Old 3rd August 2011, 12:29   #1
wildon's Avatar
Thanked: 1,057 Times
Default Help for removing the i20 ORVM Mirror Glass
Purpose:
I Want to install a Turn Signal indicator on the ORVM. Doesn't want to buy the new ORVM which comes with Turn Signal indicator as its costly.
Wanted to know:
The removal process of the mirror glass from the ORVM.
I know how to remove the ORVM module but need expert advice to remove the mirror glass.
As per my knowledge the mirror is fixed there by the supporting clips, and applying some gentle pressure it will come out easily. But wanted to know the location of that clip so nothing gets damaged.
Once the mirror is taken out heard that there are 4-5 screws and if we remove that we can takeout the back cover as well.
The other option is to drill a small hole and put the connecting wires through that so the wires wont be visible at all from outside(side/bottom/top)
Please help.
wildon is offline   Reply With Quote
Old 21st April 2013, 11:20   #2
joybhowmik's Avatar
Thanked: 1,909 Times
Default Re: Help for removing the i20 ORVM Mirror Glass
Originally Posted by wildon View Post
Purpose:
Hi wildon
I do too. As I understand there are two options
a) Indicator on the mirror housing
b) Indicator on the mirror (LED strip)
What kind did you install? Can you describe this in detail.
Old 21st April 2013, 11:25   #3
Safari_Beast's Avatar
Thanked: 196 Times
Purpose:
Wanted to know:
Please help.
In my swift clips are in center of glass , and i am pretty sure i20 will also be same .
Safari_Beast is offline   Reply With Quote
Wing mirror glass replacement Safari stefanm The Indian Car Scene 18 26th January 2017 10:55
XYG Glass or Saint Gobain glass HappyRoadie Technical Stuff 10 2nd June 2011 19:50
Settings gone after removing HU and removing key achopraa In-Car Entertainment 14 15th December 2007 22:18
