Old 17th October 2014, 09:50   #76
Blue Thunder's Avatar
Thanked: 335 Times
Exclamation Re: A/c Evaporator coil fails 2nd time in my Ford Fiesta
Originally Posted by sswaroop View Post
Our Fiesta has been having problems with the Air Con for the past year or so. There is no issue with the cooling of the A/C....
Have you made any modifications during the past year or so? For eg. , if you ICE'd your car, and the installer guys had not done the routing of wires the proper way...they could have made small holes in the floor carpet area near the dash area...above where the passenger feet would be...this could cause external air to come in even in re-circulation mode.
Blue Thunder is offline   Reply With Quote
Old 17th October 2014, 18:47   #77
Thanked: 31 Times
Nope. No modifications done. The ICE is the same one that was installed when we bought the car some 7 years ago now
sswaroop is offline   Reply With Quote
Old 17th October 2014, 20:31   #78
khoj's Avatar
Thanked: 1,258 Times
Default Re: A/c Evaporator coil fails 2nd time in my Ford Fiesta
Why would an ICE installer make holes in the floor?
Old 17th October 2014, 22:55   #79
vnabhi's Avatar
Thanked: 1,317 Times
If you check my LTO thread of my Fiesta, the most recent service had some preventive measure to prevent AC Evaporator damage, for which around 2 K was charged. The job involved removing the dash. I don't remember what they called it, but it does look like Ford has come up with a solution.
Old 10th June 2015, 16:27   #80
vnabhi's Avatar
Looks like I've finally become the victim of the infamous AC evaporator coil issue!
This is after 98 months of ownership.
A week back, when temperatures were around 45 degrees C, I had to make two airport runs in the afternoon. On both trips, I felt the AC was not cooling enough, even at blower position 2 and sometimes in 3. But in the evenings and mornings, it worked fine. Even today it was working fine. But the max temperature today was only 37.
Nevertheless, I took it to Vibrant Ford as I needed to get a bush replaced on the lever that holds the bonnet up. I also asked them to inspect the AC. They did inspect it by sitting inside the car and putting it in a higher blower position, and confirmed that there is a whooshing sound that indicates a leak in the evaporator coil. They said I can get it done later, and would cost around 13 K with labour. They also said the weakness in the AC would manifest itself only in very hot temperatures.
This being the case, I am wondering if I should get it done over the next few weeks at an AC shop nearby, instead of Ford A.S.S. The only things holding me back from going to the local guy are:
  1. I'm not sure if he can fix the dashboard back in a manner that will not lead to rattles.
  2. Hope I don't have water droplets on the footwell that some people are complaining of.
  3. His shop is on a narrow street, and I am hesitant to leave my car for an entire day over there.
BTW, that guy was referred by another bhpian.
vnabhi is offline   (2) Thanks Reply With Quote
Old 10th June 2015, 16:38   #81
amitpunjani's Avatar
Thanked: 101 Times
If the "Whoosh" sound ONLY appears during start of the Aircon, then it indicates Gas is less. Pls. top us the gas. If that "Whoosh" sound is constant then there is possibility of Gas Leak.
amitpunjani is offline   (2) Thanks Reply With Quote
Old 10th June 2015, 16:40   #82
vnabhi's Avatar
I believe it is the latter, though my untrained year could not pick it up on the return journey. Let us see how it holds up.
Old 10th June 2015, 21:48   #83
sbala's Avatar
Thanked: 158 Times
I was the victim of this issue, not once, but twice :( Once i gave it to Ford ASS and the bill was close to 11k. After 3 years, i had this issue again and gave the car to Raj Motors, Bellandur, Bangalore and they fixed the issue within 7k. Touch wood, no issues so far.
sbala is offline   (1) Thanks Reply With Quote
Old 10th June 2015, 21:50   #84
Jaggu's Avatar
Thanked: 8,692 Times
Why don't you get it checked by the local fellow first before you conclude on a decision? I have a feeling it is just a gas top up issue.
Old 10th June 2015, 21:57   #85
vnabhi's Avatar
That's on my cards. Only reason I hesitate to go to the local guy is that he has no protected parking and the car needs to be parked on a narrow lane that has traffic. But I'll see if he agrees to come home and analyze, or find a shelter near his shop.
Further, I'm not sure if removing and placing back the dash is an intricate task, and I'd hate rattles emanating from a badly-fixed one. My WagonR rattles like a snake, but that's due to Maruti's quality.
Old 10th June 2015, 22:04   #86
Jaggu's Avatar
By checking i meant taking an opinion , not ripping the dash and checking. If he is good, he will be able to tell you what really is wrong.
Jaggu is offline   (1) Thanks Reply With Quote
Old 10th June 2015, 22:13   #87
vnabhi's Avatar
Ok, gotcha! I do have a plan to get it checked. I went there once last week, but the guy was not around. He wanted me to call and go to his shop after ascertaining that he was around. It falls on my way back from office, so I'll pay him a visit soon.
Old 4th July 2015, 18:04   #88
vnabhi's Avatar
I finally took the plunge and got my Evaporator Replaced by the Subros workshop, who also service ACs of cars of all manufacturers. Total cost was Rs 7600. Details in my LTO thread.
http://www.team-bhp.com/forum/long-t...rs-old-40.html
Old 5th July 2015, 07:45   #89
Thanked: 68 Times
I finally took the plunge and got my Evaporator Replaced by the Subros workshop, who also service ACs of cars of all manufacturers. Total cost was -fiesta-1-6-sxi-turns-one-fat-lady-8-years-old-40.html[/url]
Any idea what sort of damage causes the evaporator to get replaced? Since it sits safe buckled behind the dashboard, unlike the condensor that sits ahead, no iota of a physical damage can be thought of.
gopa99 is offline   Reply With Quote
Old 5th July 2015, 10:28   #90
Captain Slow's Avatar
Thanked: 664 Times
If you are referring to that woosh sound that comes during the Aircon start up, then just ignore it. Our figo makes the same sound, been living with this sound close to 2 - 2,1/2 years now. During the service the SA keeps asking if we want this sound checked, on asking him what would be done to check this sound? He replies - removing and re-fixing the dashboard, checking the coil ( all this means big labour costs). So far everything about the AC is behaving normal, except for that wooossh sound. Until my AC starts acting up, I will just ignore this sound.
Captain Slow is offline   Reply With Quote
Spied: All-new 2017 Ford Fiesta for the first time RavenAvi The International Automotive Scene 6 29th November 2016 21:24
Corolla A/c Evaporator Replacement - Steps and Pics! vigsom Technical Stuff 7 18th May 2012 20:44
Please help me decide: Fiesta S or Fiesta ZXi? EDIT: Booked Fiesta S! Pics on pg5. frankmehta Sedans 108 18th August 2009 13:43
Ford Fusion fails crash test (apparently?) rkg The Indian Car Scene 12 8th March 2006 08:00
