View Poll Results: What engine?
Rebuild the diesel. You have torque, reliability and a factory fit feel 17 30.36%
Isuzu 1.8 Liter Petrol! Give us more power, baby! 39 69.64%
Voters: 56. You may not vote on this poll
Closed Thread
Old 15th February 2006, 22:13   #16
Rudra Sen's Avatar
Thanked: 4,288 Times
Originally Posted by Aditya
While we are on the topic, why not try the Isuzu 4FG1 diesel? 2.4L, 78bhp. I think falcon has it in his Conti.
Adi bro, 1.8 ISZ only. Proven stuff. Cheap and easy to replace (you know my case). Smooth.
Rudra Sen is offline
Old 15th February 2006, 22:18   #17
Thanked: 27,201 Times
That's true. I drive one myself.
I just thought of giving GTO a "move up".
Aditya is offline
Old 16th February 2006, 03:36   #18
Rehaan's Avatar
Thanked: 25,037 Times
The question is......
Do you want a petrol jeep ???
I guess you know the answer....
cya
R
ps - so did i hear you say all the problems started that night you let Rtech drive? lol
Rehaan is offline
Old 16th February 2006, 09:54   #19
Rtech's Avatar
Thanked: 221 Times
what, you mean a jeep is not supposed to revv till 7,000rpm?
I say go the whole hog and plonk in a 1.8. That diesel was terrible anyways! Oh yea, don't forget the gearbox as well.
Rtech is offline
Old 16th February 2006, 10:09   #20
shuvc's Avatar
Thanked: 287 Times
Originally Posted by Mpower
I dont know if a petrol engine will suit the character of a Mahindra. Simply dosent sound right !
I second that .. Mahindra = Diesel ... be it a rebuild or some other new diesel engine.
shuvc is offline
Old 16th February 2006, 10:30   #21
Sahil's Avatar
Thanked: 2,712 Times
I'd say throw in a new engine. And bring on its "new life"
I see that this car has a lot of sentimental value to you and am sure you would never want to let go of it. An engine rebuild would give it some more time but a new engine would give it a much longer life span, maybe get past on to your next generation So i strongly suggest you get a new diesel engine and better still get a turbo chargered one, if that still maintains the "jeep" image for you.
Sahil is offline
Old 16th February 2006, 10:35   #22
Rtech's Avatar
Thanked: 221 Times
In almost all other countries where the Jeep is sold, it runs with petrol engines, so don't fall into the trap that Jeep=diesel. Its more like Mahindra=diesel.
To me, Jeep = inline 6 petrol actually!
Rtech is offline   (1) Thanks
Old 16th February 2006, 10:53   #23
Thanked: 655 Times
Default New Engine
Hi! I think I mentioned here that I had CJ3B with a 1.8 Isuzu engine. I replaced the original engine which was the Hurricane petrol engine (4Kmpl!!) with this engine. I also used a 4 speed 4wd gearbox off an isuzu van/trooper. The rear drive was centred off the gear box and the front drive was offset to the right. I had to change the rear diff assembly to that of a Commander and the original front was used (Later changed to that of a 4WD Mahindra Van- wider track).
I found the ratio between the 2nd and the 3rd to be little too wide, but the engine managed to handle that. On an isuzu diesel (4FC1Turbo) (which I did for a friend) this was very irritating.
Overall I found the 1.8 to be tractable and very efficient (9Kmpl).
The option of mating the original gearbox to the 1.8 was tried and removed due to regular problems which cropped up. My personal opinion is that very powerful engines are not a very good option for a stock 80" wheelbase jeep.
Hope I could be of help.
jyobeb is offline
Old 16th February 2006, 13:48   #24
Sideways's Avatar
Thanked: 18 Times
Would have to agree with m power. Scorpio engine will urn it into a beast. Go for it.
Sideways is offline
Old 16th February 2006, 14:32   #25
nitrous's Avatar
Thanked: 285 Times
Well, i've got a great idea.
Remove the CJ engine and keep it with u as it is.
Then, get the 1.8 ISZ for the peanuts it costs.
Get the transplant done along with the 4x4. Drive it around for a month, and if u have no problems with reliability,etc..stick to it.
Else, revert back to ur old engine and rebuild it.
Simple
nitrous is offline
Old 16th February 2006, 14:41   #26
Thanked: 34 Times
I would do as Nitrous has suggested.
deepakhon is online now
Old 16th February 2006, 14:46   #27
Thanked: 352 Times
Originally Posted by nitrous
Simple
tifosikrishna is offline
Old 16th February 2006, 14:54   #28
Joz
Would a scorpio engine fit in the CJ3B?
Joz is offline
Old 16th February 2006, 15:23   #29
nitrous's Avatar
Thanked: 285 Times
Pretty complicated. And sourcing the engine might be a problem and i'm sure it would cost upwards of 2 lakhs.... Do u think its worth it??
nitrous is offline
Old 16th February 2006, 16:07   #30
Thanked: 655 Times
Can help you get a scorpio (regular) engine + gearbox (used) from Chennai for about 90K
jyobeb is offline
Closed Thread
Engine, Gearbox, Diff ratios, axles options for the JEEP Frankenstein 4x4 Technical 112 7th June 2018 23:17
CJ4A jeep : Looking for alternative petrol engine options abheekg 4x4 Vehicles 6 5th October 2010 17:20
Scorpio CRDe @ 70,000 kms! 5,000 of Agony & 65,000 of bliss smats Long-Term Ownership Reviews 17 8th May 2010 17:37
Optra - Safe to use 100/130 watt bulbs? Boom Shiva Modifications & Accessories 10 23rd January 2006 15:08
