| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Feb 2006 Location: Bangalore
| Hello Folks, I am new to this forum folks. I own a Accent CRDi. Its 3 months old. I use Hi-Speed Diesel for my CRDi's consumption. Of late I am seeing lot more smoke in my exhaust compared to what it was earlier. I don't rev my engine more than 3k on the tacho. Any special maintenance suggested from other owners!! Do you think using Injector cleaning solvents would help? I use Mobil 5W-50 as my engine oil. I also used NULON during run-in period. Any other suggestions will be appreciated. Which is the best Premium Diesel of the lot 1. Hi-Speed Diesel 2. XTRA Mile Diesel 3. HP TurboJet Diesel Has anyone seen variations in FE? Regards Sateesh |
| | #2 (permalink) |
| Senior - BHPian Join Date: Feb 2006 Location: Aaaah... HALEEM!!!
| Hi Sateesh I own a CRDI myself and have had this problem for the last two years... After an entire battery of tests and various interventions by the dealer this problem still has not gone away - keeps surfacing within a couple of days .. This happens when ever the MASTER AIR FLOW SENSOR is dirty/clogged. despite even trying a K&N filter we found enough muck in the turbo and intake systems to paint a decent sized mural with !! - am sure this has definitely dented the life of the engine. I have as recently as yesterday reverted back to a stock filter and am sending the car to get the ENTIRE intake plumbing stipped and cleaned. dange is the sensor itself may be irrepairable dirty and may need ot be replaced - in which case will set you back by bout 7.5k. Suggest you go for the extended warranty which covers these things - I did! Now time to CONFRONT Hyundai with this - the dealers are clearly clueless and unhelful! Sujit ANYONE who can shed more light on this - surely will help |
| | #3 (permalink) |
| Update I gave the car to Leela Krishnan's garage. He stripped the enire intake system, cleaned the entire thingy and put the whole package back. Tested the whole thing on a dyno, tweaked the Mass air flow sensor - and the smoke seems gone! Lets now see if it ever recurs - in which case replaing the sensor is the only option. Rdgs Sujit |
| | #4 (permalink) |
| | #7 (permalink) |
| Hello Sujit, I am not sure neither are the Hyundai *** folks. The folks at the *** are confident they can fix it. Let me see. I am also not lucky enough to have Leela Krishnan service my car. And I know what an enthusiast he is. Lucky you.. |
| | #9 (permalink) |
| Hello Folks, Apparently the Hyundai *** folks cleaned the EGR valve(Exhaust Gas Recirculation) and calibrated the sensors. It seems to be clean now. I need to keep an eye to identify recurrence of the same. If it does I am planning to confront Hyundai on this. Keeping my fingers crossed till then Regards |
| | #10 (permalink) |
| Hello Sujit, The smoke is back after clocking 200 kms on the ODO. I am confronting the Hyundai *** and making a lot of noise. Let us see on how it goes. I am getting frustated as I see a lot of other CRDi's on the road without this issue. Drifter have you had this issue before... Regards Sateesh |
| | #11 (permalink) |
| BHPian Join Date: Jan 2005 Location: chennai
| May be naive thought, but can be considered. Why don't you try using ordinary deisel. Reason is, there was a big thread in tbhp on Innova diesel - black smoke, the owners found it, the premium deisel is main (or important) culprit. |
| | #12 (permalink) | |
| BHPian | Quote:
in fact my scorpio crde had the same problem and it was attributed to faulty oil separator, it has been replaced during service and now its gone. btw, i am also using hsd.however, it hasnt done more than 100kms since the service.. may be i need to keep an eye on smoke.... if i am right, steeroid's dicor had the same problem and was subsequently recified by rebanding the EGR. so insist the service centre to rectify the problem permanently. | |
| | #13 (permalink) |
| Hello Sujit and other Team-BHP folks, The EGR valve was cleaned and the problem has gone away. The biggest change has come from the change of Diesel- From BP to IOC. The Hyundai *** looked at their records and found a couple of more folks who had the same problem and the problem vanished when they were asked to switch from Hi-Speed Diesel to XTRA Mile Diesel. I now can see my CRDI literally flying to smoking out Esteems.. I have done 200 kms since the fuel change and I don't see any smoke yet.. Finally a happy customer of Hyundai ***( They showed the difference in Hi-Speed Diesel and IOC's combustion exhausts...) Cheers Sateesh ------------------------------- I drive a Accent CRDi |
| | #15 (permalink) | |
| Quote:
Good to hear your problems have gone away.... not trying to spoil the party but I have ALWAYS used IOC Extra mile ONLY. Have done 500kms since the cleanup.. My problem has not recurred.. yet ... !! Going on a highway trip this weekend.. Gonna let her stratch her legs a little,.. will keep all of you posted how that goes
__________________ A closed mouth gathers no Feet. | |
| Thread Tools | |
Similar Threads | ||||
| Lancer DIESEL/ Accent DLS/Accent CRDI | ForeRunner | Sedans | 20 | 12th August 2008 23:01 |
| Accent CRDi or Accent Viva CRDi Looks | abhibh | The Indian Car Scene!! | 4 | 8th November 2005 16:43 |
| Accent CRDi or Accent Viva CRDi | abhibh | Sedans | 16 | 8th November 2005 04:58 |
| Accent CRDi | z klasse | Sedans | 50 | 12th April 2005 14:59 |
| Maintenance costs of the Ikon 1.3, Accent 1.5, etc | zazuaza | The Indian Car Scene!! | 4 | 20th November 2004 16:24 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458
