Old 10th February 2006, 00:46   #1
vipul261's Avatar
Question Flywheel
Tell me what you think about flywheel..
Weather it is a part of Engine or Transmission???
I say that flywheel is physically present in the engine (seperate from transmission system) but the design of flywheel or its purpose is for Transmission system !
vipul261 is offline   Reply With Quote
Old 10th February 2006, 14:23   #2
sbasak's Avatar
Flywheel is the part of engine where engine transfers its output from pistons.
See www.howsuffworks.com and you can see nice animation of everything
sbasak is offline   Reply With Quote
Old 10th February 2006, 15:03   #3
marinegopi's Avatar
Thanked: 36 Times
hey mate the flywheel is definitely a part of the engine..its main function is to store energy developed during the power stroke and distribute it evenly for continuous and smooth power delivery during the other strokes when power is not developed (suction...compression....exhaust) it also houses the ring gear on its circumference which engages with the starter motor for starting the engine.
marinegopi is offline   Reply With Quote
Old 11th February 2006, 06:31   #4
Rehaan's Avatar
Thanked: 25,043 Times
Engine on both counts....
cya
R
Is flywheel replacement a must, when getting a new clutch plate? csateesh Technical Stuff 26 16th October 2017 06:18
Dual mass flywheel? bhardwaja2 Technical Stuff 6 18th July 2010 03:21
Flywheel Weight Reduction / Lightened Flywheels kpzen Technical Stuff 38 2nd February 2008 15:07
Lightened flywheel& underdrive pulley on esteem anybody? Stage3Monster Modifications & Accessories 8 18th March 2005 20:24
