Old 2nd August 2011, 19:22   #1
ssh1979's Avatar
Thanked: 106 Times
Default Ford Endeavour - Sedimenter Fuel Filter Warning Light
Hi Guys, mine is a new Endeavour which I took delivery of on Saturday 30 July and I noticed this thing this morning. When I put the key in the ignition I saw the "Sedimenter Fuel Filter Warning Light" glow. After I started the engine the light went off and never came back again. I am not really sure if this occured over the past three days too. After the factory filled fuel, I topped up the tank at BP on Saturday evening.
The manual doesn't say anything; except to drain the water if this comes on. I'm just hesitant to do anything myself just three days after taking delivery.
Is this quite common, and should I be prepared to do this when required? Also, why does the light go off when the engine starts? The manual makes no mention that the light goes off once the engine is started.
Cheers,
Shyam
ssh1979 is offline   Reply With Quote
Old 3rd August 2011, 19:06   #2
Thanked: 103,780 Times
Default Re: Ford Endeavour - Sedimenter Fuel Filter Warning Light
Relax! Even if you tried, I doubt you'd be able to get the sedimenter filled with water in just a tank fill
I presume the light is designed to glow on "ignition on" mode & go off when you crank the engine. Similar to the check engine light.
You should worry if the light stays on *after* starting the engine.
GTO is offline   (1) Thanks Reply With Quote
Old 4th August 2011, 13:54   #3
ssh1979's Avatar
Thanked: 106 Times
Post Re: Ford Endeavour - Sedimenter Fuel Filter Warning Light
GTO, thanks! I checked the OM again, and it just says the light glows when there is 0.13L water accumulated. And to drain it if it does. No mention of pre-cranking and post. I'll keep watching out anyways.
Old 4th August 2011, 20:30   #4
Alter_Ego's Avatar
Thanked: 98 Times
The light is supposed to glow when you switch the ignition on and should go off as soon as you crank the engine.
If it remains glowing when the engine has started, then you have something to be concerned of.
Else.Chill.And congrats on your purchase.
Alter_Ego is offline   Reply With Quote
Old 6th August 2011, 17:08   #5
ssh1979's Avatar
Thanked: 106 Times
Thanks Alter_Ego. I guess I was just being paranoid typical of "just bought" category
Fuel filter warning sign comes up! subratasenn Technical Stuff 14 1st November 2015 10:02
Ikon Fuel Filter : OEM is cheaper than After-Market filter RM2488 Technical Stuff 13 28th June 2012 11:39
Sedimenter Light issue in Innova. Folks on the road! raj_5004 Technical Stuff 13 1st September 2010 16:58
Low Fuel warning light on Dzire/Swift-can it be activated/retrofitted? TOR Technical Stuff 43 20th October 2008 10:41
Is Oil filter and Fuel filter different? finneyp Technical Stuff 10 25th July 2008 11:45
