Old 27th August 2011, 02:20   #31
dhanushs's Avatar
Thanked: 4,507 Times
Default Re: Sluggish response from i20 Diesel
PROBLEM SOLVED
The culprit was bad diesel.
My 1st suspect would be bad fuel.
Please make a note to change the fuel filter.
Old 27th August 2011, 06:14   #32
gopikb's Avatar
Thanked: 133 Times
PROBLEM SOLVED
The culprit was bad diesel.Filled up at my regular pump with Xtra mile.The performance is back as before after driving some 100 kms with new stock of diesel.Maybe it took some time for the adulterated one to lose its bad effect.
Thanks everyone for the valuable suggestions.
sagarpadakki, can you help to identify the specific fuel pump that filled you adulterated fuel in Bangalore? Atleast all team bhpians will avoid it at any cost
gopikb is offline   Reply With Quote
Old 27th August 2011, 10:14   #33
sagarpadaki's Avatar
Thanked: 1,337 Times
The pump is a HP one in kengeri . Its on the left side of the road towards mysore at the signal.
Sluggish Swift, Edit: And other swift speed related queries pillainp Technical Stuff 90 8th September 2009 21:27
LPG mis-firing/back-firing/sluggish ranjithbalan Technical Stuff 4 26th April 2007 14:55
Pulsar 180 sluggish after 100kmph member Motorbikes 6 23rd August 2006 22:51
Sluggish Brakes on my Accent libre sito Technical Stuff 15 8th October 2004 19:19
Why is Suzuki India so sluggish? SLK The Indian Car Scene 7 10th June 2004 15:42
