Old 9th July 2011, 14:13   #1
Thanked: 1,664 Times
Default What's this warning light?
My father-in-law's Zen Estillo (2008 vintage) recently had a battery conk-off - he got his OEM battery replaced with an Amaron battery. Ever since (or so he thinks - but the correlation might not be correct) there is a warning light (red) on the dashboard of his car to the right side of the steering column.
Does anyone know what this light is trying to tell him? He'd also like to know what the switch next to it is. There is no mention of the light or the switch in the owner's manual.
This pic is from a mobile camera and hence might not be very clear. The location of the red light is circled.
binand is online now   Reply With Quote
Old 9th July 2011, 14:54   #2
dhanushs's Avatar
Thanked: 4,504 Times
Default Re: What's this warning light?
IIRC, the light is related to the car security alarm sensitivity. ie, you can can set the sensitivity of the alarm for sounding, if anything heavy passes nearby, or to touch sensitivity, or the least to sound only while opening the door. I think this light tells us the level of sensitivity.
Maybe after replacing the battery, the settings have gone kaput?. Is there any change in alarm sounding/security after replacing the battery?
Old 9th July 2011, 15:05   #3
vikram_d's Avatar
Thanked: 940 Times
That light should not be on. It being on means that there is something wrong with the security system. You would have got a Nippon user manual with the car for the security system. Look up in that manual or contact your Maruti service centre.
vikram_d is offline   (1) Thanks Reply With Quote
Old 9th July 2011, 15:09   #4
nomadabhi's Avatar
Thanked: 73 Times
The light is for security system. Lit up when active. The switch beside is for fog lamps. (basically after market fog lamp). The left side of 'alarm' is to house OVRMs switch (VXI version)
nomadabhi is offline   (1) Thanks Reply With Quote
Old 9th July 2011, 15:10   #5
frankmehta's Avatar
Thanked: 2,334 Times
It is probably related to the battery. Maybe it's been reset and the settings need to be adjusted again.
frankmehta is online now   Reply With Quote
Old 9th July 2011, 15:45   #6
Thanked: 28 Times
I also had this query, about a friends 2005 esteem, in which on driving one day the console lights, blower, stereo everything went off. It was detected to a blown fuse and it was replaced. After the replacement, the ecu or engine management indicator on the dash keeps on blinking at least 1k has been travelled but it just keeps on blinking. What can be the reason ? Any good knowledgeable and reasonable mechanic in S. Mumbai ?
kavesh55 is offline   Reply With Quote
Old 9th July 2011, 15:47   #7
frankmehta's Avatar
http://www.team-bhp.com/forum/indian...hlight=vitesse (MASS- Vitesse Pvt. Ltd., (Prabhadevi, Mumbai))
Your best bet!
Old 9th July 2011, 15:49   #8
V-16's Avatar
Thanked: 862 Times
Usually this light would mean that the vehicle is 'armed' , which means secure ready. This happens when either the panic button is pressed on the remote or when the car is locked when you alight. You may need to undergo some steps like switching on and off, the ignition for a certain number of times to get rid of this. Please contact your local dealer or read your owner's manual. That should solve the problem. I doubt it is battery related, though you may want to explore that option also.
V-16 is offline   Reply With Quote
Old 9th July 2011, 19:06   #9
Thanks for all the pointers, folks. I will tell my father-in-law to get the security system checked. He was looking only in the Maruti owner's manual, so did not find any reference to this light. Also, he took the car to the Maruti place on Old Airport Road in Bangalore (the one across the road and between Total and Pizza Hut) but they told him it is absolutely normal, he must not have noticed it in the past.
Old 9th July 2011, 21:06   #10
Speed.Demon's Avatar
Thanked: 465 Times
I have a similar Maruti Nippon security system in my Waggie. The light blinks continuously when the car has been locked using the supplied remote. This is not a malfunction, the system is designed like that.
Speed.Demon is offline   Reply With Quote
Old 11th July 2011, 09:44   #11
In the present case, the light stays on (not blinking) all the time irrespective of the status of the central locking system. I have asked my f-i-l to take it to the service center once again - a different one, this time. :-)
Old 11th July 2011, 18:25   #12
skilanjar's Avatar
Angry Re: What's this warning light?
You wont find this info in the Maruti manual, look for a seperate manual 'Nippon', it has the info. The same light shows up in my Astar, this would indicate that when u lock or unlock the car, the lights would flash but wont hear any 'tweets' sounds and when the light is off I can hear the tweets and see the flashes of indicator lights on locking unlocking.
I had to disable the 'tweets' sounds because kids would on purpose throw a football at my car to blow the horn. Or burst crackers in diwali , twist my orvms, hit a plastic ball..(complained to their parents and issue is resolved)... do wat not as this technology amazes them, ... so I only keep the beeps on when outdoors.
skilanjar is offline   Reply With Quote
Low Fuel warning light on Dzire/Swift-can it be activated/retrofitted? TOR Technical Stuff 43 20th October 2008 10:41
Low Oil warning light RJK Technical Stuff 9 6th July 2008 11:52
FI warning light constantly on - Palio Stile SLX PatchyBoy Technical Stuff 4 30th May 2008 12:14
Chevrolet Spark Seat-belt warning light adya33 Technical Stuff 13 22nd February 2008 18:00
Oil pressure warning light sbasak Technical Stuff 1 4th July 2007 11:24
