 54 25th November 2011 09:22
rpm below idle rpm tortoise Technical Stuff 12 2nd April 2007 00:51
Sea water turns sweet? Shan2nu Shifting gears 13 24th August 2006 04:09
