Old 15th February 2006, 20:48   #16
Mpower's Avatar
Thanked: 1,687 Times
22 psi does sound really high. I guess we will confirm that when remano fit a boost gage into his Scrpio.
Old 16th February 2006, 13:58   #17
Sideways's Avatar
Thanked: 18 Times
I'd like to see it too. If it aint right the turbo energy guys are defineately gonna hear from me.
Sideways is offline   Reply With Quote
Old 16th February 2006, 14:12   #18
Is it possible to fit any pressure guage to measure turbo boost ? for eg: hospital oxigen pressure guages which are claimed to be accurate.
Or any special guage is required for turbo applications ?
renamo is offline   Reply With Quote
Old 16th February 2006, 15:27   #19
nitrous's Avatar
Thanked: 285 Times
Renamo, u can get an engine-boost guage which is available with autoguage/autometer. And make sure it can read till 24-25 psi...
Sideways can comment more on this since he used to have a Turbo Lancer
Old 16th February 2006, 17:20   #20
Firstly, no 3K application runs at pressure ratios above 2.2, that means that the max boost pressure that the turbo could produce would be limited to abt 1.2 bar.
secondly, an EGR valve and a BOV are 2 totally different things.
BOVs are used in turbo petrols to prevent surge, as has been explained in great detail.
petrols, being low CR and spark ignited engines, operate at or near abt the stoichimetric AF ratio. to attain this they have a throttle valve, which controls the amount of air metered into the engine. the fuel input is adjusted likewise. this is why, when load is reduced, it causes the throttle valve to close and this is where the BOV comes in. the BOOM noise is heard in turbo petrols for this very reason.
An EGR valve merely recirculates the exhaust air from the exhaust manifold and mixes it with the fresh inlet charge. this causes the oxygen content to reduce and hence limits the NOx formation. there is no 'blow off' anywhere in the inlet route.
diesels are more fuel efficient because they can operate at higher AF ratios (usually abt 20+).As there is no throttle valve in diesels hence no BOV is required.
porsche_fan is offline   Reply With Quote
Old 20th February 2006, 01:53   #21
jat
What a silly mistake . Thanks a lot for reminding about throttle valve. I should have remembered it in first place while giving funda on surge. Thanks again.
Regarding pressure ratios of turbo, technology exists for pressure ratios of 3.5 that is turbo pressure of 2.5 bar. But for many constraints the technology is not provided to end user. For example see the pete's tuning box to produce more power.
jat is offline   Reply With Quote
Old 20th February 2006, 02:24   #22
Mpower's Avatar
3K meaning KKK? A 2004 Porsche 911 turbo runs 1.8 bar boost stock. I believe the STI_300 is even higher. You would think they are using a german turbo supplier
Old 20th February 2006, 03:08   #23
Mpower's Avatar
Originally Posted by Sideways
Tifosi, he means bosst pressure as in the case of the turbo. I know the non CRDE runs 1.4 to 1.6 bar which is about 22 to 23 Psi. i know it sounds a lot but I have verified this with Turbo Energy who make the turbos for the Scorpio.
Sideways, Im wondering if what he's refering to is the absolute pressure at compressor outlet. So the boost would be 22 - 14.7 = 7.3 psi (gage pressure which is commonly quoted).....but it still works out to 1.5 bar.
Old 20th February 2006, 10:49   #24
Lets not compare a
1.) 3.6 L 6 cyl gasoline boxer which uses cutting edge technology and makes 444 HP and a 2.6L 4 cyl diesel which makes 115Ps
2.) a turbo manufactured by BW systems germany and one by TEL, India which only has 31% BW stake in it.
Petrols have poor volumetric efficiency as compared to diesels.
therefore to achieve the same volume of air flow, higher boost pressures are reqd.
Of course all this greatly depends on the engine design and the rated speed , but this a basic thumb rule.
Old 8th September 2009, 12:53   #25
MB-Sting's Avatar
Originally Posted by nitrous View Post
Yes,Renamo.
We're sure its 22 psi.
Infact, we were searching for a Scorpio's waste-gate actuator when the one in the EVO-VI gave up. The EVO was spooling somewhere around 18-22 psi.
Has someone maybee got a picture of a boostgauge on a Scorpio showing the actual maximum boost, my boostgauge shows my Scorpio boosts about 0.9bar max. If there is something wrong I would like to get it fixed, but if 0.9bar is what its supposed to be I'm fine. Everybody says it should be 1.5bar???
MB-Sting is offline   Reply With Quote
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
Effective utilization of wasted boost pressure (Turbo) tsk1979 Technical Stuff 8 11th May 2013 14:30
Help with Scorpio Tyre Pressure with 16" BFG NIP Tyre & Alloy wheel Section 4 7th July 2009 17:05
Question regarding Santro tyre pressure shapath Tyre & Alloy wheel Section 7 12th July 2007 16:43
Where Do I get BOOST? mazrx Modifications & Accessories 2 1st February 2005 11:40
