Old 7th August 2011, 21:22   #1
hemen's Avatar
Thanked: 26 Times
Default Problems/Complication arising from "keyless go"
Hi Team,
I faced a problem today due to start stop mechanism in a nissan teana. It was parked behind my car, so it had to moved for my car to removed. The nissan did not accept the key. Finally after ten mins trying called the owner. He too tried but in vain. He thought the battery of the key must have got weak so brought the spare key but that to didnt work. We also tried the backup key installed in the key itself but the stering key would not move. Finally had to call a friend with his car.
My point is if a car with start/stop mechanism was out of station or on highway and the battery of the key dies or the ecu does not recognise the signal from the key is there any thing that can be done? Or do we have to go to service centre for help
Has anyone faced any such problem?
hemen is offline   (1) Thanks Reply With Quote
Old 7th August 2011, 21:29   #2
ghodlur's Avatar
Thanked: 2,438 Times
Red face Re: Problems/Complication arising from start/stop mechanism
Originally Posted by hemen View Post
Hi Team,
Thats bad. Before going to the service centre ask you friend to check the manual if he can do some intial diagnosis of the problem. If nothing helps then the service centre is the last alternative. After calling your friend did the problem get resolved, if so what was done?
My friend has a Nissan Micra, will contact him to find out if he has faced any issues regarding the start/stop.
ghodlur is offline   Reply With Quote
Old 7th August 2011, 21:35   #3
taranonline's Avatar
Thanked: 105 Times
Default Re: Problems/Complication arising from start/stop mechanism
There shouldnt be much issues about a simple start stop function. car has to be reprogrammed to resolve this issue or replace the sensor that checks the key.
taranonline is offline   Reply With Quote
Old 7th August 2011, 21:36   #4
hemen's Avatar
Thanked: 26 Times
This happend today evening and being a sunday nothing could be done. My car is still stuck.
hemen is offline   Reply With Quote
Old 10th August 2011, 15:24   #5
Thanked: 103,690 Times
Default Re: Problems/Complication arising from "keyless go"
Hi Hemen, firstly I've renamed your thread, presuming you are talking about keyless go. The start / stop mechanism is entirely different; it's basically a system that shuts the engine off when the car is stationary in traffic (to save fuel).
Did you guys try pressing the brake pedal before pressing the engine start button? It's a requirement with the Nissan system. If yes, and both the keys didn't work, probably an electrical problem somewhere.
Note that you can always call the traffic authorities if a car is parked such that it blocks you from driving away; the tow truck usually arrives in a very short while.
Old 10th August 2011, 15:50   #6
dhanushs's Avatar
Thanked: 4,507 Times
Thanks for the clarification. Even I, was unsure.
Doesn't the car come with real keys, which you put in the keyhole? It can be used, in case the batteries are shot.
Well, if the batteries are shot, as I mentioned above, one could use the real key. And, regarding the 2nd point, most modern cars (including the humble 800) come with an engine immobilizer, which requires the ECU to recognize the RF signal from the key. Its pretty reliable, and seldom causes problems.
Well, in case if it causes problems even with the original key, an ECU reset should solve the issue, which can be done anywhere, including the highway. You just have to remove the battery terminals, remove any residual current from the cars electrical system, wait for 20 mins, and re-connect it.
Old 10th August 2011, 16:00   #7
noopster's Avatar
Thanked: 9,598 Times
Hi Team,
I faced a problem today due to start stop mechanism in a nissan teana. It was parked behind my car, so it had to moved for my car to removed. The nissan did not accept the key. Finally after ten mins trying called the owner. He too tried but in vain...
Excuse me, but what key did you try using to open the Nissan before the owner got there? If you tried some other key than the vehicle's, maybe the immobiliser kicked in and hence didn't allow you to start the car?
noopster is offline   Reply With Quote
Old 10th August 2011, 16:05   #8
Neilguy's Avatar
Thanked: 51 Times
Hi Team,
Is the Teana owner your acquaintance. Are you sure it was his own car and not an imposter posing as the owner. Maybe thats why the car didn't start, as it shouldn't, without the original keys! Just a thought.
Neilguy is offline   (1) Thanks Reply With Quote
Old 10th August 2011, 16:59   #9
hemen's Avatar
Thanked: 26 Times
He is a neighbour
The car opened with the remote itself
The car is a prefacelift one nearly 2 years old and the owner personally drives it too once in a while. I have personally moved this car n number of times. The thing that we had observed was once the car accepts the key. 'KEY' in the dashboard turns green but it was just blinking in red like it hasn't registered the signal from the keys.The problem occurred maybe due to our limited knowledge of the system or plain badluck.
The next day, the driver of the car told me that the car did not start because the steering wheel was locked .
Old 10th August 2011, 17:20   #10
ghodlur's Avatar
Question Re: Problems/Complication arising from "keyless go"
Is this is a normal thing with such cars? I dont think there should be any relation with the steering wheel lock and the engine start stop. Doesn't the Steering wheel get locked manually? I am confused.
Old 10th August 2011, 18:17   #11
IndigoXLGrandDi's Avatar
Thanked: 161 Times
The residual current can be drained by depressing the Brake Pedal after removing the Battery Terminals, right? If yes, how long should the Brake Pedal be pressed?
IndigoXLGrandDi is offline   Reply With Quote
RTO NOC Complication - Guidance Needed meerkat The Indian Car Scene 67 21st December 2015 20:19
Virus problems/spyware problems! post here! SirAlec Gadgets, Computers & Software 10 16th July 2014 00:05
Mahindra Scorpio CRDE 2007 - Problems 'n' Problems chandrda Technical Stuff 3 13th November 2009 09:59
