Old 7th August 2011, 11:27   #1
Default Help! Something dead in air vent!!
hi all
i have a 2009 swift. 2 days back a noise started coming from the air vents when switched on.
yesterday opened the car door and the insides are smelling of a dead rat or something!!
any idea how i can open the vent and get the thing out?
thanks bros
torrent2073 is offline   Reply With Quote
Old 7th August 2011, 11:48   #2
Sankar's Avatar
Thanked: 4,657 Times
Default Re: Help! Something dead in air vent!!
Places to check:
Fresh air inlet and diverter.
Blower unit under the passenger side dashboard.
The blower ducts inside the dash.
To get to all these places partial or complete removal of dashboard is required. The blower unit could be accessed after you remove the passenger side glove box but can you open it?
If you heard the noise of fan hitting something then it definitely might be in the blower unit.
Wise thing to do is to take it to the service centre and do a proper cleaning of the blower and ducts, you don't want any remnants of anything to be stuck in there and disinfect.
Sankar is offline   (4) Thanks Reply With Quote
Old 7th August 2011, 12:30   #3
the noise is still there when i turn the unit on. so i guess something's managed to get into the blower, and died there.
i'll try to open the glove compartment.
Old 7th August 2011, 23:15   #4
n.devdath's Avatar
Thanked: 2,155 Times
Is the noise there ONLY when you turn the fan on? In that case, it must be on the cylindrical fan on the blower, else, it could be anywhere in the ac ducts.
Unless you have the required tooling and experience at home, I would suggest taking the car to an ASC or a FNG to get it cleared.
Old 7th August 2011, 23:36   #5
Thanked: 655 Times
Please take it to your A.S.S. For removing the dash and checking your blower, they should be your only choice!
jyobeb is offline   Reply With Quote
Old 8th August 2011, 00:17   #6
Thanked: 381 Times
Take it to a service station or to a trusted local mechanic. It would be best to not attempt it yourself, considering that you may have a dead and mangled rat on your hands (literally )
keyur is offline   Reply With Quote
Old 8th August 2011, 01:05   #7
carfreak77's Avatar
Thanked: 129 Times
You should take it to your nearest service station and ask them to open the dash and blower unit up. If you attempt to do it yourself, maruti might raise warranty issues if they find out that it was opened. Hope its sorted out soon!
carfreak77 is offline   Reply With Quote
Old 8th August 2011, 07:11   #8
1self's Avatar
Thanked: 270 Times
DO NOT open the dashboard yourself. It's FAR more complicated than you think. There are LOTS of essential ECM wires running in the area.
DO NOT EAT OR DRINK in the car or allow anyone else also. These pests come looking for food & the smell coming from inside the vehicle (via the A/C vents) attracts them.
Keep some napthalene balls in the car at all times. These will mask the food smells & prevent further recurrence of such incidents.
Hope this helps.
1self is offline   (1) Thanks Reply With Quote
Old 8th August 2011, 09:42   #9
sachinj12's Avatar
Thanked: 162 Times
While this serves its purpose, remember that it will adversely affect your health.
I wouldn't suggest keeping naptha balls inside the car.
sachinj12 is offline   Reply With Quote
Old 8th August 2011, 10:03   #10
1self's Avatar
Thanked: 270 Times
Well, a couple of these would not be bad. OR, one could put them in when the car is not occupied & remove them when it is.
1self is offline   Reply With Quote
Old 8th August 2011, 10:14   #11
Jaggu's Avatar
Thanked: 8,696 Times
If its making noise inside the fan, its an easy job. The fan unit is under the dash near to passenger foot well. Remove the 3 screws and unit comes out. Ensure that you keep paper underneath so that the falling debri does not mess up the mats.
Old 8th August 2011, 12:47   #12
salbin's Avatar
Thanked: 164 Times
If you are going to MSIL service center, after cleaning the blower and ducts, ask them to put rat mesh(wire mesh) in the ac duct openings to prevent further entry of rats.
I had similar bad experience on my old zen and after putting the mesh, rat entry stopped.
salbin is offline   Reply With Quote
Something fast, Something naughty - The Volvo S60 T6 (304 BHP) kau_therock Test-Drives & Initial Ownership Reports 97 26th December 2014 17:27
Air France Plane goes missing!!! 228 feared dead! anilkalvani Shifting gears 114 12th March 2014 11:24
Cold air coming out only from the passenger-side A/C vent Harshavarthan Technical Stuff 11 26th February 2012 12:16
Air India Express Flight from Dubai crashes at Mangalore airport - Over 160 Dead sidindica Shifting gears 114 29th May 2010 14:04
Bonnet vent help lodhra Modifications & Accessories 1 7th May 2008 15:56
