Old 27th July 2011, 11:03   #1
Thanked: 672 Times
Default Multifunction Display Dead on Fiat Linea
Hi
Yesterday, my dashboard err - froze on the Fiat Linea. The time is stuck at 3.11 and none of the gauges work. The Blue and Me works but I don't see any display whatsoever. When car is switched on neither the Airbag nor the ABS signs come on either. Same goes for all lights. For all practical purposes, the Dashboard is dead. Anyone else have the same issue? If so, could you resolve it on your own or did you have to take it in to the Fiat chaps?
invidious is offline   Reply With Quote
Old 27th July 2011, 11:24   #2
NetfreakBombay's Avatar
Thanked: 402 Times
Default re: Multifunction Display Dead on Fiat Linea
If your car still under warranty? Do not attempt DIY if it is.
Old 27th July 2011, 11:25   #3
Thanked: 672 Times
Yep, my car is under warranty. I have registered a complaint now with Fiat India on their 1-800 number. Let's see how it goes.
Old 27th July 2011, 11:31   #4
1self's Avatar
Thanked: 270 Times
I think a fuse has blown. However let the A.S.S. personnel handle this.
1self is offline   (1) Thanks Reply With Quote
Old 27th July 2011, 11:35   #5
Post re: Multifunction Display Dead on Fiat Linea
Even i would suggest let the *** handle this but one small thing that you can try is disconnecting the negative terminal of the car battery for 5 to 10 minutes and see if this helps.
djkher is offline   Reply With Quote
Old 27th July 2011, 11:36   #6
Thanked: 672 Times
So I assume it is not a very big deal?
Old 27th July 2011, 11:42   #7
1self's Avatar
Thanked: 270 Times
You assume correctly.
1self is offline   Reply With Quote
Old 27th July 2011, 11:46   #8
Awaiting Email Confirmation
Thanked: 4,225 Times
You can try disconnecting your Linea's battery's negative terminal and re-connecting after 10 minutes. If it works, then MID functions are to be reset.
J.Ravi is offline   (2) Thanks Reply With Quote
Old 27th July 2011, 12:09   #9
revintup's Avatar
Thanked: 373 Times
Yes,it might be a case of blown fuse.its very easy to check and change blown fuses.I think the fuse box comes with spare fuses.check the owner's manual.
revintup is offline   Reply With Quote
Old 27th July 2011, 12:26   #10
the-rare-one's Avatar
Thanked: 58 Times
I would not worry too much. TATA-FIAT are known to replace parts under warranty. I just hope its just the fuse thing as others have mentioned.
I had the same problem on my Indica and the warranty was to expire in 3 days. I logged in the complaint with B.U.Bhandari, Pune TASS and they honoured it. Entire instrument cluster replaced
V. Imp: If the entire cluster needs to replaced, make sure they do not give you another cars cluster with some reading on the ODO already. It happened with me and I had to live with it. The changed cluster came with reading as 420 km and since then I subtract 420 and add 7525 km (cluster went dead at this figure) from the current reading to actually derive my clocked figure .
the-rare-one is offline   Reply With Quote
Old 27th July 2011, 12:32   #11
moralfibre's Avatar
Thanked: 6,532 Times
I agree with 1self, its just a fuse from what I can guess but in that case, the clock, odo, trip should not display at all rather than freeze as you have mentioned.
Old 27th July 2011, 12:47   #12
Thanked: 402 Times
Since some parts are still working, fuse might not be the root cause. I believe a reset by removing battery might do the trick or something related to MID might have gone Kaput.
Better to let A.S.S. take a stab at it first.
Old 27th July 2011, 13:33   #13
Thanked: 672 Times
A.S.S will take a stab at it tomorrow. Called up Tata owned Worli center which gave me an appointment for August 8 and suggested I call up Bombay Cycle Co at Churchgate. BCC gave me an appointment for tomorrow. But I guess thanks to my call to Fiat First 1-800 number, Worli called me back and asked me to come at 9 tomorrow. While I am sure BCC is good, I'd much rather stick to the company owned center.
Old 30th July 2011, 11:54   #14
Thanked: 672 Times
Default Re: Multifunction Display Dead on Fiat Linea
Well it was fixed - for a little while atleast. Now the battery is dead. Also an orange light on the dashboard was on 15 minutes into taking the car from the service station. It showed an inclined seat ?!?!
Old 30th July 2011, 15:45   #15
dhanushs's Avatar
Thanked: 4,504 Times
Well, a dying battery does show similar symptoms. I think in the Swift D, it even turns on the Engine Check light.
Fiat Linea and Fiat Punto (90 BHP) Owners. Timing chain issue & recall justin.das Technical Stuff 130 26th May 2018 08:28
Fiat Linea front arm rest for Fiat Punto NSK123 Modifications & Accessories 47 15th April 2013 23:34
fiat sienna-water wash -ecu dead nutmello Technical Stuff 4 18th September 2010 09:53
