Old 19th July 2011, 22:32   #16
humyum's Avatar
Thanked: 2,503 Times
Default Re: The jump over the roadhump :(
Originally Posted by Maverick79 View Post
When you brake at speeds, majority of the load component shifts on to the front wheels and will compress the springs in the front from the top (to be precise, at an angle from the top of the springs)
Now in this condition, if the front tyres start climbing a sudden bump, the springs are further compressed from the bottom side too.
Hence, this could cause some damage to the 're coil' property of the springs in the suspension. The re bounding nature may get reduced due to excessive compression from both sides of the springs.
Hope I could clarify to some extent.
Yes the strut takes a beating and secondly if the forces are too high for the strut to manage, i ll bend under the load and your car will see excessive camber which can only be corrected by strut replacement.
So as rightly pointed out, never over a speed breaker make a last ditch attempt when its unavoidable, just let it glide over it. At the most you will see a bent rim or alignment out. Mechanically the car will still be sound.
Old 20th July 2011, 00:58   #17
Thanked: 103,670 Times
Airguitar, here's a thread that might make you feel better : PICS of flying cars! (Wheels in the Air - Pics of flying rally cars)
Old 20th July 2011, 01:16   #18
dhanushs's Avatar
Thanked: 4,506 Times
. That would cheer him up for sure.
My 2 cents regarding landing, if at all one manages to make a jump at speeds on the streets: Keep the steering straight, meaning in the direction where the car is flying. If there is any direction change you have to do, do it after the landing.
Old 28th July 2011, 18:31   #19
crackparag's Avatar
Thanked: 69 Times
I did this once too (jumping over the speed breaker) in my Esteem and fortunately or unfortunately the front part of the exhaust (near the front wheels) scraped on the road and the car started sounding (albeit, a little) as if a free-flow was installed. Obviously I never got to repair that part of the exhaust, given the sporty note . I, however did send the car to the A.S.S for checking the entire suspension and steering assembly, was relieved to get a clean chit.
The car, even today sounds sporty!
crackparag is offline   Reply With Quote
Old 30th July 2011, 17:03   #20
RGK
RGK's Avatar
Thanked: 221 Times
Recently i came across a big size speed breaker (ramp like one) in Tirupathi and could not locate due to rain and poor headlight (normally i drive in low beam inside the town). My Figo had four adults and 2 kids at the time of jump.
Luckily my presence of mind helped in not braking at that time.
My daughter sitting in the back hit the roof.
Nothing happened and no noises so far. But as said by many, I want to have an alignment checkup soon.
RGK is offline   Reply With Quote
Old 30th July 2011, 17:44   #21
libranof1987's Avatar
Thanked: 4,221 Times
Does Figo have a sump guard (engine-guard)? You could check it to know how nasty the hit was.
Please ask the passengers in the rear seat to wear seat belts too.
libranof1987 is offline   Reply With Quote
Old 1st August 2011, 13:07   #22
RGK
RGK's Avatar
Thanked: 221 Times
I dont think it has a sump-guard. Luckily the road was good and hence the landing (?!) was even.
Absolutely right . The seat belts are pushed inside under the rear seat after the seat covers are installed. No doubt this shows my seriousness towards safety . Will get corrected and Thanks for the advice.
Old 1st August 2011, 15:14   #23
d_payne's Avatar
Read in isolation, that statement just sounds funny!
Am sure your daughter will have serious issues with you if you have an alignment checkup done on her head!
J/K
d_payne is offline   Reply With Quote
Old 1st August 2011, 16:19   #24
RGK
RGK's Avatar
Thanked: 221 Times
J/K
. Acutally my head needs an alignment checkup for driving without seatbelts on
Portable Jump-Start Packs rameshspassion Technical Stuff 6 4th January 2015 11:54
Do you jump red lights? tsk1979 Shifting gears 73 9th July 2012 15:50
Dont jump in to buy the pulsar 200!! Wait for the 220 devil_in_flesh Motorbikes 14 21st April 2007 12:20
Tyre "Jump Maar Raha Hai"What does it mean humyum Technical Stuff 26 10th November 2006 18:04
Need a jump over 3230 sinner Gadgets, Computers & Software 28 13th October 2005 03:21
